Dell Laser Printer 5350dn Mono Laser Printer
Quicklinx: 7QBPWS00 Mfr#: 210-36876
Get crisp and fast color laser printing from the 5350dn monochrome laser printer from Dell. It lets you print delivering optimum performance every time you print. Designed to support high printing volumes and great usage demands, the 5350dn supports 4300-sheet maximum paper input capacity. It will address customer needs for consistent high performance, robust reliability on a single function printer.
The Dell 5350dn laser printer offers long-term value with consistent, reliable and economical service options for large workgroups that need to cut their printing costs without sacrificing high-speed, high-capacity performance.
The Dell 5350dn laser printer is designed for ease of use, with management tools, connectivity features and service options that help you set up fast and put your printers to work without delay.
The 5350dn laser printer is RoHS compliant and offers a variety of resource-saving features and green-minded services to promote environmental sustainability, including paper conservation and recycling.
  • Worth every penny
  • Make it easy on yourself
  • Eco-conscious printer
  • Speed and quality
    It generates razor-sharp, professional-quality prints with a max print resolution of up to 1200 x 1200 dpi.
  • Fewer interruptions
    A standard duplexer helps to decrease paper usage by allowing for automatic printing on both sides of a page.
  • Saving paper
    Paper trays support recycled paper while standard two-sided printing and a feature that allows several pages to be printed on one sheet help conserve paper.
Dell 5350dn - printer - B/W - laser
Printer Type
Workgroup printer - laser - B/W
23 kg
Media Size Class
A4
Max Media Size
ANSI A (Letter) (216 x 279 mm)
Print Speed
Up to 50 ppm - ANSI A (Letter) (216 x 279 mm)
Max Resolution (B&W)
1200 dpi
Automatic Duplexing
USB, LAN, USB host
500 MHz
RAM Installed (Max)
128 MB (640 MB)
Language Simulation
PCL 5E, PostScript, Adobe PPDS, PCL
Barcodes
Code 3 of 9, OCR-A, OCR-B
Media Type
Envelopes, transparencies, labels, plain paper, heavy-weight paper, bond paper, recycled paper, cotton paper
Total Media Capacity
650 sheets
Media Handling
100-sheet multipurpose tray, 550-sheet input tray
Monthly Duty Cycle (max)
225000 pages
Print server - Ethernet, Fast Ethernet
Red Hat Linux 5.0, Novell NetWare 5.x, Apple MacOS 9.x, Novell NetWare 6.x, HP-UX 11.11, SuSE Linux Enterprise Server 8, Microsoft Windows Server 2003 Terminal Server, HP-UX 11.23, Ubuntu 8.04 LTS, openSUSE 11.0, SuSE Linux Enterprise Server 9, SuSE Linux Enterprise Server 11, SUSE Linux Enterprise Desktop 11, Microsoft Windows 2000/XP/Vista/7, Microsoft Windows Server 2000 Terminal Server, SuSE Linux Enterprise Server 10, Microsoft Windows Server 2003 x64 Edition, Red Hat Linux 4, Red Hat Linux 3.0, Microsoft Windows Server 2008, Debian GNU/Linux 4.0, HP-UX 11.31, Apple MacOS X 10.2 - 10.6, Ubuntu 7.10
1-year warranty
42.5 cm x 51 cm x 42.7 cm
Printer Type
Workgroup printer - laser - monochrome
Printer
Print Speed
Built-in Devices
Status LCD
Wired
USB, LAN, USB host
1200 dpi
Automatic Duplexing
PostScript Support
Standard
Language Simulation
Fonts Included
2 x bitmapped PCL , 39 x scalable PPDS , 5 x bitmapped PPDS , 84 x scalable PCL , 1 x PCL 5e
Barcodes
Media Handling
500 MHz
RAM
RAM Installed (Max)
128 MB / 640 MB (max)
Media Handling
Media Type
Media Size Class
A4
Max Media Size
Media Sizes
Media Weight
60 g/m² - 163 g/m²
650 sheets
Media Feeders
1 x automatic - 100 sheets - Legal (216 x 356 mm) , 1 x automatic - 550 sheets - Legal (216 x 356 mm)
Max Media Capacity
4300 sheets
Output Trays Capacity
350 sheets
Duty Cycle
225000 pages
Print server
Expansion Slots
1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45 , 1 x direct print port - 4 pin USB Type A
Consumables Included
1 x toner cartridge - up to 10000 pages
RoHS
Power supply - internal
Software Included
Dell OpenManage, Dell Printer Configuration Web Tool
Limited warranty - 1 year - on-site - response time: next business day , Technical support - web support - lifetime - availability: 24 hours a day / Monday-Sunday , Technical support - phone consulting - 1 year
42.5 cm
51 cm
42.7 cm
23 kg
