Your basket is empty
Dell Extended I/O Module for Latitude 12 Rugged Tablet 7202
Quicklinx: C36NWS00 Mfr#: 565-BBCE
The Latitude 12 Rugged Tablet features the ability to connect modules that expand the functionality of the system. The Extended I/O Module adds two USB 3.0 ports and an Ethernet port to your Rugged Tablet. The module attaches securely to the back of the tablet when additional ports are needed and can be easily removed when not.
Dell Extended I/O Module - port replicator
Port replicator
20.2 cm x 5.5 cm x 2.2 cm
144 g
Port replicator
20.2 cm
5.5 cm
2.2 cm
144 g
2 x SuperSpeed USB 3.0 , 1 x network - Ethernet - RJ-45
Dell Latitude 12 Rugged Tablet 7202
C36N C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.09
