This 13" essential business notebook features an innovative webcam for high-quality video conferencing and a powerful processor.
Minimize distractions
A 3-sided narrow border enhances your screen, so you can collaborate in online meetings or work on your latest projects in style. -
Redesigned hinge
Your laptop lifts slightly off the table when open past a 135-degree angle, allowing for improved air circulation and a more comfortable typing experience. -
Intelligent thermals
The Latitude 3301 is smart enough to know when it's in your hands, lap or on a desk. This allows it to intelligently adapt its thermal profiles to stay cool. It remains cooler on your lap and full power is unleashed when stationary on a desk for maximum productivity. -
Be seen in any light
By using advanced noise reduction, video quality is significantly improved, especially in dim lighting conditions. -
Never miss a word
With Waves MaxxAudio Pro, get an immersive audio experience that emulates an actual conference room to hear and be heard for better collaboration. -
Power up
Keep the work flowing with a high-density battery and ExpressCharge, which allows an 80% charge in one hour. -
Plug in
Quickly connect to peripherals with a full range of available ports, including USB Type-C, Type-A and legacy ports like HDMI.
- Dell Latitude 3301 - 13.3" - Core i5 8265U - 8 GB RAM - 256 GB SSD
- Product Type
- Notebook
- Operating System
- Win 10 Pro 64-bit - Multilingual User Interface (MUI)
- Processor
- Intel Core i5 (8th Gen) 8265U / 1.6 GHz (3.9 GHz) / 6 MB Cache
- Memory
- 8 GB LPDDR3 (provided memory is soldered)
- Storage
- 256 GB SSD
- Display
- 13.3" 1920 x 1080 / Full HD @ 60 Hz - 166 ppi
- Graphics
- Intel UHD Graphics 620
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac Wave 2, Bluetooth 5.0
- Battery
- 4-cell
- Security
- Trusted Platform Module (TPM 2.0) Security Chip
- Black
- 30.76 cm x 20.45 cm x 1.68 cm
- 1.18 kg
- Pricing Type
- Build To Stock (BTS)
- Environmental Standards
- ENERGY STAR Qualified
- Bundled Services
- 1 Year Basic Onsite
- Product Type
- Notebook
- Operating System
- Windows 10 Pro 64-bit Edition - Multilingual User Interface (MUI)
Processor / Chipset
- CPU
- Max Turbo Speed
- 3.9 GHz
- Number of Cores
- Quad-Core
- Cache
- 6 MB
- 64-bit Computing
- Intel Turbo Boost Technology 2.0
- RAM
- 8 GB (provided memory is soldered)
- Technology
- LPDDR3 SDRAM
- Speed
- 2133 MHz
- Rated Speed
- 2133 MHz
Storage
- Main Storage
- 256 GB SSD M.2 2280 PCIe
Display
- 13.3"
- Resolution
- 1920 x 1080 (Full HD)
- V-Sync Rate at Max Res.
- 60 Hz
- Widescreen
- Pixel Density (ppi)
- 166
- Image Brightness
- 300 cd/m²
- TrueLife
Audio & Video
- Graphics Processor
- Memory Allocation Technology
- Shared Video Memory (UMA)
- Camera
- Yes - HD
- Resolution
- 0.92 Megapixel
- Image Sensor Type
- CMOS
- Video Resolutions
- 1280 x 720
- Frame Rate
- 30 frames per second
- Camera Features
- 74.9 degrees, RGB camera
- Sound
- Stereo speakers, dual array microphone
- Codec
- Realtek ALC3204
- High Definition Audio
- Audio Features
- Output: MaxxAudio Pro
Input
- Keyboard, touchpad
- Multi-finger touchpad
Communications
- Wireless
- Wireless Controller
- Intel Wireless-AC 9560
- Technology
- 4-cell Lithium Ion
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 65 Watt, 19.5 V, 3.34 A
Connections & Expansion
- Headphone/microphone combo jack , USB 3.1 Gen 1 , USB-C 3.1 Gen 1 (supports DisplayPort Alt Mode) , HDMI
- Memory Card Reader
- Yes (microSD)
Software
- Software Included
- Microsoft Office (Trial)
- Black
- Case Material
- Aluminum
- Security
- Included Accessories
- Power adapter
- Pricing Type
- 1.18 kg
Sustainability Information
- ENERGY STAR Certified
- Bundled Services
- 0 °C
- 35 °C
- 10 - 90% (non-condensing)
- Shock Tolerance (operating)
- 110 g @ 2 ms half-sine pulse
- Shock Tolerance (non-operating)
- 160 g @ 2 ms half-sine pulse
- Vibration Tolerance (operating)
- 0.66 g @ RMS (random)
- Vibration Tolerance (non-operating)
- 1.3 g @ RMS (random)
