Dell Latitude 3410 Intel Core i5-10210U 8GB 256GB SSD 14" Windows 10 Professional 64-bit
Quicklinx: FW36WS00 Mfr#: TFHP9
Display Size: 14in
Processor Model: I5-10210U
Operating System: Windows 10 Pro 64-bit Edition
Hard Drive Capacity: 256GB
Optical Storage: None
  • Core i5
  • IEEE 802.11n
Hurry, only 3 left in stock!
£693.84 ex VAT
£832.60 inc VAT
UK/BTS/Lati 3410/Core i5-10210U/8GB/256GB SSD/14.0" FHD/Intel UHD/Cam & Mic/WLAN + BT/Backlit Kb/3 Cell/W10Pro/1Y Basic Onsite.
  • Stunningly designed
    The Latitude 3410 is smaller and thinner, with a lighter finish and narrow screen bezels to give you more room to work.
  • Start quickly, power through
    Start up instantly with a fingerprint reader built into the power button. Keep working with outstanding battery life.
  • Ports for any purpose
    Compatible with more monitors and accessories, with a full range of available ports, including USB Type-C and legacy ports like HDMI and RJ45.
  • Fast performance
    The 10th Gen Intel Core processor offers businesses the performance, manageability, built-in security features and stability of Intel architecture and aligns to a future-proof roadmap. Plus, you can stream video, download and smoothly run applications with advanced graphics.
Dell Latitude 3410 - 14" - Core i5 10210U - 8 GB RAM - 256 GB SSD
Notebook
Operating System
Win 10 Pro 64-bit - Multilingual User Interface (MUI)
Intel Core i5 (10th Gen) 10210U / 1.6 GHz (4.2 GHz) / 6 MB Cache
8 GB DDR4 (1 x 8 GB)
Storage
256 GB SSD
Optical Drive
No optical drive
Display
14" 1920 x 1080 / Full HD @ 60 Hz - 157 ppi
Graphics
Intel UHD Graphics
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac Wave 2/ax, Bluetooth 5.1, Gigabit Ethernet
3-cell
Security
Trusted Platform Module (TPM 2.0) Security Chip
32.65 cm x 22.638 cm x 1.835 cm
1.61 kg
Pricing Type
Build To Stock (BTS)
Bundled Services
1 Year Basic Onsite
Notebook
Operating System
Windows 10 Pro 64-bit Edition - Multilingual User Interface (MUI)
Processor / Chipset
CPU
Max Turbo Speed
4.2 GHz
Number of Cores
Quad-Core
Cache
6 MB
64-bit Computing
Intel Turbo Boost Technology 2.0
RAM
8 GB (1 x 8 GB)
Max RAM Supported
32 GB
DDR4 SDRAM
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
256 GB SSD M.2 PCIe
Display
14"
Resolution
1920 x 1080 (Full HD)
V-Sync Rate at Max Res.
60 Hz
Widescreen
Pixel Density (ppi)
157
Image Brightness
220 cd/m²
Bezel Type
Raised
Anti-glare, 45% NTSC colour gamut, Wide Viewing Angle, ±80° horizontal viewing angle, ±80° vertical viewing angle, 35 ms response rate
Audio & Video
Graphics Processor
Intel UHD Graphics
Memory Allocation Technology
Shared Video Memory (UMA)
Camera
Yes - HD
Resolution
0.92 Megapixel
Image Sensor Type
CMOS
Video Resolutions
1280 x 720
Frame Rate
30 frames per second
Camera Features
IR camera, RGB camera, 87 degrees
Sound
Stereo speakers, dual array microphone
Codec
Realtek ALC3204
High Definition Audio
Input
Keyboard, touchpad
Keyboard Backlight
Communications
Wireless
Wireless Controller
Intel Wi-Fi 6 AX 201
Network Interface
Gigabit Ethernet
Ethernet Controller
Realtek RTL8111H
3-cell
40 Wh
AC Adapter
Input
Output
65 Watt, 19.5 V, 3.34 A
Connections & Expansion
HDMI , USB-C 3.2 Gen 1/DisplayPort , USB 3.2 Gen 1 (PowerShare) , USB 3.2 Gen 1 , USB 2.0 , LAN , Headphone/microphone combo jack
Memory Card Reader
Yes (microSD, microSDHC, microSDXC)
Software
Software Included
Microsoft Office (Trial)
Security
ExpressCharge
Theft/Intrusion Protection
Security Slot Type
Noble Wedge security slot
Power adapter
Pricing Type
1.61 kg
Bundled Services
1 Year Basic Onsite
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
110 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
160 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.66 g @ RMS (random)
Vibration Tolerance (non-operating)
1.3 g @ RMS (random)
Display Size: 14in
Graphics: Intel UHD Graphics
Hard Drive Type: SSD
Brand: Dell
Price Range Ex VAT: 500 - 750
