Dell Latitude 3590 i5 7200U 4GB 500GB 15.6" W10P
Quicklinx: F34QWS00 Mfr#: NK4HF
Display Size: 15.6in
Processor Model: I5-7200U
Operating System: Windows 10 Pro 64-bit Edition
Installed Memory: 4GB, 4GB
Hard Drive Capacity: 500GB
  • Core i5
  • IEEE 802.11n
Hurry, only 1 left in stock!
£497.60 ex VAT
£597.12 inc VAT
An easily managed laptop with superior security features critical for small and growing businesses, all in a durable, reliable and sleek design.
  • Office everywhere
    Latitude's superior security, versatility and accessories empower the way you work because your success relies on the ability to maintain office-level productivity, wherever your job takes you.
  • Enhanced data protection
    Data security is key in protecting your business and employees. Endpoint security, advanced user authentication and data encryption software all work cohesively to safeguard your data from threats and hacks.
  • Outstanding reliability
    Your Latitude 3590 features a durable, built-to-last chassis that has undergone extensive testing to ensure your system can withstand real-world conditions.
  • Power your workday
    Fast processors deliver the power you need for optimal productivity. The superior memory boosts transfer rates while using less voltage, making your Latitude run faster and more efficiently.
Dell Latitude 3590 - 15.6" - Core i5 7200U - 4 GB RAM - 500 GB HDD
Notebook
Operating System
Win 10 Pro 64-bit - Multilingual User Interface (MUI)
Intel Core i5 (7th Gen) 7200U / 2.5 GHz (3.1 GHz) / 3 MB Cache
4 GB DDR4 (1 x 4 GB)
Storage
500 GB HDD / 7200 rpm
Optical Drive
No optical drive
Display
15.6" WLED 1366 x 768 / HD
Graphics
Intel HD Graphics 620
Numeric Keypad
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.1, Gigabit Ethernet
4-cell
Security
Trusted Platform Module (TPM 2.0) Security Chip
38 cm x 25.8 cm x 2.27 cm
2.02 kg
Pricing Type
Build To Stock (BTS)
Limited warranty - 1 year - on-site
Notebook
Operating System
Windows 10 Pro 64-bit Edition - Multilingual User Interface (MUI)
Processor / Chipset
CPU
Max Turbo Speed
3.1 GHz
Number of Cores
Dual-Core
Cache
3 MB
64-bit Computing
Intel Turbo Boost Technology 2.0
RAM
4 GB (1 x 4 GB)
Max RAM Supported
32 GB
DDR4 SDRAM
Speed
2133 MHz - 2133 MHz
Rated Speed
2133 MHz
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
500 GB HDD SATA / 7200 rpm
Display
15.6"
LCD Backlight Technology
WLED backlight
Resolution
1366 x 768 (HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
220 cd/m²
Anti-glare
Audio & Video
Graphics Processor
Memory Allocation Technology
Shared Video Memory (UMA)
Camera
Yes - HD
Resolution
0.92 Megapixel
Image Sensor Type
CMOS
Video Resolutions
1280x720
Frame Rate
30 frames per second
Camera Features
Fixed focus
Sound
Stereo speakers, dual array microphone
Codec
Realtek ALC3246
High Definition Audio
Audio Features
MaxxAudio Pro
Input
Keyboard, touchpad
Numeric Keypad
Communications
Wireless
Wireless Controller
Qualcomm QCA61x4A - M.2 2230
Network Interface
Gigabit Ethernet
4-cell lithium polymer
56 Wh
AC Adapter
Input
Output
65 Watt, 19.5 V, 3.34 A
Connections & Expansion
USB 2.0 , USB-C 3.1 Gen 1 (PowerShare) , USB-C/DisplayPort (Power Delivery) , HDMI , VGA , LAN , Headphone/microphone combo jack
Memory Card Reader
Yes (SD Card)
Software
Software Included
Microsoft Office (Trial), McAfee (30 days trial)
Security
ExpressCharge, MU-MIMO technology
Theft/Intrusion Protection
Security Slot Type
Noble Wedge security slot
Power adapter
FIPS 140-2
Pricing Type
2.02 kg
35 °C
10 - 90%
Software applications
Dell Latitude 3590 i5 7200U 4GB 500GB 15.6 Bundle deal on Dell Latitude 3590 i5 7200U 4GB 500GB 15.6" W10P
£682.82
saving £8.33
£596.77
Optical Storage: None
Graphics: Intel HD Graphics 620
Hard Drive Type: HDD
Brand: Dell
Price Range Ex VAT: 300 - 500
