High performance comes courtesy of high-performance processors, which help you power through any task. Four flexible modes mean you can view your screen from whichever angle suits the task at hand, letting you work comfortably for longer. The USB Type-C offers a range of docking flexibility with a single wire, letting you connect and power your 2-in-1 whether you're on the move or at your desk. Four modes mean you can bring your sleek system with you, no matter what you happen to be doing. Laptop at the office, tablet on the go, tent mode for viewing on narrow surface areas and stand mode for presentations: this machine will tag along and make your busy day even more efficient. Thin bezels and extra screen space make it simple to spread out your work and view presentations comfortably.
Organize your work load
High performance comes courtesy of high-performance processors, which help you power through any task. -
Work better from any angle
Four flexible modes mean you can view your screen from whichever angle suits the task at hand, letting you work comfortably for longer. -
Make the most of every minute
The USB Type-C offers a range of docking flexibility with a single wire, letting you connect and power your 2-in-1 whether you're on the move or at your desk. -
Workday powerhouse
Four modes mean you can bring your sleek system with you, no matter what you happen to be doing. Laptop at the office, tablet on the go, tent mode for viewing on narrow surface areas and stand mode for presentations: this machine will tag along and make your busy day even more efficient. -
Expansive views
- Dell Latitude 3390 2-in-1 - 13.3" - Core i5 8250U - 8 GB RAM - 256 GB SSD
- Product Type
- Notebook - flip design
- Operating System
- Win 10 Pro 64-bit - Multilingual User Interface (MUI)
- Processor
- Intel Core i5 (8th Gen) 8250U / 1.6 GHz (3.4 GHz) / 6 MB Cache
- Memory
- 8 GB DDR4 (2 x 4 GB)
- Storage
- 256 GB SSD
- Display
- 13.3" touchscreen 1920 x 1080 / Full HD
- Graphics
- Intel UHD Graphics 620
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.1
- Battery
- 3-cell
- Security
- Trusted Platform Module (TPM 2.0) Security Chip
- Black
- 32.4 cm x 22.48 cm x 2.04 cm
- 1.57 kg
- Pricing Type
- Build To Stock (BTS)
- Bundled Services
- 1 Year Basic Onsite
- Product Type
- Operating System
- Windows 10 Pro 64-bit Edition - Multilingual User Interface (MUI)
Processor / Chipset
- CPU
- Max Turbo Speed
- 3.4 GHz
- Number of Cores
- Quad-Core
- Cache
- 6 MB
- 64-bit Computing
- Intel Turbo Boost Technology 2.0
- RAM
- 8 GB (2 x 4 GB)
- Max RAM Supported
- 16 GB
- Technology
- DDR4 SDRAM
- Speed
- 2133 MHz
- Rated Speed
- 2133 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 2
- Empty Slots
- 0
Storage
- Main Storage
- 256 GB SSD M.2 2280 SATA
Display
- 13.3"
- Touchscreen
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Brightness
- 220 cd/m²
- Anti-glare, Wide Viewing Angle
Audio & Video
- Graphics Processor
- Memory Allocation Technology
- Shared Video Memory (UMA)
- Camera
- Yes - 1280 x 720
- Resolution
- 0.92 Megapixel
- Video Resolutions
- 1280 x 720
- Frame Rate
- 30 frames per second
- Camera Features
- IR camera
- Sound
- Stereo speakers, two microphones
- Codec
- Realtek ALC3253
- High Definition Audio
- Audio Features
- Output: MaxxAudio Pro
Input
- Keyboard, touchpad
Communications
- Wireless
- Wireless Controller
- Atheros QCA61x4A - M.2 2230
- Technology
- 3-cell Lithium Ion
- Capacity
- 42 Wh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 19.5 V, 2.31 A
Connections & Expansion
- Headphone/microphone combo jack , USB 3.1 Gen 1 (PowerShare) , USB-C (supports DisplayPort Alt Mode) , USB 2.0 , HDMI
- Memory Card Reader
- Yes (SD Card)
Software
- Software Included
- Microsoft Office (Trial)
- Black
- Security
- Theft/Intrusion Protection
- Security Slot Type
- Noble Wedge security slot
- Included Accessories
- Power adapter
- Pricing Type
- 1.57 kg
- Bundled Services
Protect your investment by taking out one of our great value warranty packs
Dell Upgrade from 1Y Basic Onsite to 3Y Basic Onsite - Extended Service Agreement | In Stock | £40.94 |
