This 23.8-inch Full HD monitor features a wide viewing angle, HDMI connectivity and an eco-conscious design.
Wide viewing angle
See your work in superb FHD clarity. IPS technology delivers consistent color and picture quality across a wide 178°/178° viewing angle. -
Easy on the eyes
This monitor has a flicker-free screen with ComfortView, a software feature that reduces harmful blue light emissions. It's designed to optimize eye comfort even over an extended period of time. -
Convenient connectivity
Connect to current and legacy systems via HDMI, VGA and DP ports. -
Maximize your desktop
Cut clutter with space-saving features like a compact stand and improved cable management that hides cables while complementing any workspace. -
Clean, simple design
A slim bezel adds a modern look. -
Adapts to your needs
Make your workspace your own with VESA-compatible mounts and stands.
- Dell E2422HN - LED monitor - Full HD (1080p) - 24"
- LED-backlit LCD monitor - 24"
- Energy Class
- Class E
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.2745 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 5 ms (grey-to-grey fast), 8 ms (grey-to-grey normal)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72% (CIE 1931), 83% (CIE 1976)
- Input Connectors
- HDMI, VGA
- Tilt
- Screen Coating
- Anti-glare 3H hardness
- Voltage
- AC 100-240 V (50/60 Hz)
- Black
- 55.264 cm x 17.1 cm x 42.035 cm
- 3.55 kg
- Environmental Standards
- TCO Certified Displays 8, ENERGY STAR Qualified EPEAT Gold
- RoHS, NFPA 99, BFR-free, PVC-free, Mercury-free
- Bundled Services
- 3 years Advanced Exchange Service
- Designed For
- Vostro 14 5410, 15 3510, 15 5510
- Display Type
- Energy Class
- Class E
- Diagonal Size
- 24"
- Viewable Size
- 23.8"
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2745 mm
- Pixel Per Inch
- 93
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Colour Gamut
- Response Time
- Vertical Refresh Rate
- 50 - 75 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- LED backlight
- LED edgelight system, Mercury free, arsenic-free glass
- Black
- 55.264 cm x 17.1 cm x 42.035 cm - with stand
- 3.55 kg
- HDMI , VGA
Mechanical
- Tilt
- Tilt Angle
- -5/+21
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), VESA interface support
- Included Accessories
- VESA screw cover
- Cables Included
- 1 x HDMI cable
- Input Voltage
- Power Consumption SDR (On mode)
- 16 kWh/1000h
- Power Consumption (Typical)
- 16 Watt
- Power Consumption (Max)
- 28 Watt
- Power Consumption Stand by
- 0.3 Watt
- 0.3 Watt
- Included Software
- Dell Display Manager
- Dimensions & Weight Details
- With stand - width: 55.264 cm - depth: 17.1 cm - height: 42.035 cm - weight: 3.55 kg , Without stand - width: 55.264 cm - depth: 4.969 cm - height: 331.61 cm - weight: 3.2 kg
- Shipping Weight
- 5.5 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Gold
- ENERGY STAR Certified
- ENERGY STAR Version
- 8.0
- Bundled Services
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
- Designed For
- Dell Vostro 14 5410, 15 3510, 15 5510
