An easily managed 14" laptop with top security features critical for small and growing businesses, all in a durable, reliable and sleek design.
Office everywhere
Latitude's superior security, versatility empower the way you work because your success relies on the ability to maintain office-level productivity, wherever your job takes you. -
Safely communicate
Your Latitude 3490 comes TPM2.0 TCG certified and FIPS-140-2 certified, and uses hardware-based cryptography for the most secure communication. -
Flexible connectivity
VGA, HDMI, RJ-45, USB Type-A and USB Type-C ports let you go dongle free and accommodate your legacy connections. -
Work together with ease
The extended 175 degree hinge is smooth, flexible and durable so you can collaborate effectively. -
Take your work with you
At 0.82" (21 mm) thin and weighing in at 3.79 lbs (1.72 kg), your Latitude laptop is travel ready.
- Dell Latitude 3490 - 14" - Core i5 7200U - 8 GB RAM - 256 GB SSD
- Product Type
- Notebook
- Operating System
- Win 10 Pro 64-bit
- Processor
- Intel Core i5 (7th Gen) 7200U / 2.5 GHz (3.1 GHz) / 3 MB Cache
- Memory
- 8 GB DDR4 (1 x 8 GB)
- Storage
- 256 GB SSD
- Display
- 14" 1920 x 1080 / Full HD - 157 ppi
- Graphics
- Intel HD Graphics 620
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.1, Gigabit Ethernet
- Battery
- 4-cell
- Security
- Trusted Platform Module (TPM 2.0) Security Chip
- Black
- 33.9 cm x 24.19 cm x 2.1 cm
- 1.72 kg
- Pricing Type
- Build To Stock (BTS)
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - 1 year - response time: next business day
- Product Type
- Notebook
- Operating System
- Windows 10 Pro 64-bit Edition
Processor / Chipset
- CPU
- Max Turbo Speed
- 3.1 GHz
- Number of Cores
- Dual-Core
- Cache
- 3 MB
- 64-bit Computing
- Intel Turbo Boost Technology 2.0
- RAM
- 8 GB (1 x 8 GB)
- Max RAM Supported
- 32 GB
- Technology
- DDR4 SDRAM
- Speed
- 2133 MHz
- Rated Speed
- 2133 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 256 GB SSD M.2 2280 SATA
Display
- 14"
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Pixel Density (ppi)
- 157
- Image Brightness
- 220 cd/m²
- Anti-glare, Wide Viewing Angle
Audio & Video
- Graphics Processor
- Memory Allocation Technology
- Shared Video Memory (UMA)
- Camera
- Yes - 1280 x 720
- Resolution
- 0.92 Megapixel
- Image Sensor Type
- CMOS
- Video Resolutions
- 1280 x 720
- Frame Rate
- 30 frames per second
- Camera Features
- Fixed focus
- Sound
- Stereo speakers, dual array microphone
- Codec
- Realtek ALC3246
- High Definition Audio
- Audio Features
- Output: MaxxAudio Pro
Input
- Keyboard, touchpad
Communications
- Wireless
- Wireless Controller
- Atheros QCA61x4A - M.2 2230
- Network Interface
- Gigabit Ethernet
- Ethernet Controller
- Realtek RTL8111HSD
- Technology
- 4-cell lithium polymer
- Capacity
- 56 Wh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 65 Watt, 19.5 V, 3.34 A
Connections & Expansion
- Headphone/microphone combo jack , USB 3.1 Gen 1 (PowerShare) , USB 2.0 , HDMI , VGA , USB-C (supports DisplayPort Alt Mode) (Power Delivery) , LAN
- Memory Card Reader
- Yes (SD Card)
Software
- Software Included
- Microsoft Office (Trial), McAfee (30 days trial)
- Black
- Security
- ExpressCharge, MU-MIMO technology
- Theft/Intrusion Protection
- Security Slot Type
- Noble Wedge security slot
- Included Accessories
- Power adapter
- FIPS 140-2, TCG Certified
- Pricing Type
- 1.72 kg
Sustainability Information
- ENERGY STAR Certified
- 0 °C
- 35 °C
- 10 - 90%
