Latitude 5330|i5-1235U, vPro|8GB|256GB SSD|13.3" FHD|Cam & Mic|Intel Iris Xe|ThBlt & FgrPr & SmtCd|4 Cell|65W Type-C|WLAN|Backlit Kb|W10Pro+W11Pro Licence|1Y Basic Onsite.
ExpressConnect
Be on 2 networks at once with simultaneous multi-network connection for faster data and video downloads. Get more data transfer from optimized networking, faster application data processing and better video quality from optimized Internet bandwidth. -
4G and Wi-Fi 6E connections
Wi-Fi 6E allows more channels with more bandwidth which provides faster, smoother Wi-Fi, especially in high-density areas while 4G LTE options keep you connected wherever you work. -
Work remote for longer
Long battery life with ExpressCharge that provides charge quickly. -
Intelligent privacy
Onlooker detection notifies you when someone is peering at your screen and will texturize your screen. Look Away Detect knows when your focus is elsewhere and dims to further protect privacy and save battery life. -
Enhanced camera
Look great on every video call with improved Full HD IR camera options. Available Temporal Noise Reduction enhances image quality in any light. -
ExpressSign-In
A camera-based proximity sensor wakes your system on approach and locks when you walk away. -
Intelligent audio
Artificial intelligence improves audio and voice quality and adjusts for different environments. Neural Noise Cancellation eliminates unwanted background noise as well as the background noise of the participants on your call. -
ExpressResponse
Based on user behavior, ExpressResponse prioritizes your CPU to improve the performance of the apps you're currently using. -
Cool under pressure
Larger fan with optimized venting and other thermal improvements keeps your system cool even when working with multiple applications. -
Easy on the eyes
Featuring ComfortView Plus low blue light technology to reduce eye strain for all day working.
- Dell Latitude 5330 - 13.3" - Intel Core i5 1235U - 8 GB RAM - 256 GB SSD
- Product Type
- Notebook
- Operating System
- Win 10 Pro 64-bit (downgrade from Windows 11 Pro) + Windows 11 Pro Licence - Dutch / English / French / German / Italian
- Processor
- Intel Core i5 (12th Gen) 1235U / 1.3 GHz (4.4 GHz) / 12 MB Cache
- Memory
- 8 GB LPDDR4 (provided memory is soldered)
- Storage
- 256 GB SSD - NVMe, Class 35
- Display
- 13.3" 1920 x 1080 / Full HD @ 60 Hz - 166 ppi
- Graphics
- Intel Iris Xe Graphics
- Keyboard Backlight
- Integrated Webcam
- Networking
- Bluetooth, 802.11a/b/g/n/ac/ax (Wi-Fi 6E)
- Battery
- 4-cell
- Accelerometer
- Security
- Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader
- Grey
- 30.57 cm x 20.75 cm x 1.843 cm
- 1.2 kg
- Pricing Type
- Build To Stock (BTS)
- Manufacturer Selling Program
- Dell Smart Selection
- Environmental Standards
- ENERGY STAR Qualified EPEAT Gold
- Bundled Services
- 1 Year Basic Onsite
- Product Type
- Notebook
- Operating System
- Windows 10 Pro 64-bit Edition (available through downgrade rights from Windows 11 Pro) + Windows 11 Pro Licence - Dutch / English / French / German / Italian
Processor / Chipset
- CPU
- Max Turbo Speed
- 4.4 GHz
- Number of Cores
- 10-core
- Cache
- 12 MB
- 12 Threads
- RAM
- 8 GB (provided memory is soldered)
- Technology
- LPDDR4 SDRAM
- Speed
- 3200 MHz
- Rated Speed
- 3200 MHz
Storage
- Main Storage
- 256 GB SSD M.2 PCIe - NVM Express (NVMe), Class 35
Display
- 13.3"
- Resolution
- 1920 x 1080 (Full HD)
- V-Sync Rate at Max Res.
