Dell Latitude 5300 Intel Core i5-8265U 8GB 256GB SSD 13.3" Windows 10 Professional 64-bit
Quicklinx: FMTMWS00 Mfr#: F60PX
  • Core i5
  • IEEE 802.11n
Dell Latitude business-class 2-in-1 gives you the flexibility you want, with features like ExpressCharge you can charge up to 80% in one hour.
  • Work how you want
    Use it like a tablet or like a laptop with the ISO-compliant keyboard.
  • Connect anywhere
    Seamlessly work on the go thanks to optional mobile broadband supporting speeds up to 450Mbps.
  • Stay synced
    Thanks to Modern Standby capability, you can resume work quickly when waking your system since Wi-Fi is running in the background.
  • Power through the day
    Keep the work flowing with a high-density battery and ExpressCharge, which allows an 80% charge in one hour. With Dell Power Manager, you can choose between four modes to balance between optimal battery or power performance.
  • Get up and go
    Start the workday faster by signing on with optional fingerprint reader integrated into the power button or with the optional IR camera + Windows Hello for seamless authentication.
  • Elevated design
    Starting at 3.15lbs., this small and light 2-in-1 has a 4-sided narrow bezel with edge-to-edge Gorilla Glass and a light, stylish finish. It also features an optional Thunderbolt 3 port for even more versatility.
  • Sustainability
    Dell is proactive in the fight against pollution by using recycled ocean-bound plastic in the packaging.
  • Work fast, stay cool
    The fan technology utilizes a Liquid Crystal Polymer material. This allows for the creation of thinner fan blades and provides maximum airflow for an overall cooler experience.
  • Seamless sign on
    SafeID protects end user credentials with optional fingerprint reader on the power button and the optional FIPS 201 Smart Card Reader delivering fast, multi-factor authentication you've come to expect from the world's most secure PC portfolio.
  • Remotely manage
    Dell unique vPro extensions can remotely manage and run diagnostics on a fleet of devices, whether they are powered on or off.
Dell Latitude 5300 2-in-1 - 13.33" - Core i5 8265U - 8 GB RAM - 256 GB SSD
Notebook - flip design
Operating System
Win 10 Pro 64-bit - Multilingual User Interface (MUI)
Intel Core i5 (8th Gen) 8265U / 1.6 GHz (3.9 GHz) / 6 MB Cache
8 GB DDR4 (1 x 8 GB)
Storage
256 GB SSD - NVMe, Class 40
Display
13.33" touchscreen 1920 x 1080 / Full HD @ 60 Hz - 166 ppi
Graphics
Intel UHD Graphics 620
Input Device
Digitizer, digital pen
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac Wave 2, Bluetooth 5.0
3-cell
Security
Trusted Platform Module (TPM 2.0) Security Chip, smart card reader
30.57 cm x 20.75 cm x 1.93 cm
1.42 kg
Pricing Type
Build To Stock (BTS)
Bundled Services
1 Year Basic Onsite
Operating System
Windows 10 Pro 64-bit Edition - Multilingual User Interface (MUI)
Processor / Chipset
CPU
Max Turbo Speed
3.9 GHz
Number of Cores
Quad-Core
Cache
6 MB
64-bit Computing
Intel Turbo Boost Technology 2.0
RAM
8 GB (1 x 8 GB)
Max RAM Supported
32 GB
DDR4 SDRAM - non-ECC
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
256 GB SSD M.2 2280 PCIe - NVM Express (NVMe), Class 40
Display
13.33" - IPS
Touchscreen
Resolution
1920 x 1080 (Full HD)
V-Sync Rate at Max Res.
60 Hz
Widescreen
Pixel Density (ppi)
166
Image Aspect Ratio
16:9
Image Brightness
255 cd/m²
Colour Gamut
72% NTSC
Anti-reflective, ±80° horizontal viewing angle, ±80° vertical viewing angle, glass cover, 72% NTSC colour gamut
Audio & Video
Graphics Processor
Memory Allocation Technology
Shared Video Memory (UMA)
Camera
Yes - HD
Image Sensor Type
CMOS
Video Resolutions
1280 x 720
Frame Rate
30 frames per second
Camera Features
Fixed focus, 78.6 degrees, RGB camera
Sound
Stereo speakers, dual array microphone
Codec
Realtek ALC3254
High Definition Audio
Audio Features
Output: MaxxAudio Pro
Input
Keyboard, digitizer, touchpad, digital pen
Keyboard Backlight
Active pen support
Communications
Wireless
Wireless Controller
Intel Wireless-AC 9560
3-cell Lithium Ion
42 Wh
AC Adapter
Input
Output
65 Watt, 19.5 V, 3.34 A
Connections & Expansion
USB 3.1 Gen 1 , USB-C 3.1 Gen 1 (PowerShare) , Headphone/microphone combo jack , HDMI , USB-C 3.1 Gen 2 (supports DisplayPort Alt Mode)
Memory Card Reader
Yes (microSD)
Security
ExpressCharge
Theft/Intrusion Protection
Security Slot Type
Noble Wedge security slot
Power adapter
Pricing Type
1.42 kg
Bundled Services
1 Year Basic Onsite
35 °C
10 - 80% (non-condensing)
Shock Tolerance (operating)
140 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
160 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.66 g @ RMS (random)
Vibration Tolerance (non-operating)
1.3 g @ RMS (random)
