Dell E515dn Mono Laser Multifunction Printer
Quicklinx: BKG4WS00 Mfr#: 210-AEHE
For added ease, the Dell E515dn multifunction printer comes with enhanced one-click features, great for your everyday printing and imagining needs.
  • Simple set up
    Get your printer up and running quickly with the Dell's easy installation.
  • Sharable printing
    Ethernet connectivity allows you to conveniently share your printer.
  • Hassle-free paper handling
    Fax, scan or copy hands-free with the automatic document feeder and reduce paper use thanks to automatic two-sided printing. The E515dn also features a robust cassette input paper tray that helps keep paper free from dust.
  • Enhanced copy features
    The "ID Copy" button allows you to copy both sides of an ID card on a single side of paper.
Dell E515dn - multifunction printer - B/W
Multifunction printer
Fax Type
Super G3 - plain paper
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
10000 pages
Recommended Monthly Volume
300 - 1000 pages
Max Copying Speed
Up to 20 ppm
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 27 ppm
Max Printing Resolution
Up to 2400 x 600 dpi
Max Fax Transmission Speed
33.6 Kbps
Scanning
600 x 1200 dpi
Original Size
210 x 350 mm (max)
Original Type
Sheets
Document Feeder Capacity
35 sheets
Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, labels, recycled paper, bond paper, thick paper
Standard Media Capacity
250 sheets
Max Media Capacity
251 sheets
Bypass Feeder Capacity
1 sheet
Output Trays Capacity
100 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
USB 2.0, LAN
Office Machine Features
Scan to folder, scan to FTP
AC 230 V (50/60Hz)
40.9 cm x 39.85 cm x 31.65 cm
11.5 kg
Environmental Standards
ENERGY STAR Qualified, Blue Angel
1-year warranty
Fax Type
Plain paper
Printing Technology
Laser - monochrome
10000 pages
300 - 1000 pages
Display
2 lines
USB 2.0, LAN
Standard Memory
64 MB
Copying
Max Copying Speed
Up to 20 ppm
Up to 600 x 600 dpi
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Exposure Modes
Text, photo, text and photo
Copying Features
2 on 1, 4 on 1, ID Card Copy
Printing
Max Printing Speed
Up to 27 ppm
Printer Drivers / Emulations
PCL 6, PostScript 3, XPS
Automatic Duplexing
Scanning
Scan Element
CIS
Optical Resolution
600 x 1200 dpi
Interpolated Resolution
19200 x 19200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Document & Media Handling
Max Original Size
210 x 350 mm
Original Type
Sheets
35 sheets
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
105 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), JIS B5 (182 x 257 mm)
250 sheets
Max Media Capacity
251 sheets
1 sheet
100 sheets
Input tray - 250 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 80 g/m² , Bypass tray - 1 sheet weight: 60 g/m² - 105 g/m²
Speed Details
Printing: up to 27 ppm (Letter A) - B/W , Printing: up to 26 ppm (A4) - B/W , Printing: up to 15 ppm (Letter A) - B/W duplex , Printing: up to 13 ppm (A4) - B/W duplex , Scanning: up to 17 ipm - B/W , Scanning: up to 6 ipm - colour , Copying: up to 20 ppm (Letter A) , Copying: up to 19 ppm (A4)
1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
Operating System Support
MS Windows Server 2003, MS Windows 7, MS Windows Vista, MS Windows Server 2003 x64 Edition, MS Windows Server 2008, MS Windows Server 2008 R2, Apple Mac OS X 10.7.x, Ubuntu Linux 12.04, Apple Mac OS X 10.8.x, MS Windows Server 2012, Windows 8, Red Hat Enterprise Linux 6 Desktop, Windows 8.1, MS Windows Server 2012 R2, Apple Mac OS X 10.9.x, SUSE Linux Enterprise Desktop 11 (32/64-bit), Apple Mac OS X 10.10
AC 230 V (50/60Hz)
480 Watt
Power Consumption Standby
60 Watt
Power Consumption Sleep
6.6 Watt
USB cable, phone cable
Consumables Included
1 x toner cartridge (black) - up to 700 pages
DHHS, EN 61000-3-2, EN55022, ICES-003, EN 61000-3-3, EN55024, FCC Part 15 B, FCC Part 68, FCC Part 15 C, RoHS, FCC Part 2, UL 60950-1, IEC 60950-1, EN 60950-1, WEEE, FDA, Energy-Related Products (ErP) Lot 6, REACH, CAN/CSA C22.2 No. 60950-1-07, Energy-Related Products (ErP) Lot 4
ENERGY STAR Certified
Blue Angel Compliant
Limited warranty - 1 year
40.9 cm
39.85 cm
31.65 cm
11.5 kg
Shipping Width
62.3 cm
Shipping Depth
51.7 cm
Shipping Height
49.9 cm
Shipping Weight
15.6 kg
Sound Emission
33 dB (idle) / 50 dB (operating)
10 °C
32.5 °C
10 - 80%
BKG4 C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.91
