Dell E525w Colour Laser Multifunction Printer
Quicklinx: BKFXWS00 Mfr#: 210-AEHD
Versatility, value and ease for brilliant everyday performance! Simplify everyday printing and imaging tasks with a space-saving, 4-in-1 color multifunction printer with essential productivity features that let you accomplish more.
  • Easy set up
    Get your printer up and running easily with the Dell Printer Easy Installer.
  • Connect and share your printer with ease
    Get flexible connectivity with USB, Wi-Fi and Ethernet options.
  • Dell Printer Hub - your complete printer software
    Declutter your desktop with one intuitive interface for all your printing needs. This one-stop, complete solution integrates printer essentials and cloud connectivity for easy document management and control of your printer.
  • Stay up and running with automatic alerts
    With the Dell Printer Hub, you will get automatic alerts when firmware and software updates are available, or when toner runs low. Toner reordering is convenient with direct access to compatible toners. To reduce maintenance, the E525w comes with a single fuser unit that is designed to last the life of the printer.
  • Multitask with ease
    Print wirelessly, scan, copy and fax with one affordable, space-saving device. Initiate tasks quickly using the four-line high contrast LCD display and 35 button control panel.
  • Brilliant results at fast speeds
    Get crisp text and vivid color prints at superb speeds of up to 18ppm (black/color). Scan documents quickly at up to 17/7ipm (black/color).
  • Secure print release
    Keep sensitive documents private using the Secure Print feature. With this security feature, print jobs are password protected and released in 3 easy steps: select Secure Print on the control panel; key in the valid user PIN on the 10 digit keypad; choose the document and print.
  • Enhanced copy feature
    The "ID Copy" button allows you to copy both sides of an ID card on a single side of paper.
  • Easy paper handling
    Minimize effort with the ADF for unattended faxing, scanning and copying. This printer also features a robust cassette input paper tray that helps keep paper dust free.
  • On-the-go convenience
    Print directly from compatible mobile devices with the Dell Document Hub app (compatible with Android, iOS and Windows 8 and later). This printer also supports AirPrint, and Google Cloud Print, so you can print from virtually anywhere.
  • High duty cycles
    With a duty cycle of 30,000 pages per month, you can rely on this printer to handle everyday work demands.
  • Reduced energy consumption
    Low-melt toner technology means less heating, reduced warm-up times and faster first-page-out time (FPOT).
  • Eco-conscious design
    The E525w meets the latest regulatory and environmental standards, including ENERGY STAR qualification, Restriction of Hazardous Substances (RoHS) compliance and EPEAT Bronze registration.
  • Minimal upkeep
    With a single drum/fuser unit designed to last the life of the printer, all you have to replace are the toner cartridges when you receive the low toner alert via Dell Printer Hub. For optimal print results, always choose Dell original toners.
Dell E525w - multifunction printer - colour
Multifunction printer
Fax Type
Super G3 - plain paper
Printing Technology
Laser (colour)
Monthly Duty Cycle (max)
30000 pages
Recommended Monthly Volume
250 - 700 pages
Max Copying Speed
Up to 18 ppm (mono) / up to 18 ppm (colour)
Max Copying Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed
Max Printing Resolution
Up to 600 x 600 dpi
Max Fax Transmission Speed
33.6 Kbps
Data Compression System
MH, MR, MMR, JBIG, JPEG
Fax Resolutions
200 x 400 dpi, 200 x 200 dpi, 200 x 100 dpi, 400 x 400 dpi
Scanning
1200 x 1200 dpi
Original Size
139.7 x 139.7 mm (min) - 216 x 356 mm (max)
Document Feeder Capacity
15 sheets
Media Size
76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, labels, recycled paper, thick paper
Standard Media Capacity
150 sheets
Max Media Capacity
150 sheets
Output Trays Capacity
100 sheets
Connection Availability
USB 2.0, LAN, Wi-Fi(n), USB 2.0 host
AC 230 V (50/60Hz)
41 cm x 39.8 cm x 35.3 cm
16.1 kg
Environmental Standards
ENERGY STAR Qualified
1-year warranty
Fax Type
Plain paper
Printing Technology
Laser - colour
30000 pages
250 - 700 pages
Display
4 lines x 20 characters
Standard Memory
512 MB
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Exposure Modes
Text, photo, text and photo
Printing
Up to 600 x 600 dpi
Max Printing Speed
Printer Drivers / Emulations
PCL 5e, PCL 6, PostScript 3, XPS
Scanning
Optical Resolution
1200 x 1200 dpi
Interpolated Resolution
4800 x 4800 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Fax Resolutions
Document & Media Handling
Min Original Size
139.7 x 139.7 mm
Max Original Size
216 x 356 mm
15 sheets
Min Media Size
76.2 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
163 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), Folio (216 x 330 mm)
Supported Envelope Sizes
US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
150 sheets
Max Media Capacity
150 sheets
100 sheets
Input tray - 250 sheets size: 76.2 x 127 mm - 215.9 x 355.6 mm weight: 60 g/m² - 163 g/m² , Output tray - 150 sheets , ADF - 15 sheets
Speed Details
Printing: up to 18 ppm - B/W , Printing: up to 18 ppm - colour , Scanning: up to 17 ipm - B/W , Scanning: up to 7 ipm - colour , Copying: up to 18 ppm - colour , Copying: up to 18 ppm - B/W
1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45 , 1 x USB 2.0 host - 4 pin USB Type A
Operating System Support
Apple Mac OS X 10.6, MS Windows, Ubuntu Linux 12.04, MS Windows Server 2012 x64 Edition, MS Windows Server 2003 (32/64-bits), MS Windows Server 2008 (32/64-bits), MS Windows Server 2012 R2 x64 Edition, MS Windows XP (32/64 bits), MS Windows Vista (32/64 bits), MS Windows 7 (32/64 bits), SUSE Linux Enterprise Desktop 11 (32/64-bit), Apple Mac OS X 10.10, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits)
AC 230 V (50/60Hz)
280 Watt
Power Consumption Standby
40 Watt
Power Consumption Sleep
10 Watt
USB cable, phone cable
Consumables Included
1 x toner cartridge (black) - up to 700 pages , 1 x toner cartridge (cyan) - up to 700 pages , 1 x toner cartridge (magenta) - up to 700 pages , 1 x toner cartridge (yellow) - up to 700 pages
EN 61000-3-2, NOM, EN 61000-3-3, EN55024, EN55022 Class B, RoHS, FCC Part 2, IEC 60950-1, EN 60950-1, WEEE, REACH, CAN/CSA C22.2 No. 60950-1-07
ENERGY STAR Certified
Limited warranty - 1 year
41 cm
39.8 cm
35.3 cm
16.1 kg
Shipping Width
56.1 cm
Shipping Depth
54.9 cm
Shipping Height
52 cm
Shipping Weight
19.4 kg
5 °C
32 °C
15 - 85% (non-condensing)
BKFX C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.91
