This small, sleek laptop with connectivity and management features is ideal for growing businesses.
Legacy ports
Connecting to peripherals is streamlined and simple with a maximum amount of port options, including HDMI, USB 3.1 and USB Type-C. -
All-day power
Extended battery life handles your entire workday and then some. -
Expand your office
The Latitude 3500 enhances your workflow anywhere and looks good while doing it. The edges look elegant and modern in any setting. -
Outstanding reliability
Your Latitude 3500 features a durable, built-to-last chassis that has undergone extensive testing to ensure your system can withstand real-world conditions.
- Dell Latitude 3500 - 15.6" - Core i5 8265U - 8 GB RAM - 256 GB SSD
- Product Type
- Notebook
- Operating System
- Win 10 Pro 64-bit
- Processor
- Intel Core i5 (8th Gen) 8265U / 1.6 GHz (3.9 GHz) / 6 MB Cache
- Memory
- 8 GB DDR4 (1 x 8 GB)
- Storage
- 256 GB SSD - NVMe, Class 35
- Display
- 15.6" 1920 x 1080 / Full HD @ 60 Hz
- Graphics
- Intel UHD Graphics 620
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac Wave 2, Bluetooth 5.0, Gigabit Ethernet
- Battery
- 4-cell
- Security
- Trusted Platform Module (TPM 2.0) Security Chip
- Black
- 37.866 cm x 25.52 cm x 1.8 cm
- 2.15 kg
- Pricing Type
- Build To Stock (BTS)
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - 1 year - on-site
- Product Type
- Notebook
- Operating System
- Windows 10 Pro 64-bit Edition
Processor / Chipset
- CPU
- Max Turbo Speed
- 3.9 GHz
- Number of Cores
- Quad-Core
- Cache
- 6 MB
- 64-bit Computing
- Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
- RAM
- 8 GB (1 x 8 GB)
- Max RAM Supported
- 64 GB
- Technology
- DDR4 SDRAM - non-ECC
- Speed
- 2400 MHz
- Rated Speed
- 2666 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 256 GB SSD M.2 PCIe - NVM Express (NVMe), Class 35
Display
- 15.6"
- Resolution
- 1920 x 1080 (Full HD)
- V-Sync Rate at Max Res.
- 60 Hz
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 220 cd/m²
- Anti-glare, WideView, ±40° horizontal viewing angle, +10/-30 vertical viewing angle
Audio & Video
- Graphics Processor
- Memory Allocation Technology
- Shared Video Memory (UMA)
- Camera
- Yes - 1280 x 720
- Resolution
- 0.92 Megapixel
- Video Resolutions
- 1280 x 720
- Frame Rate
- 60 frames per second
- Camera Features
- 86.7 degrees
- Sound
- Stereo speakers, dual array microphone
- Codec
- Realtek ALC3204
Input
- Keyboard, touchpad
- Multi-touch touchpad
Communications
- Wireless
- Wireless Controller
- Intel Wireless-AC 9560
- Network Interface
- Gigabit Ethernet
- Ethernet Controller
- Realtek RTL8111H
- Wake-on-LAN (WOL)
- Technology
- 4-cell Lithium Ion
- Capacity
- 56 Wh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 65 Watt, 19.5 V
Connections & Expansion
- USB 3.1 Gen 1 , USB 3.1 Gen 1 (PowerShare) , USB-C 3.1 Gen 1 (supports DisplayPort Alt Mode) (Power Delivery) , USB 2.0 , HDMI , VGA , LAN , Headphone/microphone combo jack
Software
- Software Included
- Microsoft Office (Trial), Dell Precision Optimizer
- Black
- Security
- ExpressCharge, noise reducing microphone
- Theft/Intrusion Protection
- Security Slot Type
- Noble Wedge security slot
- Included Accessories
- Power adapter
- Pricing Type
- 2.15 kg
Sustainability Information
- ENERGY STAR Certified
- 0 °C
- 35 °C
- 10 - 80% (non-condensing)
- Shock Tolerance (operating)
- 105 g @ 2 ms half-sine pulse
- Shock Tolerance (non-operating)
- 40 g @ 2 ms half-sine pulse
- Vibration Tolerance (operating)
- 0.26 g @ RMS (random)
- Vibration Tolerance (non-operating)
- 1.37 g @ RMS (random)
