Get crisp and fast color laser printing from the 5350dn monochrome laser printer from Dell. It lets you print delivering optimum performance every time you print. Designed to support high printing volumes and great usage demands, the 5350dn supports 4300-sheet maximum paper input capacity. It will address customer needs for consistent high performance, robust reliability on a single function printer.
The Dell 5350dn laser printer offers long-term value with consistent, reliable and economical service options for large workgroups that need to cut their printing costs without sacrificing high-speed, high-capacity performance.
The Dell 5350dn laser printer is designed for ease of use, with management tools, connectivity features and service options that help you set up fast and put your printers to work without delay.
The 5350dn laser printer is RoHS compliant and offers a variety of resource-saving features and green-minded services to promote environmental sustainability, including paper conservation and recycling.
Worth every penny
The Dell 5350dn laser printer offers long-term value with consistent, reliable and economical service options for large workgroups that need to cut their printing costs without sacrificing high-speed, high-capacity performance. -
Make it easy on yourself
The Dell 5350dn laser printer is designed for ease of use, with management tools, connectivity features and service options that help you set up fast and put your printers to work without delay. -
Eco-conscious printer
The 5350dn laser printer is RoHS compliant and offers a variety of resource-saving features and green-minded services to promote environmental sustainability, including paper conservation and recycling. -
Speed and quality
It generates razor-sharp, professional-quality prints with a max print resolution of up to 1200 x 1200 dpi. -
Fewer interruptions
A standard duplexer helps to decrease paper usage by allowing for automatic printing on both sides of a page. -
Saving paper
Paper trays support recycled paper while standard two-sided printing and a feature that allows several pages to be printed on one sheet help conserve paper.
- Dell 5350dn - printer - B/W - laser
- Printer Type
- Workgroup printer - laser - B/W
- 23 kg
- Media Size Class
- A4
- Max Media Size
- ANSI A (Letter) (216 x 279 mm)
- Print Speed
- Up to 50 ppm - ANSI A (Letter) (216 x 279 mm)
- Max Resolution (B&W)
- 1200 dpi
- Automatic Duplexing
- Interface
- USB, LAN, USB host
- Processor
- 500 MHz
- RAM Installed (Max)
- 128 MB (640 MB)
- Language Simulation
- PCL 5E, PostScript, Adobe PPDS, PCL
- Barcodes
- Code 3 of 9, OCR-A, OCR-B
- Media Type
- Envelopes, transparencies, labels, plain paper, heavy-weight paper, bond paper, recycled paper, cotton paper
- Total Media Capacity
- 650 sheets
- Media Handling
- 100-sheet multipurpose tray, 550-sheet input tray
- Monthly Duty Cycle (max)
- 225000 pages
- Networking
- Print server - Ethernet, Fast Ethernet
- System Requirements
- Red Hat Linux 5.0, Novell NetWare 5.x, Apple MacOS 9.x, Novell NetWare 6.x, HP-UX 11.11, SuSE Linux Enterprise Server 8, Microsoft Windows Server 2003 Terminal Server, HP-UX 11.23, Ubuntu 8.04 LTS, openSUSE 11.0, SuSE Linux Enterprise Server 9, SuSE Linux Enterprise Server 11, SUSE Linux Enterprise Desktop 11, Microsoft Windows 2000/XP/Vista/7, Microsoft Windows Server 2000 Terminal Server, SuSE Linux Enterprise Server 10, Microsoft Windows Server 2003 x64 Edition, Red Hat Linux 4, Red Hat Linux 3.0, Microsoft Windows Server 2008, Debian GNU/Linux 4.0, HP-UX 11.31, Apple MacOS X 10.2 - 10.6, Ubuntu 7.10
- 1-year warranty
- 42.5 cm x 51 cm x 42.7 cm
- Printer Type
- Workgroup printer - laser - monochrome
Printer
- Print Speed
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wired
- Interface
- 1200 dpi
- PostScript Support
- Standard
- Fonts Included
- 2 x bitmapped PCL , 39 x scalable PPDS , 5 x bitmapped PPDS , 84 x scalable PCL , 1 x PCL 5e
- Barcodes
- Media Handling
- Processor
- 500 MHz
RAM
- 128 MB / 640 MB (max)
Media Handling
- Media Type
- Media Size Class
- A4
- Max Media Size
- Media Sizes
- Media Weight
- 60 g/m² - 163 g/m²
- 650 sheets
- Media Feeders
- 1 x automatic - 100 sheets - Legal (216 x 356 mm) , 1 x automatic - 550 sheets - Legal (216 x 356 mm)
- Max Media Capacity
- 4300 sheets
- Output Trays Capacity
- 350 sheets
Duty Cycle
- 225000 pages
- Networking
- Print server
- Data Link Protocol
- Expansion Slots
- Memory
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45 , 1 x direct print port - 4 pin USB Type A
- Consumables Included
- 1 x toner cartridge - up to 10000 pages
- RoHS
- Power Device
- Power supply - internal
- Software Included
- Dell OpenManage, Dell Printer Configuration Web Tool
- OS Required
- Limited warranty - 1 year - on-site - response time: next business day , Technical support - web support - lifetime - availability: 24 hours a day / Monday-Sunday , Technical support - phone consulting - 1 year
- 42.5 cm
- 51 cm
- 42.7 cm
- 23 kg
