Dell Latitude 3560 Intel Core i3-5005U 4GB 500GB 15.6" Windows 7 Pro
Quicklinx: BY3JWS00 Mfr#: 3560-1683
  • Core i3
  • Microsoft Windows 7 Professional 64-bit Edition
  • IEEE 802.11n
For consistently reliable performance whether you’re at work or on the go, the Dell Latitude 3560 has it all. Take advantage of the day-long battery life so you can work unplugged anywhere.
You can also enjoy fast and easy access to data and make swift data transfers as the Dell 3560 comes with USB 2.0 and 3.0, HDMI and VGA ports for all of your business needs.
Built to last, the Latitude 15 3000 Series feature a rugged chassis, enabling your laptop to withstand wear and tear.
The Latitude 3560 is powered by an Intel Core i3 processor and comes with 500GB storage so you’ll have plenty of space for your largest files, without compromising on speed and performance.
At just over 2kg in weight, it makes the ideal companion on your travels for both work and play.
Its integrated webcam and built-in microphone and speakers allow you to stay in touch with your business contacts even when you’re not in the office. Enjoy HD resolution for precise and clear images.
With Dell Data Protection, you can maintain the highest security for your business laptop, preventing unwanted users from accessing your most sensitive files.
  • Reliable performance
    Do not compromise on performance. The Latitude delivers excellent productivity for content creation and consumption. Power through challenging jobs and easily multitask with the efficient processor.
  • Durable design
    Whether you're an office or mobile professional, you can count on your Latitude to stand up to the demands of your schedule. Work and travel without worry, thanks to durable chassis. Your easy-to-carry Latitude is thin and comes with a sleek aluminum finish.
Dell Latitude 3560 - 15.6" - Intel Core i3 - 5005U - 4 GB RAM - 500 GB HDD
Notebook
Operating System
Win 7 Pro 64-bit + Windows 10 Pro 64-bit Licence - Multilingual User Interface (MUI)
Intel Core i3 (5th Gen) - 5005U / 2 GHz / 3 MB Cache
4 GB DDR3L (1 x 4 GB)
Storage
500 GB HDD / 7200 rpm
Display
15.6" WLED 1366 x 768 / HD
Graphics
Intel HD Graphics 5500
Integrated Webcam
802.11a/b/g/n, Bluetooth 4.1, Gigabit Ethernet
4-cell
Security
Trusted Platform Module (TPM 1.2 and TPM 2.0)
38 cm x 26 cm x 2.325 cm
2.06 kg
Pricing Type
Build To Stock (BTS)
Environmental Standards
- ENERGY STAR Qualified EPEAT Climate+
Limited warranty - 1 year - pick-up and return
Bundled Services
1 Year Dell Collect and Return Service
Notebook
Operating System
Microsoft Windows 7 Professional 64-bit Edition + Windows 10 Pro 64-bit Licence - Multilingual User Interface (MUI)
Processor / Chipset
CPU
Intel Core i3 (5th Gen) 5005U / 2 GHz
Number of Cores
Dual-Core
Cache
L3 - 3 MB
64-bit Computing
RAM
4 GB (1 x 4 GB)
Max RAM Supported
16 GB
DDR3L SDRAM
Speed
1600 MHz
SO-DIMM 204-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
500 GB HDD SATA / 7200 rpm
Display
15.6"
LCD Backlight Technology
WLED backlight
Resolution
1366 x 768 (HD)
Widescreen
Image Aspect Ratio
16:9
Anti-glare
Audio & Video
Graphics Processor
Camera
Yes - HD
Sound
Speakers, microphone
Input
Keyboard, touchpad
Precision touchpad
Communications
Wireless
Wireless Controller
Dell Wireless 1802
Network Interface
Gigabit Ethernet
4-cell Lithium Ion
40 Wh
AC Adapter
Input
Output
65 Watt
Connections & Expansion
Interfaces Details
Headphone output , 2 x USB 3.0 , USB 2.0 , VGA , LAN , HDMI
Memory Card Reader
Yes (SD Card)
Software
Software Included
Microsoft Office (Trial), Windows 10 Pro 64-bit recovery DVD
Security
Security lock slot (cable lock sold separately), Free Fall Sensor, Dell Data Protection, ExpressCharge
Power adapter
FIPS 140-2, TCG Certified
Pricing Type
2.06 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Climate+
ENERGY STAR Certified
Bundled Services
BY3J C2G 2m USB 2.0 A/B Cable - Black In Stock £4.20
BY3J C2G 5m USB 2.0 A/B Cable - Black In Stock £5.07
