Dell Latitude 3500 Intel Core i5-8265U 4GB 1TB 15.6" Windows 10 Professional 64-bit
Quicklinx: FC45WS00 Mfr#: 4VTY9
Display Size: 15.6in
Processor Model: I5-8265U
Operating System: Windows 10 Pro 64-bit Edition
Installed Memory: 4GB, 4GB
Hard Drive Capacity: 1TB
  • Core i5
  • IEEE 802.11n
£565.00 ex VAT
£678.00 inc VAT
This small, sleek laptop with connectivity and management features is ideal for growing businesses.
  • Legacy ports
    Connecting to peripherals is streamlined and simple with a maximum amount of port options, including HDMI, USB 3.1 and USB Type-C.
  • All-day power
    Extended battery life handles your entire workday and then some.
  • Expand your office
    The Latitude 3500 enhances your workflow anywhere and looks good while doing it. The edges look elegant and modern in any setting.
  • Outstanding reliability
    Your Latitude 3500 features a durable, built-to-last chassis that has undergone extensive testing to ensure your system can withstand real-world conditions.
Dell Latitude 3500 - 15.6" - Core i5 8265U - 4 GB RAM - 1 TB HDD
Notebook
Operating System
Win 10 Pro 64-bit
Intel Core i5 (8th Gen) 8265U / 1.6 GHz (3.9 GHz) / 6 MB Cache
4 GB DDR4 (1 x 4 GB)
Storage
1 TB HDD / 5400 rpm
Optical Drive
No optical drive
Display
15.6" 1920 x 1080 / Full HD @ 60 Hz
Graphics
Intel UHD Graphics 620
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac Wave 2, Bluetooth 5.0, Gigabit Ethernet
4-cell
Security
Trusted Platform Module (TPM 2.0) Security Chip
37.866 cm x 25.52 cm x 1.8 cm
2.15 kg
Pricing Type
Build To Stock (BTS)
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 1 year - on-site
Notebook
Operating System
Processor / Chipset
CPU
Max Turbo Speed
3.9 GHz
Number of Cores
Quad-Core
Cache
6 MB
64-bit Computing
Intel Turbo Boost Technology 2.0
RAM
4 GB (1 x 4 GB)
Max RAM Supported
64 GB
DDR4 SDRAM - non-ECC
Speed
2400 MHz
Rated Speed
2666 MHz
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
1 TB HDD SATA / 5400 rpm
Display
15.6"
Resolution
1920 x 1080 (Full HD)
V-Sync Rate at Max Res.
60 Hz
Widescreen
Image Brightness
220 cd/m²
Bezel Type
Raised
Anti-glare, WideView, ±40° horizontal viewing angle, +10/-30 vertical viewing angle
Audio & Video
Graphics Processor
Memory Allocation Technology
Shared Video Memory (UMA)
Camera
Yes - 1280 x 720
Resolution
0.92 Megapixel
Video Resolutions
1280 x 720
Frame Rate
60 frames per second
Camera Features
86.7 degrees
Sound
Stereo speakers, dual array microphone
Codec
Realtek ALC3204
Input
Keyboard, touchpad
Keyboard Backlight
Multi-touch touchpad
Communications
Wireless
Wireless Controller
Intel Wireless-AC 9560
Network Interface
Gigabit Ethernet
Ethernet Controller
Realtek RTL8111H
Wake-on-LAN (WOL)
4-cell Lithium Ion
56 Wh
AC Adapter
Input
Output
65 Watt, 19.5 V
Connections & Expansion
USB 3.1 Gen 1 , USB 3.1 Gen 1 (PowerShare) , USB-C 3.1 Gen 1/DisplayPort (Power Delivery) , USB 2.0 , HDMI , VGA , LAN , Headphone/microphone combo jack
Software
Software Included
Microsoft Office (Trial), Dell Precision Optimizer
Security
ExpressCharge, noise reducing microphone
Theft/Intrusion Protection
Security Slot Type
Noble Wedge security slot
Power adapter
Pricing Type
2.15 kg
ENERGY STAR Certified
35 °C
10 - 80% (non-condensing)
Shock Tolerance (operating)
105 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
40 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.26 g @ RMS (random)
Vibration Tolerance (non-operating)
1.37 g @ RMS (random)
Get more from your purchase from one of our essential accessories
FC45 Dicota Privacy filter 2-Way for Laptop 15.6" Wide (16:9), self-adhesive In Stock £44.69
Optical Storage: None
Graphics: Intel UHD Graphics 620
Hard Drive Type: HDD
Brand: Dell
Price Range Ex VAT: 500 - 750
