Versatility, value and ease for brilliant everyday performance! Simplify everyday printing and imaging tasks with a space-saving, 4-in-1 color multifunction printer with essential productivity features that let you accomplish more.
Easy set up
Get your printer up and running easily with the Dell Printer Easy Installer. -
Connect and share your printer with ease
Get flexible connectivity with USB, Wi-Fi and Ethernet options. -
Dell Printer Hub - your complete printer software
Declutter your desktop with one intuitive interface for all your printing needs. This one-stop, complete solution integrates printer essentials and cloud connectivity for easy document management and control of your printer. -
Stay up and running with automatic alerts
With the Dell Printer Hub, you will get automatic alerts when firmware and software updates are available, or when toner runs low. Toner reordering is convenient with direct access to compatible toners. To reduce maintenance, the E525w comes with a single fuser unit that is designed to last the life of the printer. -
Multitask with ease
Print wirelessly, scan, copy and fax with one affordable, space-saving device. Initiate tasks quickly using the four-line high contrast LCD display and 35 button control panel. -
Brilliant results at fast speeds
Get crisp text and vivid color prints at superb speeds of up to 18ppm (black/color). Scan documents quickly at up to 17/7ipm (black/color). -
Secure print release
Keep sensitive documents private using the Secure Print feature. With this security feature, print jobs are password protected and released in 3 easy steps: select Secure Print on the control panel; key in the valid user PIN on the 10 digit keypad; choose the document and print. -
Enhanced copy feature
The "ID Copy" button allows you to copy both sides of an ID card on a single side of paper. -
Easy paper handling
Minimize effort with the ADF for unattended faxing, scanning and copying. This printer also features a robust cassette input paper tray that helps keep paper dust free. -
On-the-go convenience
Print directly from compatible mobile devices with the Dell Document Hub app (compatible with Android, iOS and Windows 8 and later). This printer also supports AirPrint, and Google Cloud Print, so you can print from virtually anywhere. -
High duty cycles
With a duty cycle of 30,000 pages per month, you can rely on this printer to handle everyday work demands. -
Reduced energy consumption
Low-melt toner technology means less heating, reduced warm-up times and faster first-page-out time (FPOT). -
Eco-conscious design
The E525w meets the latest regulatory and environmental standards, including ENERGY STAR qualification, Restriction of Hazardous Substances (RoHS) compliance and EPEAT Bronze registration. -
Minimal upkeep
With a single drum/fuser unit designed to last the life of the printer, all you have to replace are the toner cartridges when you receive the low toner alert via Dell Printer Hub. For optimal print results, always choose Dell original toners.
- Dell E525w - multifunction printer - colour
- Multifunction printer
- Fax Type
- Super G3 - plain paper
- Printing Technology
- Laser (colour)
- Monthly Duty Cycle (max)
- 30000 pages
- Recommended Monthly Volume
- 250 - 700 pages
- Max Copying Speed
- Up to 18 ppm (mono) / up to 18 ppm (colour)
- Max Copying Resolution
- Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
- Max Printing Speed
- Max Printing Resolution
- Max Fax Transmission Speed
- 33.6 Kbps
- Data Compression System
- MH, MR, MMR, JBIG, JPEG
- Fax Resolutions
- 200 x 400 dpi, 200 x 200 dpi, 200 x 100 dpi, 400 x 400 dpi
- Scanning
- 1200 x 1200 dpi
- Original Size
- 139.7 x 139.7 mm (min) - 216 x 356 mm (max)
- Document Feeder Capacity
- 15 sheets
- Media Size
- 76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, plain paper, labels, recycled paper, thick paper
- Standard Media Capacity
- 150 sheets
- Max Media Capacity
- 150 sheets
- Output Trays Capacity
- 100 sheets
- Connection Availability
- Interface
- USB 2.0, LAN, Wi-Fi(n), USB 2.0 host
- Power
- AC 230 V (50/60Hz)
- 41 cm x 39.8 cm x 35.3 cm
- 16.1 kg
- Environmental Standards
- ENERGY STAR Qualified
- 1-year warranty
- Fax Type
- Plain paper
- Laser - colour
- 30000 pages
- 250 - 700 pages
- Display
- 4 lines x 20 characters
- Interface
- Standard Memory
- 512 MB
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
- Exposure Modes
- Text, photo, text and photo
Printing
- Printer Drivers / Emulations
- PCL 5e, PCL 6, PostScript 3, XPS
Scanning
- Optical Resolution
- 1200 x 1200 dpi
- Interpolated Resolution
- 4800 x 4800 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
- Fax Resolutions
Document & Media Handling
- Min Original Size
- 139.7 x 139.7 mm
- Max Original Size
- 216 x 356 mm
- 15 sheets
- Min Media Size
- 76.2 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 163 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), Folio (216 x 330 mm)
- Supported Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
- 150 sheets
- 150 sheets
- 100 sheets
- Input tray - 250 sheets size: 76.2 x 127 mm - 215.9 x 355.6 mm weight: 60 g/m² - 163 g/m² , Output tray - 150 sheets , ADF - 15 sheets
- Speed Details
- Printing: up to 18 ppm - B/W , Printing: up to 18 ppm - colour , Scanning: up to 17 ipm - B/W , Scanning: up to 7 ipm - colour , Copying: up to 18 ppm - colour , Copying: up to 18 ppm - B/W
- 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45 , 1 x USB 2.0 host - 4 pin USB Type A
- Operating System Support
- Apple Mac OS X 10.6, MS Windows, Ubuntu Linux 12.04, MS Windows Server 2012 x64 Edition, MS Windows Server 2003 (32/64-bits), MS Windows Server 2008 (32/64-bits), MS Windows Server 2012 R2 x64 Edition, MS Windows XP (32/64 bits), MS Windows Vista (32/64 bits), MS Windows 7 (32/64 bits), SUSE Linux Enterprise Desktop 11 (32/64-bit), Apple Mac OS X 10.10, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits)
- Voltage Required
- 280 Watt
- Power Consumption Standby
- 40 Watt
- Power Consumption Sleep
- 10 Watt
- Included Accessories
- USB cable, phone cable
- Consumables Included
- 1 x toner cartridge (black) - up to 700 pages , 1 x toner cartridge (cyan) - up to 700 pages , 1 x toner cartridge (magenta) - up to 700 pages , 1 x toner cartridge (yellow) - up to 700 pages
- EN 61000-3-2, NOM, EN 61000-3-3, EN55024, EN55022 Class B, RoHS, FCC Part 2, IEC 60950-1, EN 60950-1, WEEE, REACH, CAN/CSA C22.2 No. 60950-1-07
- ENERGY STAR Certified
- Limited warranty - 1 year
- 41 cm
- 39.8 cm
- 35.3 cm
- 16.1 kg
- Shipping Width
- 56.1 cm
- Shipping Depth
- 54.9 cm
- Shipping Height
- 52 cm
- Shipping Weight
- 19.4 kg
- 5 °C
- 32 °C
- 15 - 85% (non-condensing)
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.91 |
