Performance you can rely on. The essential business-class features and options that deliver the performance small and growing businesses need.
Work from anywhere with all-day battery life. And with the easy access bottom latch, replace your battery on the go with no tools required.
Only Dell offers comprehensive encryption, advanced authentication, and leading-edge malware prevention from a single source. Dell Data Protection , Encryption protects your data across all endpoints, external media, and public cloud storage. One-touch, preset templates enable compliance right out of the box allowing you to avoid costly fines if a device is compromised, lost, or stolen. Dell Data Protection , Security Tools offers advanced authentication options to help keep unauthorized users out of your data. Dell Data Protection , Protected Workspace takes a new approach to malware prevention by guarding you and your data from all suspicious content. If an attack occurs, the malware is sealed off and a safe environment is restored in only 20 seconds.
Full Dell management capabilities to allow you to make the most of your hardware investment with free Dell Client Command Suite tools to allow flexible and automated BIOS or system configurations. Factory Installed with Dell Command , Update allowing users to easily identify and download updates. Dell Command , Power Manager is also factory installed for easy customization of battery power options, plus with Battery Extender Mode users can prolong battery life with one-click, reducing energy-intense hardware processes.
Stylish and powerful
The sophisticated Latitude 15 3000 series features powerful processors for power and productivity. -
Power on the go
Work from anywhere with all-day battery life. And with the easy access bottom latch, replace your battery on the go with no tools required. -
Plenty of ports
Modern performance is never far away with all the ports you need, including USB 3.0 and 2.0, RJ-45, HDMI and VGA ports.
- Dell Latitude 3570 - 15.6" - Intel Core i5 - 6200U - 4 GB RAM - 500 GB HDD
- Product Type
- Notebook
- Operating System
- Win 7 Pro 64-bit + Windows 10 Pro 64-bit Licence - Multilingual User Interface (MUI)
- Processor
- Intel Core i5 (6th Gen) - 6200U / 2.3 GHz, up to 2.8 GHz / 3 MB Cache
- Memory
- 4 GB DDR3L (1 x 4 GB)
- Storage
- 500 GB HDD / 7200 rpm
- Display
- 15.6" WLED 1366 x 768 / HD
- Graphics
- Intel HD Graphics 520
- Integrated Webcam
- Networking
- 802.11a/b/g/n, Bluetooth 4.1, Gigabit Ethernet
- Battery
- 6-cell
- Security
- Trusted Platform Module (TPM 1.2) Security Chip
- Black
- 38 cm x 26 cm x 2.325 cm
- 2.06 kg
- Pricing Type
- Build To Stock (BTS)
- Environmental Standards
- - ENERGY STAR Qualified EPEAT Climate+
- Limited warranty - 1 year - response time: next business day
- Product Type
- Notebook
- Operating System
- Microsoft Windows 7 Professional 64-bit Edition + Windows 10 Pro 64-bit Licence - Multilingual User Interface (MUI)
Processor / Chipset
- CPU
- Intel Core i5 (6th Gen) 6200U / 2.3 GHz
- Max Turbo Speed
- 2.8 GHz
- Number of Cores
- Dual-Core
- Cache
- L3 - 3 MB
- 64-bit Computing
- Intel Turbo Boost Technology 2.0
- RAM
- 4 GB (1 x 4 GB)
- Max RAM Supported
- 16 GB
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz
- Form Factor
- SO-DIMM 204-pin
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 500 GB HDD SATA / 7200 rpm
Display
- 15.6"
- LCD Backlight Technology
- WLED backlight
- Resolution
- 1366 x 768 (HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Anti-glare
Audio & Video
- Graphics Processor
- Memory Allocation Technology
- Shared Video Memory (UMA)
- Camera
- Yes - HD
- Sound
- Speakers, microphone
Input
- Keyboard, touchpad
Communications
- Wireless
- Wireless Controller
- Dell Wireless 1802
- Network Interface
- Gigabit Ethernet
- Technology
- 6-cell Lithium Ion
- Capacity
- 65 Wh
Connections & Expansion
- Interfaces Details
- LAN , 2 x USB 3.0 , USB 2.0 , VGA , HDMI , Headphone/microphone combo jack
- Memory Card Reader
- Yes (SD Card)
Software
- Software Included
- Microsoft Office (Trial), Windows 10 Pro 64-bit recovery DVD
- Black
- Security
- Included Accessories
- Power adapter
- FIPS 140-2
- Pricing Type
- 2.06 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Climate+
- ENERGY STAR Certified
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.07 |
