UK/BTS/Lati 5410/Intel Core i7-10610U/16GB/256GB SSD/14.0" FHD/Intel UHD 620/SmtCd/Cam & Mic/WLAN + BT/Backlit Kb/4 Cell/W10Pro/vPro/1Y Basic Onsite.
Advanced security and systems management
All Latitude E-Family laptops include features designed to simplify data protection, asset monitoring and remote management while allowing for immediate IT response to business threats. -
Smart controls
An intuitive, gesture-enabled touchpad lets you work smartly - and comfortably - in virtually any situation. -
Strength and sophistication
Reinforced hinges and rugged system latches add durability against the rigors of everyday use. -
Slim, reinforced display
Advanced LED technology enables Latitude E-Family laptops to have thinner widescreen displays while remaining exceptionally durable under everyday use. -
Critical data protection
A standard free-fall-sensor hard drive and Strike Zone shock absorber can protect your data against system drops - even if the laptop is turned off.
- Dell Latitude 5410 - 14" - Intel Core i7 10610U - vPro - 16 GB RAM - 256 GB SSD
- Product Type
- Notebook
- Operating System
- Win 10 Pro 64-bit - Multilingual User Interface (MUI)
- Platform Technology
- Intel vPro Platform
- Processor
- Intel Core i7 (10th Gen) 10610U / 1.8 GHz (4.9 GHz) / 8 MB Cache
- Memory
- 16 GB DDR4 (1 x 16 GB)
- Storage
- 256 GB SSD - NVMe
- Display
- 14" 1920 x 1080 / Full HD @ 60 Hz - 157 ppi
- Graphics
- Intel UHD Graphics
- Input Device
- Pointing stick
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac Wave 2/ax, Bluetooth 5.1, Gigabit Ethernet
- Battery
- 4-cell
- Security
- Trusted Platform Module (TPM 2.0) Security Chip, smart card reader
- Grey
- 32.305 cm x 21.6 cm x 2.118 cm
- 1.47 kg
- Pricing Type
- Build To Stock (BTS)
- Bundled Services
- 1 Year Basic Onsite
- Product Type
- Notebook
- Operating System
- Windows 10 Pro 64-bit Edition - Multilingual User Interface (MUI)
Processor / Chipset
- CPU
- Max Turbo Speed
- 4.9 GHz
- Number of Cores
- Quad-Core
- Cache
- 8 MB
- 64-bit Computing
- Intel Turbo Boost Technology 2.0
- RAM
- 16 GB (1 x 16 GB)
- Max RAM Supported
- 32 GB
- Technology
- DDR4 SDRAM
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 256 GB SSD M.2 PCIe 3.0 x4 - NVM Express (NVMe)
Display
- 14"
- Resolution
- 1920 x 1080 (Full HD)
- V-Sync Rate at Max Res.
- 60 Hz
- Widescreen
- Pixel Density (ppi)
- 157
- Anti-glare, Wide Viewing Angle, ±80° horizontal viewing angle, ±80° vertical viewing angle, 35 ms response rate, 0.161 mm pixel pitch
Audio & Video
- Graphics Processor
- Memory Allocation Technology
- Shared Video Memory (UMA)
- Camera
- Yes - HD
- Resolution
- 2 Megapixel
- Image Sensor Type
- CMOS
- Video Resolutions
- 1280 x 720
- Frame Rate
- 30 frames per second
- Camera Features
- Privacy shutter, 78.6 degrees
- Sound
- Stereo speakers, dual array microphone
- Codec
- Realtek ALC3204
- High Definition Audio
- Audio Features
- Output: MaxxAudio Pro
Input
- Keyboard, touchpad, pointing stick
Communications
- Wireless
- Wireless Controller
- Intel Wi-Fi 6 AX 201
- Network Interface
- Gigabit Ethernet
- Technology
- 4-cell
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 65 Watt, 19.5 V
Connections & Expansion
- HDMI , USB-C 3.2 Gen 2 (supports DisplayPort Alt Mode) , USB 3.2 Gen 1 (PowerShare) , 2 x USB 3.2 Gen 1 , LAN , Headphone/microphone combo jack
- Memory Card Reader
- Yes (microSD, microSDHC, microSDXC)
Software
- Software Included
- Microsoft Office (Trial)
- Grey
- Security
- Theft/Intrusion Protection
- Security Slot Type
- Noble Wedge security slot
- Included Accessories
- Power adapter
- Pricing Type
- 1.47 kg
- Bundled Services
- 0 °C
- 35 °C
- 10 - 80% (non-condensing)
- Shock Tolerance (operating)
- 105 g @ 2 ms half-sine pulse
- Shock Tolerance (non-operating)
- 40 g @ 2 ms half-sine pulse
- Vibration Tolerance (operating)
- 0.26 g @ RMS (random)
- Vibration Tolerance (non-operating)
- 1.37 g @ RMS (random)
Dell Slim DW316 USB External DVD Drive | In Stock | £35.58 |
Dell MS116 Mouse Optical Wired USB Black For Lattitude | In Stock | £10.93 |
Dell KB216 Keyboard USB Black For Inspiron 17 5759, 3459 | In Stock | £15.45 |
Dell KB216 Keyboard USB UK QWERTY Grey Inspiron 24 3459 | In Stock | £13.82 |
Dell Multimedia Keyboard KB216 UK | In Stock | £15.45 |
APC Smart-UPS SMC1000IC - UPS - AC 220/230/240 V - 600 Watt | In Stock | £438.36 |
APC BACK-UPS BE650G2-UK 650VA 230V | In Stock | £106.61 |
APC BACK-UPS BE850G2-UK 850VA 230V USB | In Stock | £110.10 |
