Dell Latitude 3490 Core i5-7200U 4GB 500GB 14.0" Win 10 Pro
Quicklinx: DC75WS00 Mfr#: R1JGJ
  • Core i5
  • IEEE 802.11n
Latitude’s superior security, versatility and accessories empower the way you work because your success relies on the ability to maintain office-level productivity, wherever your job takes you.
  • Office everywhere
    Latitude's superior security, versatility empower the way you work because your success relies on the ability to maintain office-level productivity, wherever your job takes you.
  • Safely communicate
    Your Latitude 3490 comes TPM2.0 TCG certified and FIPS-140-2 certified, and uses hardware-based cryptography for the most secure communication.
  • Flexible connectivity
    VGA, HDMI, RJ-45, USB Type-A and USB Type-C ports let you go dongle free and accommodate your legacy connections.
  • Work together with ease
    The extended 175 degree hinge is smooth, flexible and durable so you can collaborate effectively.
  • Take your work with you
    At 0.82" (21 mm) thin and weighing in at 3.79 lbs (1.72 kg), your Latitude laptop is travel ready.
Dell Latitude 3490 - 14" - Core i5 7200U - 4 GB RAM - 500 GB HDD
Notebook
Operating System
Win 10 Pro 64-bit
Intel Core i5 (7th Gen) 7200U / 2.5 GHz (3.1 GHz) / 3 MB Cache /
4 GB DDR4 (1 x 4 GB)
Storage
500 GB HDD / 7200 rpm
Optical Drive
No optical drive
Display
14" WLED 1366 x 768 / HD
Graphics
Intel HD Graphics 620
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.1, Gigabit Ethernet
4-cell
Security
Trusted Platform Module (TPM 2.0) Security Chip
33.9 cm x 24.19 cm x 2.1 cm
1.72 kg
Pricing Type
Build To Stock (BTS)
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 1 year - response time: next business day
Notebook
Operating System
Windows 10 Pro 64-bit Edition
Processor / Chipset
CPU
Max Turbo Speed
3.1 GHz
Number of Cores
Dual-Core
Cache
3 MB
64-bit Computing
Intel Turbo Boost Technology 2.0
RAM
4 GB (1 x 4 GB)
Max RAM Supported
32 GB
DDR4 SDRAM
Speed
2133 MHz
Rated Speed
2133 MHz
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
500 GB HDD SATA / 7200 rpm
Display
14"
LCD Backlight Technology
WLED backlight
Resolution
1366 x 768 (HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
200 cd/m²
Anti-glare
Audio & Video
Graphics Processor
Camera
Yes - HD
Resolution
0.92 Megapixel
Image Sensor Type
CMOS
Video Resolutions
1280x720
Frame Rate
30 frames per second
Camera Features
Fixed focus
Sound
Stereo speakers, dual array microphone
Codec
Realtek ALC3246
High Definition Audio
Audio Features
MaxxAudio Pro
Input
Keyboard, touchpad
Multi-touch touchpad
Communications
Wireless
Wireless Controller
M.2 Card
Network Interface
Gigabit Ethernet
4-cell lithium polymer
56 Wh
AC Adapter
Input
Output
65 Watt, 19.5 V, 3.34 A
Connections & Expansion
USB 2.0 , USB-C 3.1 Gen 1 (PowerShare) , USB-C/DisplayPort (Power Delivery) , HDMI , VGA , LAN , Headphone/microphone combo jack
Memory Card Reader
Yes (SD Card)
Software
Software Included
Microsoft Office (Trial), McAfee (30 days trial)
Security
ExpressCharge
Theft/Intrusion Protection
Security Slot Type
Noble Wedge security slot
Power adapter
FIPS 140-2, TCG Certified
Pricing Type
1.72 kg
ENERGY STAR Certified
35 °C
10 - 90% (non-condensing)
Get more from your purchase from one of our essential accessories
DC75 Dicota Privacy filter 2-Way for Laptop 14" Wide (16:9), side-mounted In Stock £28.95
DC75 Dicota Privacy filter 2-Way for Laptop 14" Wide (16:9), self-adhesive In Stock £36.19
DC75 Dicota Privacy filter 4-Way for Laptop 14" Wide (16:9), side-mounted In Stock £48.26
DC75 Dicota Privacy filter 2-Way for Laptop 14" Wide (16:9), magnetic In Stock £51.51
