Built for the most extreme environments, the Latitude 12 Rugged Tablet provides reliable performance and security so you can get the job done.
Performance you can count on
You have everything you need to run your projects with powerful, efficient fifth-generation Intel processors and fast, reliable solid state storage. -
Longer battery life
The Latitude 12 Rugged Tablet powers you through a full shift of projects on the go. -
Easy outdoor readability
Work never stops, regardless of environment. See clearly in direct sunlight on a crisp, 11.6" multi-touch display that responds even while wet or when wearing thick gloves. -
Bring the heat
Experience peak performance even in high temperatures with fourth-generation QuadCool fan based thermal management system that combines passive and active cooling. -
Outstanding reliability
The Dell Latitude 12 Rugged Tablet is subjected to rigorous testing to ensure world-class dependability in the most demanding of conditions.
- Dell Latitude 12 Rugged Tablet 7202 - 11.6" - Core M 5Y10c - 4 GB RAM - 128 GB SSD - with 3-year ProSupport
- Product Type
- Tablet - no keyboard
- Operating System
- Win 8.1 Pro 64-bit
- Processor
- Intel Core M 5Y10c / 800 MHz (2 GHz) / 4 MB Cache
- Memory
- 4 GB LPDDR3
- Storage
- 128 GB SSD
- Display
- 11.6" WLED touchscreen 1366 x 768 / HD
- Graphics
- Intel HD Graphics 5300
- Integrated Webcam
- Networking
- Bluetooth, Wi-Fi
- Battery
- 2-cell
- Dockable
- Security
- Fingerprint reader, smart card reader, contactless smart card reader
- 31.2 cm x 20.3 cm x 2.4 cm
- 1.62 kg
- Pricing Type
- BTO
- Limited warranty - 3 years - response time: next business day
- Bundled Services
- 3 Years ProSupport
- Product Type
- Operating System
- Windows 8.1 Pro 64-bit Edition
Processor / Chipset
- CPU
- Max Turbo Speed
- 2 GHz
- Number of Cores
- Dual-Core
- Cache
- 4 MB
- 64-bit Computing
- Intel Turbo Boost Technology 2.0
- RAM
- 4 GB
- Max RAM Supported
- 8 GB
- Technology
- LPDDR3 SDRAM
- Speed
- 1600 MHz
Storage
- Main Storage
- 128 GB SSD
Display
- 11.6"
- LCD Backlight Technology
- WLED backlight
- Touchscreen
- Yes (10-point multi-touch)
- Resolution
- 1366 x 768 (HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Corning Gorilla glass 3, Glove Friendly Multi-Touch Technology, Direct View outdoor readable
Audio & Video
- Graphics Processor
- Camera
- Yes - 3264 x 2448 (rear), 1366 x 768 (front)
- Resolution
- 8 Megapixel (rear), 2 Megapixel (front)
- Sound
- Speaker, microphone
Communications
- Wireless
- Bluetooth, Wi-Fi
- Technology
- 2-cell Lithium Ion
- Installed Qty
- 1
- Capacity
- 26 Wh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 19.5 V, 2.31 A
Connections & Expansion
- USB 3.0 , Headphone/microphone combo jack , Mini-HDMI , 2 x dock , Micro-serial
- Memory Card Reader
- Yes (microSD)
- Dockable
- Security
- Included Accessories
- Power adapter
- Pricing Type
- BTO
- 1.62 kg
- Bundled Services
- -29 °C
- 63 °C
- 10 - 90% (non-condensing)
