An easily managed 15-inch laptop with top security features critical for small and growing businesses, all in a durable, reliable design.
Enhanced data protection: Data security is key in protecting your business and employees. Dell Data Protection is a suite of security software programs offered on each Latitude 3000 Series system. Endpoint security, advanced user authentication and data encryption software all work cohesively to safeguard your data from threats and hacks.
Safely communicate: Your Latitude 3580 comes TPM2.0 TCG certified and FIPS-140-2 certified, and uses hardware-based cryptography for the most secure communication.
Easy to manage: Dell Client Command Suite comes with a set of automation tools that assists in device monitoring, deploying images, updating and more, to maximize your hardware and software investments and save time.
Outstanding reliability: Your Latitude 15 features a durable, built-to-last chassis that has undergone extensive military-grade MIL-STD 810G testing to ensure your system can withstand real-world conditions.
Power your workday: 7th Gen Intel Core i7 processors deliver the power you need for optimum productivity. The DDR4 memory boosts transfer rates while using less voltage, making your Latitude run faster and more efficiently.
Flexible connectivity: VGA, HDMI, RJ-45 and USB Type A ports let you go dongle free and accommodate your legacy connections.
Work together with ease: The extended 180-degree hinge is smooth, flexible and durable so you can collaborate effectively.
Take your work with you: At less than 24mm thin and weighing less than 2kg, your Latitude is travel ready.
Your Latitude 15 features a durable, built-to-last chassis, that ensures your system can withstand real-world conditions. -
VGA, HDMI, RJ-45 and USB Type A ports let you go dongle-free and accommodate your legacy connections. -
The extended 180-degree hinge is smooth, flexible and durable, so you can collaborate effectively.
- Dell Latitude 3580 - 15.6" - Intel Core i5 - 6200U - 4 GB RAM - 500 GB HDD
- Product Type
- Notebook
- Operating System
- Win 10 Pro 64-bit
- Processor
- Intel Core i5 (6th Gen) - 6200U / 2.3 GHz, up to 2.8 GHz / 3 MB Cache
- Memory
- 4 GB DDR4 (1 x 4 GB)
- Storage
- 500 GB HDD / 7200 rpm
- Display
- 15.6" 1366 x 768 / HD
- Graphics
- Intel HD Graphics 520
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.1, Gigabit Ethernet
- Battery
- 4-cell
- Security
- Trusted Platform Module (TPM 2.0) Security Chip
- Black
- 37.9 cm x 25.5 cm x 2.33 cm
- 1.95 kg
- Pricing Type
- Build To Stock (BTS)
- Environmental Standards
- - EPEAT Climate+
- Limited warranty - 1 year - response time: next business day
- Product Type
- Notebook
- Operating System
- Windows 10 Pro 64-bit Edition
Processor / Chipset
- CPU
- Intel Core i5 (6th Gen) 6200U / 2.3 GHz
- Max Turbo Speed
- 2.8 GHz
- Number of Cores
- Dual-Core
- Cache
- 3 MB
- 64-bit Computing
- Intel Turbo Boost Technology 2.0
- RAM
- 4 GB (1 x 4 GB)
- Max RAM Supported
- 32 GB
- Technology
- DDR4 SDRAM
- Speed
- 2133 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 500 GB HDD SATA / 7200 rpm
Display
- 15.6"
- Resolution
- 1366 x 768 (HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 200 cd/m²
- Anti-glare
Audio & Video
- Graphics Processor
- Camera
- Yes - 1280 x 720
- Resolution
- 0.92 Megapixel
- Sound
- Stereo speakers, microphone
- Codec
- Realtek ALC3246
- High Definition Audio
Input
- Keyboard, touchpad
Communications
- Wireless
- Wireless Controller
- Dell Wireless 1820
- Network Interface
- Gigabit Ethernet
- Technology
- 4-cell Lithium Ion
- Capacity
- 56 Wh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 65 Watt, 19.5 V, 3.34 A
Connections & Expansion
- Interfaces Details
- LAN , USB 3.1 Gen 1 , USB 2.0 , USB 3.1 Gen 1 (PowerShare) , HDMI , Headphone/microphone combo jack , VGA
- Memory Card Reader
- Yes (SD Card)
Software
- Software Included
- Microsoft Office (Trial)
- Black
- Security
- Theft/Intrusion Protection
- Security Slot Type
- Noble Wedge security slot
- Included Accessories
- Power adapter
- Pricing Type
- 1.95 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Climate+
- 0 °C
- 35 °C
- 10 - 90% (non-condensing)
