Dell Inspiron 3030 SFF Intel Core i3-12100 8GB 512GB SSD Windwos 11 Professional
Quicklinx: J0HJWS00 Mfr#: 6C7RM
  • Core i3
  • IEEE 802.11n
The Dell Inspiron 3030 offers efficiency and convenience in a compact package. Designed to fit perfectly in small spaces, this personal computer delivers solid performance with its 12th Generation Intel Core i3 processor and 8 GB of DDR5 RAM. It features a 512 GB NVMe SSD for quick access to storage needs with reduced loading times.
High-speed connectivity is a key feature of the Inspiron 3030, with USB 3.2 Gen 1 and USB-C ports, alongside Wi-Fi 6 capabilities, ensuring fast and reliable Internet and peripheral connections. The Intel UHD Graphics 730 with shared video memory provides smooth visuals for presentations, streaming media, or light graphic design.
With ENERGY STAR certification, the Dell Inspiron 3030 is not only efficient but also energy-efficient, making it a suitable choice for environmentally conscious users looking for a high-performance, space-saving desktop solution.
  • Compact design
    The Dell Inspiron 3030 stands out with its small form factor, making it an ideal choice for users with limited space. Its sleek design allows for easy placement on any desk or small workspace, without compromising on performance.
  • High-speed connectivity
    Equipped with USB 3.2 Gen 1 and USB-C 3.2 Gen 1 ports, alongside Gigabit Ethernet, this device ensures high-speed connections to a variety of peripherals. The inclusion of Wi-Fi 6 support further enhances its wireless connectivity, offering faster Internet speeds and improved network efficiency.
  • Efficient performance
    Powered by a 12th Generation Intel Core i3 processor and 8 GB of DDR5 RAM, the Dell Inspiron 3030 delivers efficient performance for everyday tasks. Whether it's for work or play, this computer handles applications smoothly, ensuring a seamless user experience.
  • Ample storage with fast access
    With a 512 GB NVMe SSD, users benefit from ample storage space for their files and quick boot times. The SSD's fast data access speeds significantly reduce loading times for applications and files, making this computer a productive tool for any task.
  • Enhanced visuals
    The Intel UHD Graphics 730 provides reliable image quality for everyday computing needs. From streaming videos to light graphic work, the shared video memory (UMA) ensures smooth visual performance on connected DisplayPort and HDMI displays.
Dell Inspiron 3030 - SFF Core i3 12100 3.3 GHz - 8 GB - SSD 512 GB
Personal computer - SFF
Bundled Services
1 Year Basic Onsite
Intel Core i3 (12th Gen) 12100 / 3.3 GHz (up to 4.3 GHz, (Quad-Core)
Cache Memory
12 MB
Cache Per Processor
12 MB
RAM
8 GB (installed) / 64 GB (max) - DDR5 SDRAM
Storage Controller
SATA
Hard Drive
SSD 512 GB - PCI Express - M.2 - NVM Express (NVMe)
Optical Storage
No optical drive
Card Reader
Graphics Controller
Intel UHD Graphics 730 Shared Video Memory (UMA)
1GbE, Bluetooth, 802.11a, 802.11b/g/n, Wi-Fi 5, Wi-Fi 6
(50/60 Hz)
OS Provided
Windows 11 Pro
Software Included
McAfee Business Protection (1-year), Activate your Microsoft 365 for a 30 day trial
Black, black (keyboard)
9.26 cm x 29.2 cm x 29 cm
4.72 kg
Pricing Type
Build To Stock (BTS)
Environmental Standards
ENERGY STAR Qualified
Carbon Footprint
173 kg carbon emissions
Personal computer
Bundled Services
1 Year Basic Onsite
Product Form Factor
SFF
