Dell Latitude 5410 Intel Core i5-10310U 16GB 256GB SSD 14" Windows 10 Professional 64-bit
Quicklinx: FW3BWS00 Mfr#: 20TT1
  • Core i5
  • IEEE 802.11n
UK/BTS/Lati 5410/Core i5-10310U/16GB/256GB SSD/14.0" FHD/Intel UHD 620/SmtCd/Cam & Mic/WLAN + BT/Backlit Kb/4 Cell/W10Pro/vPro/1Y Basic Onsite.
  • Advanced security and systems management
    All Latitude E-Family laptops include features designed to simplify data protection, asset monitoring and remote management while allowing for immediate IT response to business threats.
  • Smart controls
    An intuitive, gesture-enabled touchpad lets you work smartly - and comfortably - in virtually any situation.
  • Strength and sophistication
    Reinforced hinges and rugged system latches add durability against the rigors of everyday use.
  • Slim, reinforced display
    Advanced LED technology enables Latitude E-Family laptops to have thinner widescreen displays while remaining exceptionally durable under everyday use.
  • Critical data protection
    A standard free-fall-sensor hard drive and Strike Zone shock absorber can protect your data against system drops - even if the laptop is turned off.
Dell Latitude 5410 - 14" - Core i5 10310U - vPro - 16 GB RAM - 256 GB SSD
Notebook
Operating System
Win 10 Pro 64-bit - Multilingual User Interface (MUI)
Platform Technology
Intel vPro Platform
Intel Core i5 (10th Gen) 10310U / 1.7 GHz (4.4 GHz) / 6 MB Cache
16 GB DDR4 (1 x 16 GB)
Storage
256 GB SSD
Display
14" 1920 x 1080 / Full HD @ 60 Hz - 157 ppi
Graphics
Intel UHD Graphics
Input Device
Keyboard (on selected markets only)
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac Wave 2/ax, Bluetooth 5.1, Gigabit Ethernet
4-cell
Security
Trusted Platform Module (TPM 2.0) Security Chip, smart card reader
32.305 cm x 21.6 cm x 2.118 cm
1.47 kg
Pricing Type
Build To Stock (BTS)
Bundled Services
1 Year Basic Onsite
Notebook
Operating System
Windows 10 Pro 64-bit Edition - Multilingual User Interface (MUI)
Processor / Chipset
CPU
Max Turbo Speed
4.4 GHz
Number of Cores
Quad-Core
Cache
6 MB
64-bit Computing
Platform Technology
Intel vPro Platform
Intel Turbo Boost Technology 2.0
RAM
16 GB (1 x 16 GB)
Max RAM Supported
32 GB
DDR4 SDRAM
Storage
Main Storage
256 GB SSD M.2 PCIe
Display
14"
Resolution
1920 x 1080 (Full HD)
V-Sync Rate at Max Res.
60 Hz
Widescreen
Pixel Density (ppi)
157
Anti-glare, Wide Viewing Angle, ±80° horizontal viewing angle, ±80° vertical viewing angle
Audio & Video
Graphics Processor
Intel UHD Graphics
Memory Allocation Technology
Shared Video Memory (UMA)
Camera
Yes - HD
Resolution
2 Megapixel
Image Sensor Type
CMOS
Video Resolutions
1280 x 720
Frame Rate
30 frames per second
Camera Features
78.6 degrees
Sound
Stereo speakers, dual array microphone
Codec
Realtek ALC3204
High Definition Audio, Wave MAXXAudio Pro
Input
Touchpad, keyboard (on selected markets only)
Keyboard Backlight
Communications
Wireless
Wireless Controller
Intel Wi-Fi 6 AX 201
Network Interface
Gigabit Ethernet
4-cell
AC Adapter
Input
Output
65 Watt, 19.5 V
Connections & Expansion
HDMI , USB-C 3.2 Gen 2 (supports Thunderbolt 3, DisplayPort Alt Mode) , USB 3.2 Gen 1 (PowerShare) , 2 x USB 3.2 Gen 1 , LAN , Headphone/microphone combo jack
Memory Card Reader
Yes (microSD, microSDHC, microSDXC)
Software
Software Included
Microsoft Office (Trial)
Security
ExpressCharge
Theft/Intrusion Protection
Security Slot Type
Noble Wedge security slot
Power adapter
Pricing Type
1.47 kg
Bundled Services
1 Year Basic Onsite
35 °C
10 - 80% (non-condensing)
Shock Tolerance (operating)
105 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
40 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.26 g @ RMS (random)
Vibration Tolerance (non-operating)
1.37 g @ RMS (random)
