Log in with ease
Activate Windows Hello via an infrared camera to facilitate facial recognition for easy and secure access. -
Trusted authentication
The Latitude 5490 offers multiple security options to meet your diverse security needs. Features include essential multi-factor authentication hardware such as contacted FIPS 201 Smart Card Reader, and Contactless Smart Card Reader NFC to prevent unauthorized access. -
Protection from attacks
Dell ControlVault 2 with FIPs 140-2 Level 3 Certification provides a more secure alternative for storing and processing passwords, biometric templates and security codes. -
Manage with ease
Through Dell unique vPro extensions, you can remotely manage a fleet of devices, including diagnostics whether they are powered on or off.
- Dell Latitude 5490 - 14" - Intel Core i5 - 8250U - 8 GB RAM - 256 GB SSD
- Product Type
- Notebook
- Operating System
- Win 10 Pro 64-bit
- Processor
- Intel Core i5 (8th Gen) - 8250U / 1.6 GHz, up to 3.4 GHz / 6 MB Cache
- Memory
- 8 GB DDR4 (1 x 8 GB)
- Storage
- 256 GB SSD
- Display
- 14" WLED 1920 x 1080 / Full HD
- Graphics
- Intel UHD Graphics 620
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet
- Battery
- 4-cell
- Security
- Trusted Platform Module (TPM 2.0) Security Chip, smart card reader
- Black
- 33.34 cm x 22.89 cm x 2.05 cm
- 1.6 kg
- Pricing Type
- Build To Stock (BTS)
- Limited warranty - 1 year - response time: next business day
- Product Type
- Notebook
- Operating System
- Windows 10 Pro 64-bit Edition
Processor / Chipset
- CPU
- Intel Core i5 (8th Gen) 8250U / 1.6 GHz
- Max Turbo Speed
- 3.4 GHz
- Number of Cores
- Quad-Core
- Cache
- 6 MB
- 64-bit Computing
- Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
- RAM
- 8 GB (1 x 8 GB)
- Max RAM Supported
- 32 GB
- Technology
- DDR4 SDRAM - non-ECC
- Speed
- 2400 MHz
- Rated Speed
- 2400 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 256 GB SSD M.2 SATA
Display
- 14"
- LCD Backlight Technology
- WLED backlight
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 220 cd/m²
- Anti-glare, Wide Viewing Angle
Audio & Video
- Graphics Processor
- Memory Allocation Technology
- Shared Video Memory (UMA)
- Camera
- Yes - 1280 x 720
- Resolution
- 1 Megapixel
- Image Sensor Type
- CMOS
- Video Resolutions
- 1280 x 720
- Frame Rate
- 30 frames per second
- Camera Features
- Fixed focus
- Sound
- Stereo speakers, dual array microphone
- Codec
- Realtek ALC3246
- High Definition Audio
Input
- Keyboard, touchpad
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 8265
- Network Interface
- Gigabit Ethernet
- Technology
- 4-cell
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 65 Watt, 19.5 V, 3.34 A
Connections & Expansion
- Interfaces Details
- Headphone/microphone combo jack , 2 x USB 3.1 Gen 1 , USB 3.1 Gen 1 (PowerShare) , HDMI , VGA , USB-C (supports DisplayPort Alt Mode) , LAN
- Memory Card Reader
- Yes (SD Card)
Software
- Software Included
- Microsoft Office (Trial), McAfee (30 days trial)
- Black
- Security
- Free Fall Sensor, MIL-STD-810G tested
- Theft/Intrusion Protection
- Security Slot Type
- Noble Wedge security slot
- Included Accessories
- Power adapter
- FIPS 140-2, TCG Certified
- Pricing Type
- 1.6 kg
Sustainability Information
- TCO Certified
- 0 °C
- 35 °C
- 10 - 90% (non-condensing)