Embedded Security
Firmware Trusted Platform Module (TPM 2.0) Security Chip
Processor / Chipset
CPU
Clock Speed
3.3 GHz
Max Turbo Speed
4.3 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
Chipset Type
Intel B660
Cache Memory
Installed Size
12 MB
Cache Per Processor
12 MB
RAM
Installed Size
DDR5 SDRAM
Effective Memory Speed
2200 MHz
Rated Memory Speed
2200 MHz
DIMM 288-pin
Slots
2 (Total) / 1 (empty)
Configuration Features
1 x 8 GB
Hard Drive
SSD - M.2
1 x 512 GB
Interface Type
PCI Express
NVM Express (NVMe)
Storage Controller
1 x SATA
Optical Storage
No optical drive
Card Reader
Card reader
Supported Flash Memory Cards
SD Memory Card, SDHC Memory Card, SDXC Memory Card
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Video Interfaces
HDMI, DisplayPort
Audio Output
High Definition Audio
Input Device
Mouse (on selected markets only), keyboard (on selected markets only)
Keyboard
Keyboard Name
Dell KB216 Multimedia Keyboard
Mouse
Mouse Name
Dell MS116 USB Optical Mouse
Optical
USB
Interface (Bus) Type
M.2 2230
Ethernet Controller
Realtek RTL8111KD
Wireless LAN Supported
Wireless NIC
Realtek RTL8852BE
Ethernet, Fast Ethernet, Gigabit Ethernet, Bluetooth, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, IEEE 802.11ax (Wi-Fi 6)
MU-MIMO Support, dual stream (2x2)
Bays
1 (total) / 1 (free) x internal 3.5" , 1 (total) / 1 (free) x external
Slots
1 (total) / 0 (free) x M.2 Card - 2230/2280 (for SSD) , 1 (total) / 0 (free) x M.2 Card - 2230 (for wireless module) , 1 PCIe x16 , 1 PCIe x1
1 x LAN (Gigabit Ethernet) , 3 x USB 3.2 Gen 1 , 2 x USB 2.0 , 2 x USB 2.0 (Power on/Wake-up support) , 1 x USB-C 3.2 Gen 1 , 1 x headphones/microphone , 1 x audio line-out , 1 x DisplayPort 1.4 , 1 x HDMI
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), padlock loop
Security Slot Type
Kensington security slot
Pricing Type
Power supply
AC 90-264 V (50/60 Hz)
Power Provided
180 watt
80 PLUS Certification
80 PLUS Bronze
Efficiency
85%
Operating System / Software
OS Provided
Windows 11 Pro English / French / Spanish / Portuguese / Italian
Software
Sustainability Information
ENERGY STAR Certified
Carbon Footprint
Manufacturing (kg CO2e)
91.863
Logistics (kg CO2e)
10.726
Use (kg CO2e)
66.605
EOL (kg CO2e)
3.979
Total Carbon w/o Use Phase (kg CO2e)
106.4
PAIA Version
GaBi version 1, 2024
9.26 cm
29.2 cm
29 cm
4.72 kg
10 °C
35 °C
20 - 80% (non-condensing)
Accessories (1)
J0HJ Dell Dual Monitor Stand - MDS19 In Stock £129.07
Monitors (3)
J0HJ Dell P2725H 27"1920x1080 5ms VGA HDMI DisplayPort IPS LED Monitor In Stock £139.87
J0HJ Dell P2425H 24" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Monitor In Stock £119.24
J0HJ Dell Pro E2425HM 24" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Monitor In Stock £77.71
Keyboards and Mice (7)
J0HJ Dell Pro KM5221W Keyboard and Mouse Set - QWERTY - UK - Black In Stock £38.39
J0HJ Dell Wireless Keyboard and Mouse KM7120W - UK - Titan Grey In Stock £44.32
J0HJ Dell MS5120W Mobile Pro Wireless Mouse In Stock £20.80
J0HJ Dell Premier Multi-Device KM7321W Wireless Keyboard and Mouse In Stock £57.37
J0HJ Dell Multi-Device KB700 - Keyboard - wireless - 2.4 GHz, Bluetoot In Stock £43.95
J0HJ Dell Dell Mobile Wireless Mouse - MS3320W - Black In Stock £11.66
J0HJ Dell Dell Pro Wireless Mouse MS5120W Black In Stock £25.08
Other bundles (2)
J0HJ Dell WEBCAM - WB3023 In Stock £47.02
J0HJ Dell Dell Speakerphone SP3022 In Stock £61.06
