The small 14" mainstream business-class notebook lets you get to work faster than ever thanks to its scalable features, powerful performance and ExpressCharge.
Bypass passwords
Start the workday faster by signing on with an optional fingerprint reader integrated into the power button or with the optional IR camera + Windows Hello for seamless authentication. -
Power through the day
Keep the work flowing with a high-density battery and ExpressCharge, which allows an 80% charge in one hour. With Dell Power Manager, you can choose from four modes to balance between optimal battery or power performance. -
Connect anywhere
Seamlessly work on the go thanks to optional mobile broadband supporting speeds up to 450 Mbps. -
Travel light
The Latitude 5400 is more mobile and portable than ever, with an improved design that's thin and modern. The bottom mount keyboard contributes to its clean look and feel. -
Ultimate views
The display is packed with features designed to keep you focused on your work, like the four-sided narrow bezel and antiglare screen.
- Dell Latitude 5400 - 14" - Core i5 8265U - 8 GB RAM - 256 GB SSD
- Product Type
- Notebook
- Operating System
- Win 10 Pro 64-bit - Multilingual User Interface (MUI)
- Processor
- Intel Core i5 (8th Gen) 8265U / 1.6 GHz (3.9 GHz) / 6 MB Cache
- Memory
- 8 GB DDR4
- Storage
- 256 GB SSD NVMe
- Optical Drive
- No optical drive
- Display
- 14" WLED 1920 x 1080 / Full HD
- Graphics
- Intel UHD Graphics 620
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac Wave 2, Bluetooth 5.0, Gigabit Ethernet
- Battery
- 4-cell
- Security
- Trusted Platform Module (TPM 2.0) Security Chip, smart card reader
- Black
- 32.305 cm x 21.6 cm x 2.085 cm
- 1.52 kg
- Pricing Type
- Build To Stock (BTS)
- Limited warranty - 1 year - on-site
- Product Type
- Notebook
- Operating System
- Windows 10 Pro 64-bit Edition - Multilingual User Interface (MUI)
Processor / Chipset
- CPU
- Max Turbo Speed
- 3.9 GHz
- Number of Cores
- Quad-Core
- Cache
- 6 MB
- 64-bit Computing
- Intel Turbo Boost Technology 2.0
- RAM
- 8 GB
- Max RAM Supported
- 32 GB
- Technology
- DDR4 SDRAM
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 2
Storage
- Main Storage
- 256 GB SSD - (M.2) PCIe - NVM Express (NVMe)
Display
- 14"
- LCD Backlight Technology
- WLED backlight
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 220 cd/m²
- Anti-glare, Wide Viewing Angle, ±80° horizontal viewing angle, ±80° vertical viewing angle, 157 ppi
Audio & Video
- Graphics Processor
- Memory Allocation Technology
- Shared Video Memory (UMA)
- Camera
- Yes - HD
- Image Sensor Type
- CMOS
- Video Resolutions
- 1280 x 720
- Frame Rate
- 30 frames per second
- Camera Features
- 78.6 degrees, RGB camera
- Sound
- Stereo speakers, array microphone
- Codec
- Realtek ALC3204
- Wave MAXXAudio Pro
Input
- Keyboard, touchpad
- Multi-touch touchpad
Communications
- Wireless
- Wireless Controller
- Intel Wireless-AC 9560
- Network Interface
- Gigabit Ethernet
- Technology
- 4-cell Lithium Ion
- Capacity
- 68 Wh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 65 Watt, 19.5 V, 3.34 A
Connections & Expansion
- 3 x USB 3.1 Gen 1 , LAN , HDMI , Headphone/microphone combo jack , USB-C 3.1 Gen 2/DisplayPort
- Memory Card Reader
- Yes (microSD)
Software
- Software Included
- Microsoft Office (Trial)
- Black
- Security
- ExpressCharge
- Theft/Intrusion Protection
- Security Slot Type
- Noble Wedge security slot
- Included Accessories
- Power adapter
- FIPS 140-2
- Pricing Type
- 1.52 kg
- 0 °C
- 35 °C
- 10 - 80% (non-condensing)
- Shock Tolerance (operating)
- 105 g @ 2 ms half-sine pulse
- Shock Tolerance (non-operating)
- 40 g @ 2 ms half-sine pulse
- Vibration Tolerance (operating)
- 0.26 g @ RMS (random)
- Vibration Tolerance (non-operating)
- 1.37 g @ RMS (random)
Software applications
Bundle includes:
Microsoft Office Home & Business 2019 Box Pack (Medialess, 1 PC, One Time Purchase) worth £191.34 | in stock |
£909.68
saving £8.33
saving £8.33
Bundle includes:
Microsoft Office 365 Business Premium ‘in a box’ 1 year subscription/license worth £99.17 | in stock |
£825.84
