Dell Latitude 5410 Intel Core i5-10210U 8GB 256GB SSD 14" Windows 10 Professional 64-bit
Quicklinx: FW3CWS00 Mfr#: 27VWJ
Display Size: 14in
Processor Model: I5-10210U
Operating System: Windows 10 Pro 64-bit Edition
Hard Drive Capacity: 256GB
Optical Storage: None
  • Core i5
  • IEEE 802.11n
14 in stock
£727.14 ex VAT
£872.56 inc VAT
UK/BTS/Lati 5410/Core i5-10210U/8GB/256GB SSD/14.0" FHD/Intel UHD 620/SmtCd/Cam & Mic/WLAN + BT/Backlit Kb/4 Cell/W10Pro/1Y Basic Onsite.
  • Advanced security and systems management
    All Latitude E-Family laptops include features designed to simplify data protection, asset monitoring and remote management while allowing for immediate IT response to business threats.
  • Smart controls
    An intuitive, gesture-enabled touchpad lets you work smartly - and comfortably - in virtually any situation.
  • Strength and sophistication
    Reinforced hinges and rugged system latches add durability against the rigors of everyday use.
  • Slim, reinforced display
    Advanced LED technology enables Latitude E-Family laptops to have thinner widescreen displays while remaining exceptionally durable under everyday use.
  • Critical data protection
    A standard free-fall-sensor hard drive and Strike Zone shock absorber can protect your data against system drops - even if the laptop is turned off.
Dell Latitude 5410 - 14" - Core i5 10210U - 8 GB RAM - 256 GB SSD
Notebook
Operating System
Win 10 Pro 64-bit - Multilingual User Interface (MUI)
Intel Core i5 (10th Gen) 10210U / 1.6 GHz (4.2 GHz) / 6 MB Cache
8 GB DDR4 (1 x 8 GB)
Storage
256 GB SSD NVMe
Optical Drive
No optical drive
Display
14" 1920 x 1080 / Full HD - 157 ppi
Graphics
Intel UHD Graphics
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac Wave 2/ax, Bluetooth 5.1, Gigabit Ethernet
4-cell
Security
Trusted Platform Module (TPM 2.0) Security Chip, smart card reader
Grey
32.305 cm x 21.6 cm x 2.118 cm
1.47 kg
Pricing Type
Build To Stock (BTS)
Environmental Standards
TCO Certified Notebooks 8
Bundled Services
1 Year Basic Onsite
Notebook
Operating System
Windows 10 Pro 64-bit Edition - Multilingual User Interface (MUI)
Bundled Services
1 Year Basic Onsite
Processor / Chipset
CPU
Max Turbo Speed
4.2 GHz
Number of Cores
Quad-Core
Cache
6 MB
64-bit Computing
Intel Turbo Boost Technology 2.0, Intel Smart Cache
RAM
8 GB (1 x 8 GB)
Max RAM Supported
32 GB
DDR4 SDRAM
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
256 GB SSD - (M.2) PCIe 3.0 x4 - NVM Express (NVMe)
Display
14"
Resolution
1920 x 1080 (Full HD)
Widescreen
Pixel Density (ppi)
157
Bezel Type
Raised
Anti-glare, Wide Viewing Angle, ±80° horizontal viewing angle, ±80° vertical viewing angle, 35 ms response rate, 60 Hz refresh rate, 0.161 mm pixel pitch
Audio & Video
Graphics Processor
Intel UHD Graphics
Memory Allocation Technology
Shared Video Memory (UMA)
Camera
Yes - HD
Resolution
2 Megapixel
Image Sensor Type
CMOS
Video Resolutions
1280 x 720
Frame Rate
30 frames per second
Camera Features
Privacy shutter, 78.6 degrees
Sound
Stereo speakers, dual array microphone
Codec
Realtek ALC3204
High Definition Audio
Audio Features
MaxxAudio Pro
Input
Keyboard, touchpad
Keyboard Backlight
Communications
Wireless
Wireless Controller
Intel Wi-Fi 6 AX 201
Network Interface
Gigabit Ethernet
4-cell
AC Adapter
Input
Output
65 Watt, 19.5 V
Connections & Expansion
HDMI , USB-C 3.2 Gen 2/DisplayPort , USB 3.2 Gen 1 (PowerShare) , 2 x USB 3.2 Gen 1 , LAN , Headphone/microphone combo jack
Memory Card Reader
Yes (microSD, microSDHC, microSDXC)
Software
Software Included
Microsoft Office (Trial)
Grey
Security
Theft/Intrusion Protection
Security Slot Type
Noble Wedge security slot
Power adapter
Pricing Type
1.47 kg
TCO Certified
35 °C
10 - 80% (non-condensing)
Shock Tolerance (operating)
105 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
40 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.26 g @ RMS (random)
Vibration Tolerance (non-operating)
1.37 g @ RMS (random)
Display Size: 14in
Graphics: Intel UHD Graphics
Hard Drive Type: SSD
Brand: Dell
Price Range Ex VAT: 500 - 750
