The Dell Wired Keyboard provides a convenient keyboard solution for everyday home or office computing uses. The keyboard's full layout with chiclet style keys allows for efficient, comfortable typing - excellent for everyday usage on virtually any task at hand.
Wired keyboard for everyday home or office use
The Dell Wired Keyboard provides a convenient keyboard solution for everyday home or office computing uses. The keyboard's full layout with chiclet style keys allows for efficient, comfortable typing - excellent for everyday usage on virtually any task at hand. -
Multimedia keys for quick actions and commands
The convenient multimedia keys let you easily access functions such as play, pause, rewind, and fast-forward plus volume control. -
Comfortable, desk-centric design
With a compact design that still features a full-sized keyboard and number pad, the Dell Wired Keyboard is ideal for home and office environments. With a durable build and quiet keys, it's designed to provide comfort for the everyday demands of desktop usage. The Dell Wired Keyboard also has a palm rest that is available for separate purchase.
 - Dell KB216 - keyboard - black Input Device
 - Keyboard
- Interface
 - USB
- Connectivity Technology
 - Wired
- Hot Keys Function
 - Volume, mute, play/pause, backward, forward
- Keys Style
 - Chiclet
 - Black
 - 44.2 cm x 12.7 cm x 2.44 cm
 - 503 g
 - 1-year warranty
 - Keyboard
- Interface
 - USB
- Hot Keys Function
- Keys Style
 - Chiclet
 - 44.2 cm
 - 12.7 cm
 - 2.44 cm
 - 503 g
 - Black
- Cables Included
 - 1 x USB cable
 - Limited warranty - 1 year
