Power up your system for business trips and vacations with this 6-Cell Battery from Dell. With a capacity of 58 WHr this battery lets you work seamlessly when you are on the move. The integrated battery charge gauge lets you check the charge status of an installed or uninstalled battery at any time.
- Dell - laptop battery - Li-Ion - 58 Wh
- Laptop battery
- Battery
- Lithium Ion 6-cell - 58 Wh
- 3-year warranty
- Designed For
- Latitude E6220, E6320, E6320 N-Series
- Laptop battery
- Technology
- 6-cell Lithium Ion
- Capacity
- 58 Wh
- Limited warranty - 3 years
- Designed For
- Dell Latitude E6220, E6320, E6320 N-Series
