The compact Dell adapter - USB 3.0 to HDMI/VGA/Ethernet/USB 2.0 Slayer offers a plug-and-play solution for connecting your laptop or notebook to an external display and other essential devices. It also features an Ethernet port, which means it can replace as many as three dongles to save you space on your desk and in your bag. Onboard USB 2.0 means you still have an open port to connect with USB peripherals.
Replaces need for multiple adaptors
The compact Dell adapter - USB 3.0 to HDMI/VGA/Ethernet/USB 2.0 offers a plug-and-play solution for connecting your laptop or notebook to an external display and other essential devices. The adapter also features an Ethernet port, which means it can replace as many as three dongles to save you space on your desk and in your bag. Onboard USB 2.0 means you still have an open port to connect with USB peripherals. -
Choose from VGA or HDMI video output
Choose from available VGA and HDMI ports to connect your mobile computer to an external monitor. The Dell Adapter gives you the flexibility to use a wide variety of monitors to expand your desktop and stay productive while managing multiple applications. -
Ethernet port connects to wired networks
The Dell Adapter - USB 3.0 to HDMI/VGA/Ethernet/USB 2.0 lets you connect to wired networks via an Ethernet port when needed. This ensures you can connect to the Internet and stay productive in virtually any environment. -
USB 2.0 port lets you connect to more peripherals
With the Dell adapter you can add productivity options without sacrificing USB connectivity. Using the included USB 2.0 port, you're free to connect to a range of everyday peripherals, such as printers, scanners, and external hard drives.
- Dell DA100 - external video adapter - black
- External video adapter
- Bus Type
- SuperSpeed USB 3.0
- Interfaces Details
- VGA , Network , USB 2.0 , HDMI
- 6.5 cm x 1.7 cm x 6.5 cm
- Enclosure Colour
- Black
- Designed For
- Inspiron 14 3451, 15 3551, 17 7778 2-in-1, 5458, 5555, 5558, 5559, 5759, 7559; Latitude 13 7350, 3570, 7370, E5250, E5270, E5440, E5450, E5470, E5540, E5550, E5570, E7250, E7270, E7450, E7470; Precision 3510, 5510, 7510, 7710; Venue 10 5050, 10 Pro, 11 Pro, 8 Pro; Vostro 3558, 3559, 5459; XPS 13, 15
- Bus Type
- USB powered
- OS Required
- Microsoft Windows 7 / 8 / 8.1
- Min Processor Type
- 1.6 GHz
- Plug and Play
- 6.5 cm
- 1.7 cm
- 6.5 cm
- 45.5 g
- Enclosure Colour
- Black
- Designed For
- Dell Inspiron 14 3451, 15 3551, 17 7778 2-in-1, 5458, 5555, 5558, 5559, 5759, 7559 , Dell Latitude 13 7350, 3570, 7370, E5250, E5270, E5440, E5450, E5470, E5540, E5550, E5570, E7250, E7270, E7450, E7470 , Dell Precision 3510, 5510, 7510, 7710 , Dell Venue 10 5050, 10 Pro (5050), 10 Pro (5055), 10 Pro (5056), 11 Pro (5055), 11 Pro (7140), 8 Pro (5855) , Dell Vostro 3558, 3559, 5459 , Dell XPS 13, 13 (9333), 13 (9343), 15 (9530)
