Dell Latitude 3390 2-in-1 i3-7020U 4GB 128GB SSD 13" Win 10 Pro
Quicklinx: F2H2WS00 Mfr#: YV726
Display Size: 13.3in
Processor Model: I3-7020U
Operating System: Windows 10 Pro 64-bit Edition
Installed Memory: 4GB, 4GB
Hard Drive Capacity: 128GB
  • Core i3
  • IEEE 802.11n
£539.06 ex VAT
£646.87 inc VAT
High performance comes courtesy of high-performance processors, which help you power through any task. Four flexible modes mean you can view your screen from whichever angle suits the task at hand, letting you work comfortably for longer. The USB Type-C offers a range of docking flexibility with a single wire, letting you connect and power your 2-in-1 whether you're on the move or at your desk. Four modes mean you can bring your sleek system with you, no matter what you happen to be doing. Laptop at the office, tablet on the go, tent mode for viewing on narrow surface areas and stand mode for presentations: this machine will tag along and make your busy day even more efficient. Thin bezels and extra screen space make it simple to spread out your work and view presentations comfortably.
  • Organize your work load
  • Work better from any angle
  • Make the most of every minute
  • Workday powerhouse
  • Expansive views
Dell Latitude 3390 2-in-1 - 13.3" - Core i3 7020U - 4 GB RAM - 128 GB SSD
Notebook - flip design
Operating System
Win 10 Pro 64-bit - English
Intel Core i3 (7th Gen) 7020U / 2.3 GHz / 3 MB Cache
4 GB DDR4 (1 x 4 GB)
Storage
128 GB - M.2 2280 SSD
Optical Drive
No optical drive
Display
13.3" touchscreen 1920 x 1080 / Full HD
Graphics
Intel HD Graphics 620
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.1
3-cell
Security
Trusted Platform Module (TPM 2.0) Security Chip
32.4 cm x 22.48 cm x 2.04 cm
1.57 kg
Pricing Type
Build To Plan (BTP)
Limited warranty - 1 year - on-site
Operating System
Windows 10 Pro 64-bit Edition - English
Processor / Chipset
CPU
Number of Cores
Dual-Core
Cache
3 MB
64-bit Computing
RAM
4 GB (1 x 4 GB)
Max RAM Supported
16 GB
DDR4 SDRAM
Speed
2400 MHz - 2400 MHz
Rated Speed
2400 MHz
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
128 GB SSD - (M.2 2280) SATA
Display
13.3"
Touchscreen
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Brightness
220 cd/m²
Anti-glare
Audio & Video
Graphics Processor
Memory Allocation Technology
Shared Video Memory (UMA)
Camera
Yes - 1280 x 720
Resolution
0.92 Megapixel
Video Resolutions
1280 x 720
Frame Rate
30 frames per second
Camera Features
IR camera
Sound
Stereo speakers, two microphones
Codec
Realtek ALC3253
High Definition Audio
Audio Features
MaxxAudio Pro
Input
Keyboard, touchpad
Keyboard Backlight
Communications
Wireless
Wireless Controller
Atheros QCA61x4A - M.2 2230
3-cell Lithium Ion
42 Wh
AC Adapter
Input
Output
45 Watt, 19.5 V, 2.31 A
Connections & Expansion
Headphone/microphone combo jack , USB 3.1 Gen 1 (PowerShare) , USB-C/DisplayPort , USB 2.0 , HDMI
Memory Card Reader
Yes (SD Card)
Software
Software Included
Microsoft Office (Trial)
Security
Theft/Intrusion Protection
Security Slot Type
Noble Wedge security slot
Power adapter
Pricing Type
Build To Plan (BTP)
1.57 kg
Software applications
Dell Latitude 3390 2-in-1 i3-7020U 4GB 128GB SSD 13 Bundle deal on Dell Latitude 3390 2-in-1 i3-7020U 4GB 128GB SSD 13" Win 10 Pro
£724.28
saving £8.33
£638.23
Optical Storage: None
Graphics: Intel HD Graphics 620
Hard Drive Type: SSD
Brand: Dell
Price Range Ex VAT: 500 - 750
