Dell Latitude 3490 Core i3-6006U 4GB 500GB 14.0" Windows 10 Pro
Quicklinx: DC74WS00 Mfr#: CVK8M
Display Size: 14in
Processor Model: I3-6006U
Operating System: Windows 10 Pro 64-bit Edition
Installed Memory: 4GB, 4GB
Hard Drive Capacity: 500GB
  • Core i3
  • IEEE 802.11n
31 in stock
£430.57 ex VAT
£516.68 inc VAT
An easily managed 14" laptop with top security features critical for small and growing businesses, all in a durable, reliable and sleek design.
  • Office everywhere
    Latitude's superior security, versatility empower the way you work because your success relies on the ability to maintain office-level productivity, wherever your job takes you.
  • Safely communicate
    Your Latitude 3490 comes TPM2.0 TCG certified and FIPS-140-2 certified, and uses hardware-based cryptography for the most secure communication.
  • Flexible connectivity
    VGA, HDMI, RJ-45, USB Type-A and USB Type-C ports let you go dongle free and accommodate your legacy connections.
  • Work together with ease
    The extended 175 degree hinge is smooth, flexible and durable so you can collaborate effectively.
  • Take your work with you
    At 0.82" (21 mm) thin and weighing in at 3.79 lbs (1.72 kg), your Latitude laptop is travel ready.
Dell Latitude 3490 - 14" - Core i3 6006U - 4 GB RAM - 500 GB HDD
Notebook
Operating System
Win 10 Pro 64-bit
Intel Core i3 (6th Gen) 6006U / 2 GHz / 3 MB Cache
4 GB DDR4 (1 x 4 GB)
Storage
500 GB HDD / 7200 rpm
Optical Drive
No optical drive
Display
14" 1366 x 768 / HD
Graphics
Intel HD Graphics 520
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.1, Gigabit Ethernet
3-cell
Security
Trusted Platform Module (TPM 2.0) Security Chip
33.9 cm x 24.19 cm x 2.1 cm
1.72 kg
Pricing Type
Build To Stock (BTS)
Limited warranty - 1 year - response time: next business day
Notebook
Operating System
Processor / Chipset
CPU
Number of Cores
Dual-Core
Cache
3 MB
64-bit Computing
RAM
4 GB (1 x 4 GB)
Max RAM Supported
32 GB
DDR4 SDRAM
Speed
2133 MHz - 2133 MHz
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
500 GB HDD SATA / 7200 rpm
Display
14"
Resolution
1366 x 768 (HD)
Widescreen
Image Brightness
220 cd/m²
Anti-glare, 112 ppi
Audio & Video
Graphics Processor
Memory Allocation Technology
Shared Video Memory (UMA)
Camera
Yes - 1280 x 720
Resolution
0.92 Megapixel
Image Sensor Type
CMOS
Video Resolutions
1280x720
Frame Rate
30 frames per second
Camera Features
Fixed focus
Sound
Stereo speakers, dual array microphone
Codec
Realtek ALC3246
High Definition Audio
Audio Features
MaxxAudio Pro
Input
Keyboard, touchpad
Communications
Wireless
Wireless Controller
Atheros QCA61x4A - M.2 2230
Network Interface
Gigabit Ethernet
Ethernet Controller
Realtek RTL8111HSD
Miracast
3-cell lithium polymer
42 Wh
AC Adapter
Input
Output
65 Watt, 19.5 V, 3.34 A
Connections & Expansion
Headphone/microphone combo jack , USB 3.1 Gen 1 (PowerShare) , USB 2.0 , HDMI , VGA , USB-C/DisplayPort (Power Delivery) , LAN
Memory Card Reader
Yes (SD Card)
Software
Software Included
Microsoft Office (Trial), McAfee (30 days trial)
Security
ExpressCharge, MU-MIMO technology
Theft/Intrusion Protection
Security Slot Type
Noble Wedge security slot
Power adapter
FIPS 140-2, TCG Certified
Pricing Type
1.72 kg
35 °C
10 - 90%
Software applications
Dell Latitude 3490 Core i3-6006U 4GB 500GB 14.0 Bundle deal on Dell Latitude 3490 Core i3-6006U 4GB 500GB 14.0" Windows 10 Pro
£617.03
saving £8.33
£522.11
Display Size: 14in
Optical Storage: None
Graphics: Intel HD Graphics 520
Hard Drive Type: HDD
Type: Laptop
Brand: Dell
Price Range Ex VAT: 300 - 500
