Dell E515dw Mono Laser Multifunction Printer
Quicklinx: BKG6WS00 Mfr#: 210-AEHU
For added ease, the Dell Multifunction Printer - E515dw comes with enhanced 1-click features ideal for your everyday printing and imagining needs.
Essential, easy-to-use features allow you to print wirelessly, 1 scan, copy and fax, giving your workgroup added versatility and a boost in and productivity.
Gain peace of mind and additional savings with a dependable and environmentally conscious multifunction printer.
  • Simple set up
    Get your printer up and running easily with the Dell Printer Easy Installer.
  • Convenient connectivity
    Get flexible connectivity with wireless, USB and Ethernet options.
  • Efficiency made easy with Dell Printer Hub
    Declutter your desktop with one intuitive interface for all your printing needs. This one-stop, complete solution integrates printer essentials and cloud connectivity for easy document management and control of your printer.
  • Hassle-free paper handling
    Fax, scan or copy up to 35 sheets hands-free with the automatic document feeder (ADF) and reduce paper use up to 50% thanks to automatic two-sided printing. The E515dw also features a robust cassette input paper tray that helps keep paper free from dust.
  • Enhanced copy feature
    The "ID Copy" button allows you to copy both sides of an ID card on a single side of paper.
  • On-the-go convenience
    Print directly from compatible mobile devices with the Dell Document Hub app (compatible with Android, iOS and Windows 8 and later). This printer also supports AirPrint, Google Cloud Print and Mopria, so you can print from virtually anywhere.
  • Additional savings
    The optional high yield black toner cartridge lets you print up to 2,600 pages for greater savings. For optimal print results, always use Dell original toners.
  • Eco-conscious design
    The E515dw meets the regulatory and environmental standards, including ENERGY STAR qualification and Restriction of Hazardous Substances (RoHS) compliance. This printer also supports printing on recycled, renewable content and chlorine-free paper.
Dell E515dw - multifunction printer - B/W
Multifunction printer
Fax Type
Super G3 - plain paper
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
10000 pages
Recommended Monthly Volume
300 - 1000 pages
Max Copying Speed
Up to 20 ppm
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 27 ppm
Max Printing Resolution
Up to 2400 x 600 dpi
Max Fax Transmission Speed
33.6 Kbps
Scanning
600 x 1200 dpi
Original Size
210 x 350 mm (max)
Document Feeder Capacity
35 sheets
Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, labels, recycled paper, bond paper, thick paper
Standard Media Capacity
250 sheets
Bypass Feeder Capacity
1 sheet
Output Trays Capacity
100 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
USB 2.0, LAN, Wi-Fi(n)
Office Machine Features
Scan to folder, scan to FTP
AC 230 V (50/60Hz)
40.9 cm x 39.85 cm x 31.65 cm
11.5 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
Fax Type
Plain paper
Printing Technology
Laser - monochrome
10000 pages
300 - 1000 pages
Display
2 lines
Standard Memory
64 MB
Copying
Max Copying Speed
Up to 20 ppm
Up to 600 x 600 dpi
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Copying Features
ID Card Copy, Sort
Printing
Max Printing Speed
Up to 27 ppm
Printer Drivers / Emulations
PCL 6, PostScript 3, XPS
Automatic Duplexing
Scanning
Scan Element
CIS
Optical Resolution
600 x 1200 dpi
Interpolated Resolution
19200 x 19200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Fax Machine Features
Speed Dialing
200 station(s)
Broadcast Transmission
Fax forwarding
Document & Media Handling
Max Original Size
210 x 350 mm
35 sheets
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
105 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), JIS B5 (182 x 257 mm)
250 sheets
1 sheet
100 sheets
Input tray - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 80 g/m² , Bypass tray - 1 sheet - Legal (216 x 356 mm) weight: 60 g/m² - 105 g/m²
Speed Details
Printing: up to 27 ppm (Letter A) - B/W , Printing: up to 26 ppm (A4) - B/W , Printing: up to 15 ppm (Letter A) - B/W duplex , Printing: up to 13 ppm (A4) - B/W duplex , Scanning: up to 17 ipm - B/W , Scanning: up to 6 ipm - colour , Copying: up to 20 ppm (Letter A) , Copying: up to 19 ppm (A4)
1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
Security Protocols & Features
WPS, Wi-Fi Direct
Operating System Support
MS Windows Server 2003, MS Windows 7, MS Windows Vista, MS Windows Server 2003 x64 Edition, MS Windows Server 2008, MS Windows Server 2008 R2, Apple Mac OS X 10.7.x, Ubuntu Linux 12.04, Apple Mac OS X 10.8.x, MS Windows Server 2012, Windows 8, Red Hat Enterprise Linux 6 Desktop, Windows 8.1, MS Windows Server 2012 R2, Apple Mac OS X 10.9.x, SUSE Linux Enterprise Desktop 11 (32/64-bit), Apple Mac OS X 10.10
AC 230 V (50/60Hz)
480 Watt
Power Consumption Standby
60 Watt
Power Consumption Sleep
6.6 Watt
USB cable, phone cable
Consumables Included
1 x toner cartridge (black) - up to 700 pages
VCCI, C-Tick, NOM, SEMKO, FCC, R&TTE, RoHS, WEEE, FDA, cTUVus, ERP, ICASA
ENERGY STAR Certified
40.9 cm
39.85 cm
31.65 cm
11.5 kg
Shipping Width
62.3 cm
Shipping Depth
51.7 cm
Shipping Height
49.9 cm
Shipping Weight
15.6 kg
Sound Emission
33 dB (idle) / 50 dB (operating)
10 °C
32.5 °C
10 - 80%
BKG6 C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.91
