For consistently reliable performance whether you’re at work or on the go, the Dell Latitude 3560 has it all. Take advantage of the day-long battery life so you can work unplugged anywhere.
You can also enjoy fast and easy access to data and make swift data transfers as the Dell 3560 comes with USB 2.0 and 3.0, HDMI and VGA ports for all of your business needs.
Built to last, the Latitude 15 3000 Series feature a rugged chassis, enabling your laptop to withstand wear and tear.
The Latitude 3560 is powered by an Intel Core i3 processor and comes with 500GB storage so you’ll have plenty of space for your largest files, without compromising on speed and performance.
At just over 2kg in weight, it makes the ideal companion on your travels for both work and play.
Its integrated webcam and built-in microphone and speakers allow you to stay in touch with your business contacts even when you’re not in the office. Enjoy HD resolution for precise and clear images.
With Dell Data Protection, you can maintain the highest security for your business laptop, preventing unwanted users from accessing your most sensitive files.
Reliable performance
Do not compromise on performance. The Latitude delivers excellent productivity for content creation and consumption. Power through challenging jobs and easily multitask with the efficient processor. -
Durable design
Whether you're an office or mobile professional, you can count on your Latitude to stand up to the demands of your schedule. Work and travel without worry, thanks to durable chassis. Your easy-to-carry Latitude is thin and comes with a sleek aluminum finish.
- Dell Latitude 3560 - 15.6" - Intel Core i3 - 5005U - 4 GB RAM - 500 GB HDD
- Product Type
- Notebook
- Operating System
- Win 7 Pro 64-bit + Windows 10 Pro 64-bit Licence - Multilingual User Interface (MUI)
- Processor
- Intel Core i3 (5th Gen) - 5005U / 2 GHz / 3 MB Cache
- Memory
- 4 GB DDR3L (1 x 4 GB)
- Storage
- 500 GB HDD / 7200 rpm
- Display
- 15.6" WLED 1366 x 768 / HD
- Graphics
- Intel HD Graphics 5500
- Integrated Webcam
- Networking
- 802.11a/b/g/n, Bluetooth 4.1, Gigabit Ethernet
- Battery
- 4-cell
- Security
- Trusted Platform Module (TPM 1.2 and TPM 2.0)
- Black
- 38 cm x 26 cm x 2.325 cm
- 2.06 kg
- Pricing Type
- Build To Stock (BTS)
- Environmental Standards
- - ENERGY STAR Qualified EPEAT Climate+
- Limited warranty - 1 year - pick-up and return
- Bundled Services
- 1 Year Dell Collect and Return Service
- Product Type
- Notebook
- Operating System
- Microsoft Windows 7 Professional 64-bit Edition + Windows 10 Pro 64-bit Licence - Multilingual User Interface (MUI)
Processor / Chipset
- CPU
- Intel Core i3 (5th Gen) 5005U / 2 GHz
- Number of Cores
- Dual-Core
- Cache
- L3 - 3 MB
- 64-bit Computing
- RAM
- 4 GB (1 x 4 GB)
- Max RAM Supported
- 16 GB
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz
- Form Factor
- SO-DIMM 204-pin
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 500 GB HDD SATA / 7200 rpm
Display
- 15.6"
- LCD Backlight Technology
- WLED backlight
- Resolution
- 1366 x 768 (HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Anti-glare
Audio & Video
- Graphics Processor
- Camera
- Yes - HD
- Sound
- Speakers, microphone
Input
- Keyboard, touchpad
- Precision touchpad
Communications
- Wireless
- Wireless Controller
- Dell Wireless 1802
- Network Interface
- Gigabit Ethernet
- Technology
- 4-cell Lithium Ion
- Capacity
- 40 Wh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 65 Watt
Connections & Expansion
- Interfaces Details
- Headphone output , 2 x USB 3.0 , USB 2.0 , VGA , LAN , HDMI
- Memory Card Reader
- Yes (SD Card)
Software
- Software Included
- Microsoft Office (Trial), Windows 10 Pro 64-bit recovery DVD
- Black
- Security
- Security lock slot (cable lock sold separately), Free Fall Sensor, Dell Data Protection, ExpressCharge
- Included Accessories
- Power adapter
- FIPS 140-2, TCG Certified
- Pricing Type
- 2.06 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Climate+
- ENERGY STAR Certified
- Bundled Services