- 60 Hz
- Widescreen
- Pixel Density (ppi)
- 166
- Image Aspect Ratio
- 16:9
- Image Brightness
- 250 cd/m²
- Colour Gamut
- 45% NTSC
- Anti-glare, Wide Viewing Angle, ±85° horizontal viewing angle, ±85° vertical viewing angle, 35 ms response rate, 0.153 mm pixel pitch
Audio & Video
- Graphics Processor
- Camera
- Yes - HD
- Resolution
- 0.92 Megapixel
- Image Sensor Type
- CMOS
- Video Resolutions
- 1280 x 720
- Frame Rate
- 30 frames per second
- Camera Features
- Privacy shutter, 78.6 degrees, RGB camera, Temporal Noise Reduction
- Sound
- Stereo speakers, dual array microphone
- Codec
- Realtek ALC3204
- High Definition Audio
- Audio Features
- Output: MaxxAudio Pro
Input
- Keyboard, touchpad
Communications
- Wireless
- Wireless Controller
- Intel Wi-Fi 6E AX 211 - M.2 2230
- Dual stream (2x2)
- Technology
- 4-cell Lithium Ion
- Capacity
- 58 Wh
AC Adapter
- Input
- AC 100-240 V (50/60 Hz)
- Output
- 65 Watt, 5 / 9 / 15 / 20 V
Connections & Expansion
- HDMI , 2 x USB4 (supports Thunderbolt 4, DisplayPort Alt Mode) (Power Delivery) , USB 3.2 Gen 1 (PowerShare) , USB 3.2 Gen 1 , Headphone/microphone combo jack
- Memory Card Reader
- Yes (microSD, microSDHC, microSDXC)
Software
- Software Included
- Microsoft Office (30 days trial, excludes office licence), Dell Applications for Windows 11
- Grey
- Integrated Options
- Accelerometer
- Security
- ExpressCharge
- Theft/Intrusion Protection
- Security Slot Type
- Noble Wedge security slot
- Included Accessories
- USB-C power adapter
- FIPS 140-2, FIPS 201
- Pricing Type
- 1.2 kg
Sustainability Information
- EPEAT Compliant
- EPEAT Gold
- ENERGY STAR Certified
- Bundled Services
- 0 °C
- 35 °C
- 10 - 90% (non-condensing)
- Shock Tolerance (operating)
- 110 g @ 2 ms half-sine pulse
- Shock Tolerance (non-operating)
- 160 g @ 2 ms half-sine pulse
- Vibration Tolerance (operating)
- 0.66 g @ RMS (random)
- Vibration Tolerance (non-operating)
- 1.3 g @ RMS (random)
Essential Accessories (5)
Get more from your purchase from one of our essential accessories
Targus Meridian II Toploader Notebook Carrying Case 15.6" Black | In Stock | £45.11 |
Dell Docking Station WD19S - USB-C - HDMI, 2 x DP, USB-C - GigE | In Stock | £148.13 |
Dell Docking Station WD19S - USB-C - HDMI, 2 x DP, USB-C - GigE | In Stock | £141.12 |
Dell USB-C AC Adapter - Power adapter - 65 Watt - UK | In Stock | £43.60 |
Dell Essential Backpack 15 | In Stock | £15.44 |
Other bundles (19)
Dell Slim DW316 USB External DVD Drive | In Stock | £32.24 |
Dell KB-813 Smart Card Reader | In Stock | £40.85 |
Dell Ultrasharp U2421E 23.8" 1920x1200 5ms HDMI DisplayPort USB-C IPS LED Monitor | In Stock | £188.26 |
Dell P2422H 24" 1920 x 1080 5ms HDMI VGA Monitor | In Stock | £120.91 |
Dell Pro KM5221W Keyboard and Mouse Set - QWERTY - UK - Black | In Stock | £28.06 |
Dell P2722H 27" 1920x1080 8ms VGA HDMI DisplayPort IPS LED Monitor | In Stock | £134.70 |
Dell Wireless Keyboard and Mouse KM7120W - UK - Titan Grey | In Stock | £49.25 |
Dell P2422HE 23.8" 1920x1080 8ms HDMI DisplayPort USB-C LED Monitor | In Stock | £157.37 |
Dell SB521A Magnetic Sound bar | In Stock | £30.79 |
Dell MS5120W Mobile Pro Wireless Mouse | In Stock | £24.13 |
Dell UltraSharp U3223QE 31.5" 3840x2160 8ms DisplayPort HDMI USB-C IPS LED Monitor | In Stock | £555.90 |
Dell Premier Multi-Device KM7321W Wireless Keyboard and Mouse | In Stock | £57.27 |
Dell P2423 24" 1920 x 1200 8ms HDMI DVI VGA USB LED LCD Monitor | In Stock | £131.03 |
Dell P2723DE 27" 2560 x1440 8ms HDMI DP USB LED LCD Monitor | In Stock | £281.81 |
Dell P2222H - LED monitor - 22" (21.5" viewable) - 1920 x 1080 Fu | In Stock | £94.81 |
Dell Stereo Headset WH1022 | In Stock | £29.91 |
Dell Dual Monitor Stand - MDS19 | In Stock | £150.16 |
Dell P2423D 23.8" 2560x1440 5ms HDMI DisplayPort IPS LED Monitor | In Stock | £182.68 |
Dell Ultrasharp U2723QE 27" 3840x2160 5ms HDMI DisplayPort USB-C IPS LED Monitor | In Stock | £391.41 |
