Dell Latitude 3390 i5-8250U 2-in-1 8GB 256GB SSD 13.3" Win 10 Pro
Quicklinx: FQ56WS00 Mfr#: NWYNN
  • Core i5
  • IEEE 802.11n
High performance comes courtesy of high-performance processors, which help you power through any task. Four flexible modes mean you can view your screen from whichever angle suits the task at hand, letting you work comfortably for longer. The USB Type-C offers a range of docking flexibility with a single wire, letting you connect and power your 2-in-1 whether you're on the move or at your desk. Four modes mean you can bring your sleek system with you, no matter what you happen to be doing. Laptop at the office, tablet on the go, tent mode for viewing on narrow surface areas and stand mode for presentations: this machine will tag along and make your busy day even more efficient. Thin bezels and extra screen space make it simple to spread out your work and view presentations comfortably.
  • Organize your work load
  • Work better from any angle
  • Make the most of every minute
  • Workday powerhouse
  • Expansive views
Dell Latitude 3390 2-in-1 - 13.3" - Core i5 8250U - 8 GB RAM - 256 GB SSD
Notebook - flip design
Operating System
Win 10 Pro 64-bit - Multilingual User Interface (MUI)
Intel Core i5 (8th Gen) 8250U / 1.6 GHz (3.4 GHz) / 6 MB Cache
8 GB DDR4 (2 x 4 GB)
Storage
256 GB SSD
Display
13.3" touchscreen 1920 x 1080 / Full HD
Graphics
Intel UHD Graphics 620
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.1
3-cell
Security
Trusted Platform Module (TPM 2.0) Security Chip
32.4 cm x 22.48 cm x 2.04 cm
1.57 kg
Pricing Type
Build To Stock (BTS)
Bundled Services
1 Year Basic Onsite
Operating System
Windows 10 Pro 64-bit Edition - Multilingual User Interface (MUI)
Processor / Chipset
CPU
Max Turbo Speed
3.4 GHz
Number of Cores
Quad-Core
Cache
6 MB
64-bit Computing
Intel Turbo Boost Technology 2.0
RAM
8 GB (2 x 4 GB)
Max RAM Supported
16 GB
DDR4 SDRAM
Speed
2133 MHz
Rated Speed
2133 MHz
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
0
Storage
Main Storage
256 GB SSD M.2 2280 SATA
Display
13.3"
Touchscreen
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Brightness
220 cd/m²
Anti-glare, Wide Viewing Angle
Audio & Video
Graphics Processor
Memory Allocation Technology
Shared Video Memory (UMA)
Camera
Yes - 1280 x 720
Resolution
0.92 Megapixel
Video Resolutions
1280 x 720
Frame Rate
30 frames per second
Camera Features
IR camera
Sound
Stereo speakers, two microphones
Codec
Realtek ALC3253
High Definition Audio
Audio Features
Output: MaxxAudio Pro
Input
Keyboard, touchpad
Keyboard Backlight
Communications
Wireless
Wireless Controller
Atheros QCA61x4A - M.2 2230
3-cell Lithium Ion
42 Wh
AC Adapter
Input
Output
45 Watt, 19.5 V, 2.31 A
Connections & Expansion
Headphone/microphone combo jack , USB 3.1 Gen 1 (PowerShare) , USB-C (supports DisplayPort Alt Mode) , USB 2.0 , HDMI
Memory Card Reader
Yes (SD Card)
Software
Software Included
Microsoft Office (Trial)
Security
Theft/Intrusion Protection
Security Slot Type
Noble Wedge security slot
Power adapter
Pricing Type
1.57 kg
Bundled Services
1 Year Basic Onsite
Protect your investment by taking out one of our great value warranty packs
FQ56 Dell Upgrade from 1Y Basic Onsite to 3Y Basic Onsite - Extended Service Agreement In Stock £40.94
