Dell Latitude 3590 Core i5-7200U 8GB 256GB SSD 15.6" Windows 10 Pro
Quicklinx: DC79WS00 Mfr#: NKDDW
  • Core i5
  • IEEE 802.11n
An easily managed laptop with superior security features critical for small and growing businesses, all in a durable, reliable and sleek design.
  • Office everywhere
    Latitude's superior security, versatility and accessories empower the way you work because your success relies on the ability to maintain office-level productivity, wherever your job takes you.
  • Enhanced data protection
    Data security is key in protecting your business and employees. Endpoint security, advanced user authentication and data encryption software all work cohesively to safeguard your data from threats and hacks.
  • Outstanding reliability
    Your Latitude 3590 features a durable, built-to-last chassis that has undergone extensive testing to ensure your system can withstand real-world conditions.
  • Power your workday
    Fast processors deliver the power you need for optimal productivity. The superior memory boosts transfer rates while using less voltage, making your Latitude run faster and more efficiently.
Dell Latitude 3590 - 15.6" - Core i5 7200U - 8 GB RAM - 256 GB SSD
Notebook
Operating System
Win 10 Pro 64-bit
Intel Core i5 (7th Gen) 7200U / 2.5 GHz (3.1 GHz) / 3 MB Cache
8 GB DDR4 (1 x 8 GB)
Storage
256 GB - M.2 2280 SSD
Optical Drive
No optical drive
Display
15.6" 1920 x 1080 / Full HD
Graphics
Intel HD Graphics 620
Keyboard Backlight
Numeric Keypad
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.1, Gigabit Ethernet
4-cell
Security
Trusted Platform Module (TPM 2.0) Security Chip
38 cm x 25.8 cm x 2.27 cm
2.02 kg
Pricing Type
Build To Stock (BTS)
Limited warranty - 1 year - response time: next business day
Notebook
Operating System
Windows 10 Pro 64-bit Edition
Processor / Chipset
CPU
Max Turbo Speed
3.1 GHz
Number of Cores
Dual-Core
Cache
3 MB
64-bit Computing
Intel Turbo Boost Technology 2.0
RAM
8 GB (1 x 8 GB)
Max RAM Supported
32 GB
DDR4 SDRAM
Speed
2133 MHz - 2133 MHz
Rated Speed
2133 MHz
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
256 GB SSD - (M.2 2280) SATA
Display
15.6"
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Brightness
220 cd/m²
Anti-glare, 141 ppi
Audio & Video
Graphics Processor
Memory Allocation Technology
Shared Video Memory (UMA)
Camera
Yes - HD
Resolution
0.92 Megapixel
Image Sensor Type
CMOS
Video Resolutions
1280x720
Frame Rate
30 frames per second
Camera Features
720p HD movie recording
Sound
Stereo speakers, dual array microphone
Codec
Realtek ALC3246
High Definition Audio
Audio Features
MaxxAudio Pro
Input
Keyboard, touchpad
Keyboard Backlight
Numeric Keypad
Communications
Wireless
Wireless Controller
Atheros QCA61x4A - M.2 2230
Network Interface
Gigabit Ethernet
Ethernet Controller
Realtek RTL8111HSD
Miracast
4-cell lithium polymer
56 Wh
AC Adapter
Input
Output
65 Watt, 19.5 V, 3.34 A
Connections & Expansion
Headphone/microphone combo jack , USB 3.1 Gen 1 (PowerShare) , USB 2.0 , HDMI , VGA , USB-C/DisplayPort (Power Delivery) , LAN
Memory Card Reader
Yes (SD Card)
Software
Software Included
Microsoft Office (Trial), McAfee (30 days trial)
Security
ExpressCharge, MU-MIMO technology
Theft/Intrusion Protection
Security Slot Type
Noble Wedge security slot
Power adapter
FIPS 140-2, TCG Certified
Pricing Type
2.02 kg
35 °C
10 - 90%
