Dell Latitude 5400 Intel Core i5-8250U 8GB 256GB SSD 14" Windows 10 Professional 64-bit
Quicklinx: FMXXWS00 Mfr#: M37GN
  • Core i5
  • IEEE 802.11n
The small 14" mainstream business-class notebook lets you get to work faster than ever thanks to its scalable features, powerful performance and ExpressCharge.
  • Bypass passwords
    Start the workday faster by signing on with an optional fingerprint reader integrated into the power button or with the optional IR camera + Windows Hello for seamless authentication.
  • Power through the day
    Keep the work flowing with a high-density battery and ExpressCharge, which allows an 80% charge in one hour. With Dell Power Manager, you can choose from four modes to balance between optimal battery or power performance.
  • Connect anywhere
    Seamlessly work on the go thanks to optional mobile broadband supporting speeds up to 450 Mbps.
  • Travel light
    The Latitude 5400 is more mobile and portable than ever, with an improved design that's thin and modern. The bottom mount keyboard contributes to its clean look and feel.
  • Ultimate views
    The display is packed with features designed to keep you focused on your work, like the four-sided narrow bezel and antiglare screen.
Dell Latitude 5400 - 14" - Core i5 8250U - 8 GB RAM - 256 GB SSD
Notebook
Operating System
Win 10 Pro 64-bit
Intel Core i5 (8th Gen) 8250U / 1.6 GHz (3.4 GHz) / 6 MB Cache
8 GB DDR4 (1 x 8 GB)
Storage
256 GB SSD - NVMe
Display
14" WLED 1920 x 1080 / Full HD @ 60 Hz - 157 ppi
Graphics
Intel UHD Graphics 620
Input Device
Pointing stick
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet
4-cell
Security
Trusted Platform Module (TPM 2.0) Security Chip, smart card reader
32.305 cm x 21.6 cm x 2.085 cm
1.48 kg
Pricing Type
Build To Stock (BTS)
Bundled Services
1 Year Basic Onsite
Notebook
Operating System
Windows 10 Pro 64-bit Edition
Processor / Chipset
CPU
Max Turbo Speed
3.4 GHz
Number of Cores
Quad-Core
Cache
6 MB
64-bit Computing
Intel Turbo Boost Technology 2.0
RAM
8 GB (1 x 8 GB)
Max RAM Supported
32 GB
DDR4 SDRAM - non-ECC
Speed
2400 MHz
Rated Speed
2666 MHz
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
256 GB SSD M.2 PCIe - NVM Express (NVMe)
Display
14"
LCD Backlight Technology
WLED backlight
Resolution
1920 x 1080 (Full HD)
V-Sync Rate at Max Res.
60 Hz
Widescreen
Pixel Density (ppi)
157
Image Aspect Ratio
16:9
Image Brightness
220 cd/m²
Anti-glare, Wide Viewing Angle, ±80° horizontal viewing angle, ±80° vertical viewing angle
Audio & Video
Graphics Processor
Memory Allocation Technology
Shared Video Memory (UMA)
Camera
Yes - HD
Image Sensor Type
CMOS
Video Resolutions
1280 x 720
Frame Rate
30 frames per second
Camera Features
78.6 degrees, RGB camera
Sound
Stereo speakers, dual array microphone
Codec
Realtek ALC3204
High Definition Audio
Audio Features
Output: MaxxAudio Pro
Input
Keyboard, touchpad, pointing stick
Keyboard Backlight
Multi-touch touchpad
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 8265
Network Interface
Gigabit Ethernet
4-cell Lithium Ion
68 Wh
AC Adapter
Input
Output
65 Watt, 19.5 V, 3.34 A
Connections & Expansion
USB-C 3.1 Gen 2 (supports Thunderbolt 3, DisplayPort Alt Mode) , USB 3.1 Gen 1 (PowerShare) , 2 x USB 3.1 Gen 1 , LAN , Headphone/microphone combo jack
Memory Card Reader
Yes (microSD)
Security
ExpressCharge
Theft/Intrusion Protection
Security Slot Type
Noble Wedge security slot
Power adapter
FIPS 140-2
Pricing Type
1.48 kg
Bundled Services
1 Year Basic Onsite
35 °C
10 - 80% (non-condensing)
Shock Tolerance (operating)
105 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
40 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.26 g @ RMS (random)
Vibration Tolerance (non-operating)
1.37 g @ RMS (random)
