Dell E2417H 24" 1920 x 1080 8ms DP VGA LED Monitor
Quicklinx: DD3KWS00 Mfr#: E2417H
Diagonal Size: 24in
Max Resolution: 1920 x 1080
Response Time: 8ms
Speakers: None
Interfaces: DisplayPort, VGA (HD-15)
28 in stock
£109.11 ex VAT
£130.93 inc VAT
View your applications, spreadsheets and more with incredible clarity. Optimize eye comfort and reduce harmful blue light emissions with ComfortView and a flicker free screen. See consistent colors across an ultrawide viewing angle. Easily access buttons for power, brightness, contrast and customizable preset modes on the monitor's front panel. Work comfortably by tilting the monitor 5° forward or 21° backward. The monitor is compatible with most legacy and current PCs via VGA and DisplayPort connectivity.
  • Maximize workplace productivity with a monitor designed to meet your business needs
  • Create a workspace that fits your desired specifications
Dell E2417H - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.275 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
8 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
VGA, DisplayPort
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, 3H Hard Coating
56.26 cm x 17.99 cm x 42.51 cm
3.97 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, DDC/CI, RoHS, EDID compatible
Bundled Services
3 years Advanced Exchange Service
Latitude 7400 2-in-1
Display Type
Diagonal Size
24"
Viewable Size
23.8"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.275 mm
Pixel Per Inch
93
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
8 ms (grey-to-grey)
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED
OSD Languages
Chinese (simplified), Brazilian Portuguese, English, German, French, Russian, Spanish, Japanese
LED edgelight system, 72% NTSC (CIE 1931) colour gamut, Flicker Free technology, BFR/PVC-free, Mercury free, arsenic-free glass, Dell ComfortView, 87% NTSC (CIE 1976) colour gamut
56.26 cm x 17.99 cm x 42.51 cm - with stand
3.97 kg
DisplayPort , VGA
Mechanical
Tilt
Tilt Angle
-5/+21
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), LED indicator, integrated cable management, VESA interface support, Dell Soundbar mounting slots
VESA screw cover
1 x DisplayPort cable
22 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.3 Watt
Power Consumption (Off Mode)
0.3 Watt
Dimensions & Weight Details
With stand - width: 56.26 cm - depth: 17.99 cm - height: 42.51 cm - weight: 3.97 kg , Without stand - width: 56.26 cm - depth: 5.35 cm - height: 33.31 cm - weight: 3.28 kg
ENERGY STAR Certified
Limited warranty - 3 years
Bundled Services
10 - 80% (non-condensing)
Dell Latitude 7400 2-in-1
Dell E2417H 24 Bundle deal on Dell E2417H 24" 1920 x 1080 8ms DP VGA LED Monitor
£208.28
Diagonal Size: 24in
Response Time: 8ms
Speakers: None
Interfaces: VGA (HD-15)
Brand: Dell
Price Range Ex VAT: 100 - 150
