Built to withstand serious rough and tumble, the Dell Latitude 14 Rugged combines durability, performance and reliability - making it a powerful laptop suitable for a wide range of business environments.
Dell's Latitude 14 Rugged is - as the name suggests - tough and hardwearing, so it can handle the rigours of your daily routine with ease. What's more, its 4G connectivity and dedicated GPS means you'll be able to stay connected to the wider world when you're out and about.
This Dell business laptop powered by an Intel Core i5 processor, with six and nine-cell battery packs which can provide up to seven hours of battery life. With 4GB RAM and 500GB hard drive storage space, it provides you with ample power and storage space.
Docking is also easy, with a range of universal docking solutions including adjustable retention hooks and ports for USB 2.0, USB 3.0, HDMI, Ethernet, VGA and more.
For performance where and when you need it, this Dell Latitude laptop delivers.
Aluminum backing
Aluminum backing on the LCD screen adds durability for the classroom and a professional look for the business world. -
Its lightweight design
Its lightweight design enables easy portability between classrooms or wherever business takes you. -
Collaborate around
Collaborate around an antiglare screen that's compact enough to fit on most desktops. -
Bring interactive teaching
Bring interactive teaching to your classroom with a built-in HD webcam. -
Boot up quickly
Boot up quickly with hybrid and solid-state hard drive options that deliver dependable performance and fast return from sleep mode. -
Swap batteries
Swap batteries for long periods of productivity away from an outlet. Keep extra batteries for easy swaps on the move.
- Dell Latitude 14 Rugged (5404) - 14" - Core i5 4310U - vPro - 4 GB RAM - 500 GB HDD - with 3-year ProSupport
- Product Type
- Notebook - rugged
- Operating System
- Win 7 Pro 64-bit + Windows 8.1 Pro 64-bit Licence
- Platform Technology
- Intel vPro Platform
- Processor
- Intel Core i5 (4th Gen) 4310U / 2 GHz (3 GHz) / 3 MB Cache
- Memory
- 4 GB DDR3L
- Storage
- 500 GB HDD
- Optical Drive
- DVD-Writer
- Display
- 14" LED backlight 1366 x 768 / HD
- Graphics
- Intel HD Graphics 4400
- Keyboard Backlight
- Yes (RGB)
- Integrated Webcam
- Networking
- Bluetooth, Wi-Fi, Gigabit Ethernet
- Battery
- 6-cell
- Security
- Trusted Platform Module (TPM 1.2) Security Chip
- 34.7 cm x 24.3 cm x 4.44 cm
- 2.95 kg
- Pricing Type
- Catalogue Build to Order (CAT)
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - 3 years
- Bundled Services
- 3 Years Dell ProSupport with Collect and Return Service
- Product Type
- Notebook - rugged
- Operating System
- Microsoft Windows 7 Professional 64-bit Edition + Windows 8.1 Pro 64-bit Licence
Processor / Chipset
- CPU
- Max Turbo Speed
- 3 GHz
- Number of Cores
- Dual-Core
- Cache
- 3 MB
- 64-bit Computing
- Intel Turbo Boost Technology 2.0
- RAM
- 4 GB
- Max RAM Supported
- 16 GB
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz
- Form Factor
- SO-DIMM 204-pin
- Slots Qty
- 2
Storage
- Main Storage
- 500 GB HDD SATA
- Optical Drive
- DVD-Writer
Display
- 14"
- LCD Backlight Technology
- LED backlight
- Resolution
- 1366 x 768 (HD)
- Widescreen
- Image Aspect Ratio
- 16:9
Audio & Video
- Graphics Processor
- Camera
- Camera Features
- 1080p Full HD movie recording, privacy shutter
- Sound
- Speaker, microphone
Input
- Keyboard, touchpad
- Yes (RGB)
Communications
- Wireless
- Bluetooth, Wi-Fi
- Network Interface
- Gigabit Ethernet
- Technology
- 6-cell Lithium Ion
- Capacity
- 65 Wh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 65 Watt
Connections & Expansion
- Slots
- 1 x ExpressCard/54 (1 free)
- Headphone/microphone combo jack , 2 x USB 3.0 , 2 x USB 2.0 , 2 x serial , 2 x LAN , HDMI , VGA
- Memory Card Reader
- Security
- Security lock slot (cable lock sold separately), water-resistant, dust-resistant, anti-vibration, shock-resistant, explosionproof, QuadCool thermal management system, Dell ControlVault, Dell Data Protection
- Included Accessories
- Power adapter
- MIL-STD 810G, IEC 60529 IP52
- Pricing Type
- 2.95 kg
Sustainability Information
- ENERGY STAR Certified
- Bundled Services
- -29 °C
- 60 °C
