Dell Latitude 3480 Intel Core i3-6006U 4GB 500GB 14" W10 Pro
Quicklinx: D92DWS00 Mfr#: PVYX1
  • Core i3
  • IEEE 802.11n
An easily managed 14-inch laptop with top security features critical for small and growing businesses, all in a durable, reliable design.
Enhanced data protection: Data security is key in protecting your business and employees. Dell Data Protection is a suite of security software programs offered on each Latitude 3000 Series system. Endpoint security, advanced user authentication and data encryption software all work cohesively to safeguard your data from threats and hacks.
Safely communicate: Your Latitude 3480 comes TPM2.0 TCG certified and FIPS-140-2 certified, and uses hardware-based cryptography for the most secure communication.
Login with ease: Login to Windows Hello using biometric authentication with optional touch fingerprint reader or Dell infrared camera for easy and secure access.
Easy to manage: Dell Client Command Suite comes with a set of automation tools that assists in device monitoring, deploying images, updating and more, to maximize your hardware and software investments and save time.
Outstanding reliability: Your Latitude 14 features a durable, built-to-last chassis that has undergone extensive military-grade MIL-STD 810G testing to ensure your system can withstand real-world conditions.
Power your workday: 7th Gen Intel Core i7 processors deliver the power you need for optimum productivity. The DDR4 memory boosts transfer rates while using less voltage, making your Latitude 3480 run faster and more efficiently.
Flexible connectivity: VGA, HDMI, RJ-45 and USB Type A ports let you go dongle free and accommodate your legacy connections.
Work together with ease: The extended 180-degree hinge is smooth, flexible and durable so you can collaborate effectively.
Take your work with you: At less than 24mm thin and weighing less than 1.8kg, your Latitude laptop is travel ready.
  • Outstanding reliability
    Your Latitude 14 features a durable, built-to-last chassis that ensures your system can withstand real-world conditions.
  • Power your workday
    Advanced processors deliver the power you need for optimum productivity. The DDR4 memory boosts transfer rates while using less voltage, making your Latitude 3480 run faster and more efficiently.
  • Flexible connectivity
    VGA, HDMI, RJ-45 and USB ports let you go dongle free and accommodate your legacy connections.
  • Work together with ease
Dell Latitude 3480 - 14" - Intel Core i3 - 6006U - 4 GB RAM - 500 GB HDD
Notebook
Operating System
Win 10 Pro 64-bit
Intel Core i3 (6th Gen) - 6006U / 2 GHz / 3 MB Cache
4 GB DDR4 (1 x 4 GB)
Storage
500 GB HDD / 7200 rpm
Display
14" 1366 x 768 / HD
Graphics
Intel HD Graphics 520
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.1, Gigabit Ethernet
4-cell
Security
Trusted Platform Module (TPM 2.0) Security Chip
33.74 cm x 24.4 cm x 2.333 cm
1.76 kg
Pricing Type
Build To Stock (BTS)
Environmental Standards
- EPEAT Climate+
Limited warranty - 1 year - response time: next business day
Notebook
Operating System
Windows 10 Pro 64-bit Edition
Processor / Chipset
CPU
Intel Core i3 (6th Gen) 6006U / 2 GHz
Number of Cores
Dual-Core
Cache
3 MB
64-bit Computing
RAM
4 GB (1 x 4 GB)
Max RAM Supported
32 GB
DDR4 SDRAM
Speed
2133 MHz
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
500 GB HDD SATA / 7200 rpm
Display
14"
Resolution
1366 x 768 (HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
200 cd/m²
Anti-glare
Audio & Video
Graphics Processor
Camera
Yes - 1280 x 720
Resolution
0.92 Megapixel
Sound
Stereo speakers, microphone
Codec
Realtek ALC3246
High Definition Audio
Input
Keyboard, touchpad
Communications
Wireless
Wireless Controller
Dell Wireless 1820
Network Interface
Gigabit Ethernet
4-cell Lithium Ion
56 Wh
AC Adapter
Input
Output
65 Watt, 19.5 V, 3.34 A
Connections & Expansion
Interfaces Details
LAN , USB 3.1 Gen 1 , USB 2.0 , USB 3.1 Gen 1 (PowerShare) , HDMI , Headphone/microphone combo jack , VGA
Memory Card Reader
Yes (SD Card)
Software
Software Included
Microsoft Office (Trial)
Security
Power adapter
Pricing Type
1.76 kg
Sustainability Information
TCO Certified
35 °C
10 - 90% (non-condensing)
