For added ease, the Dell E515dn multifunction printer comes with enhanced one-click features, great for your everyday printing and imagining needs.
Simple set up
Get your printer up and running quickly with the Dell's easy installation. -
Sharable printing
Ethernet connectivity allows you to conveniently share your printer. -
Hassle-free paper handling
Fax, scan or copy hands-free with the automatic document feeder and reduce paper use thanks to automatic two-sided printing. The E515dn also features a robust cassette input paper tray that helps keep paper free from dust. -
Enhanced copy features
The "ID Copy" button allows you to copy both sides of an ID card on a single side of paper.
- Dell E515dn - multifunction printer - B/W
- Multifunction printer
- Fax Type
- Super G3 - plain paper
- Printing Technology
- Laser (monochrome)
- Monthly Duty Cycle (max)
- 10000 pages
- Recommended Monthly Volume
- 300 - 1000 pages
- Max Copying Speed
- Up to 20 ppm
- Max Copying Resolution
- Up to 600 x 600 dpi
- Max Printing Speed
- Up to 27 ppm
- Max Printing Resolution
- Up to 2400 x 600 dpi
- Max Fax Transmission Speed
- 33.6 Kbps
- Scanning
- 600 x 1200 dpi
- Original Size
- 210 x 350 mm (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 35 sheets
- Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, plain paper, labels, recycled paper, bond paper, thick paper
- Standard Media Capacity
- 250 sheets
- Max Media Capacity
- 251 sheets
- Bypass Feeder Capacity
- 1 sheet
- Output Trays Capacity
- 100 sheets
- Automatic Duplexing
- Yes (printing)
- Connection Availability
- Interface
- USB 2.0, LAN
- Office Machine Features
- Scan to folder, scan to FTP
- Power
- AC 230 V (50/60Hz)
- 40.9 cm x 39.85 cm x 31.65 cm
- 11.5 kg
- Environmental Standards
- ENERGY STAR Qualified, Blue Angel
- 1-year warranty
- Fax Type
- Plain paper
- Laser - monochrome
- 10000 pages
- 300 - 1000 pages
- Display
- 2 lines
- Interface
- USB 2.0, LAN
- Standard Memory
- 64 MB
Copying
- Max Copying Speed
- Up to 20 ppm
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
- Exposure Modes
- Text, photo, text and photo
- Copying Features
- 2 on 1, 4 on 1, ID Card Copy
Printing
- Up to 27 ppm
- Printer Drivers / Emulations
- PCL 6, PostScript 3, XPS
Scanning
- Scan Element
- CIS
- Optical Resolution
- 600 x 1200 dpi
- Interpolated Resolution
- 19200 x 19200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
Document & Media Handling
- Max Original Size
- 210 x 350 mm
- Original Type
- Sheets
- 35 sheets
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 105 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), JIS B5 (182 x 257 mm)
- 250 sheets
- 251 sheets
- 1 sheet
- 100 sheets
- Input tray - 250 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 80 g/m² , Bypass tray - 1 sheet weight: 60 g/m² - 105 g/m²
- Speed Details
- Printing: up to 27 ppm (Letter A) - B/W , Printing: up to 26 ppm (A4) - B/W , Printing: up to 15 ppm (Letter A) - B/W duplex , Printing: up to 13 ppm (A4) - B/W duplex , Scanning: up to 17 ipm - B/W , Scanning: up to 6 ipm - colour , Copying: up to 20 ppm (Letter A) , Copying: up to 19 ppm (A4)
- 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
- Operating System Support
- MS Windows Server 2003, MS Windows 7, MS Windows Vista, MS Windows Server 2003 x64 Edition, MS Windows Server 2008, MS Windows Server 2008 R2, Apple Mac OS X 10.7.x, Ubuntu Linux 12.04, Apple Mac OS X 10.8.x, MS Windows Server 2012, Windows 8, Red Hat Enterprise Linux 6 Desktop, Windows 8.1, MS Windows Server 2012 R2, Apple Mac OS X 10.9.x, SUSE Linux Enterprise Desktop 11 (32/64-bit), Apple Mac OS X 10.10
- Voltage Required
- 480 Watt
- Power Consumption Standby
- 60 Watt
- Power Consumption Sleep
- 6.6 Watt
- Included Accessories
- USB cable, phone cable
- Consumables Included
- 1 x toner cartridge (black) - up to 700 pages
- DHHS, EN 61000-3-2, EN55022, ICES-003, EN 61000-3-3, EN55024, FCC Part 15 B, FCC Part 68, FCC Part 15 C, RoHS, FCC Part 2, UL 60950-1, IEC 60950-1, EN 60950-1, WEEE, FDA, Energy-Related Products (ErP) Lot 6, REACH, CAN/CSA C22.2 No. 60950-1-07, Energy-Related Products (ErP) Lot 4
- ENERGY STAR Certified
- Blue Angel Compliant
- Limited warranty - 1 year
- 40.9 cm
- 39.85 cm
- 31.65 cm
- 11.5 kg
- Shipping Width
- 62.3 cm
- Shipping Depth
- 51.7 cm
- Shipping Height
- 49.9 cm
- Shipping Weight
- 15.6 kg
- Sound Emission
- 33 dB (idle) / 50 dB (operating)
- 10 °C
- 32.5 °C
- 10 - 80%
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.91 |
