Dell Latitude 12 Rugged Intel Core M-5Y71 8GB 128GB 11.6" Windows 8.1 Professional 64-bit
Quicklinx: BPTXWS00 Mfr#: 7202-9194
  • Windows 8.1 Pro 64-bit Edition
  • Bluetooth 4.0
  • IEEE 802.11n
Built for the most extreme environments, the Latitude 12 Rugged Tablet provides reliable performance and security so you can get the job done.
  • Performance you can count on
    You have everything you need to run your projects with powerful, efficient fifth-generation Intel processors and fast, reliable solid state storage.
  • Longer battery life
    The Latitude 12 Rugged Tablet powers you through a full shift of projects on the go.
  • Easy outdoor readability
    Work never stops, regardless of environment. See clearly in direct sunlight on a crisp, 11.6" multi-touch display that responds even while wet or when wearing thick gloves.
  • Bring the heat
    Experience peak performance even in high temperatures with fourth-generation QuadCool fan based thermal management system that combines passive and active cooling.
  • Outstanding reliability
    The Dell Latitude 12 Rugged Tablet is subjected to rigorous testing to ensure world-class dependability in the most demanding of conditions.
Dell Latitude 12 Rugged Tablet 7202 - 11.6" - Core M 5Y71 - 8 GB RAM - 128 GB SSD - with 3-year ProSupport
Tablet - no keyboard - rugged
Operating System
Win 8.1 Pro 64-bit
Intel Core M 5Y71 / 1.2 GHz (2.9 GHz) / 4 MB Cache
8 GB LPDDR3
Storage
128 GB SSD
Display
11.6" touchscreen 1366 x 768 / HD
Graphics
Intel HD Graphics 5300
Integrated Webcam
Bluetooth 4.0, 802.11a/b/g/n/ac
2-cell - up to 12 hours
Dockable
Security
Trusted Platform Module (TPM 1.2) Security Chip, fingerprint reader, smart card reader, contactless smart card reader
31.2 cm x 20.3 cm x 2.4 cm
1.62 kg
Pricing Type
BTO
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 3 years
Bundled Services
3 Years ProSupport
Operating System
Processor / Chipset
CPU
Max Turbo Speed
2.9 GHz
Number of Cores
Dual-Core
Cache
4 MB
64-bit Computing
Intel Turbo Boost Technology 2.0
RAM
8 GB
Max RAM Supported
8 GB
LPDDR3 SDRAM
Speed
1600 MHz
Storage
Main Storage
128 GB SSD
Display
11.6"
Touchscreen
Yes (10-point multi-touch)
Resolution
1366 x 768 (HD)
Widescreen
Image Aspect Ratio
16:9
Anti-glare, Corning Gorilla glass 3
Audio & Video
Graphics Processor
Memory Allocation Technology
Shared Video Memory (UMA)
Camera
Resolution
8 Megapixel
Camera Features
LED flash, privacy shutter
Sound
Speaker, two microphones
Communications
Wireless
2-cell Lithium Ion
26 Wh
Run Time
Up to 12 hours
AC Adapter
Input
Output
45 Watt
Connections & Expansion
Headphone/microphone combo jack , USB 3.0 , Mini-HDMI , Micro-serial
Memory Card Reader
Yes (microSD)
Dockable
Security
Power adapter, additional 2-cell battery
MIL-STD-461F, IP65
Pricing Type
BTO
1.62 kg
ENERGY STAR Certified
Bundled Services
3 Years ProSupport
-29 °C
63 °C
