Brand
Dell E2220H  22" (21.5" viewable) 5ms VGA  1920 x 10 LED Monitor
Quicklinx: FWSKWS00 Mfr#: DELL-E2220H
Diagonal Size: 22in
Max Resolution: 1920 x 1080
Response Time: 5ms
Interfaces: VGA (HD-15), DisplayPort
More than 50 in stock
£102.64 ex VAT
£123.16 inc VAT
Marketing description is not available.
  • Maximize your workspace
    A thin profile and improved cable management create a smaller footprint, lending itself to a clean, uncluttered desk.
  • Enhanced views
    The Full HD resolution is ideal for everyday tasks, while ComfortView is ready for extended viewing periods. It reduces up to 60% of harmful blue light emissions.
  • Versatile connections
    The E Series monitors accommodate legacy and non-legacy systems with convenient connectivity options like VGA and DP ports. Your workspace will be completely customized to your needs.
  • Adapts to your needs
    Make your workspace your own with VESA-compatible mounts and stands.
  • Productive at every level
    Dell Display Manager's (DDM) Easy Arrange feature lets you quickly tile and view your applications side by side across one or more connected screens for multitasking efficiency. And with the improved DDM, you'll get even more preset layouts.
  • Seamless transitions
    The auto-restore feature remembers where you left off, so applications will go back to where you left them, even after you've unplugged.
  • The key to convenience
    Shortcut keys can save you even more time, letting you easily configure your display management settings so you can get to work faster.
  • More ways to manage
    Asset management reports allow IT managers to quickly capture and track monitor information as well as configure multiple monitors at once through a single setup.
  • Guaranteed green
    Compliant with the latest Energy Star standards, the E Series monitors meet stringent energy efficiency requirements while in sleep, on and off modes. They're also TCO-certified.
  • Energy reducing
    Save energy with PowerNap, a feature that dims or puts the monitor to sleep when not in use.
  • Clean disposal
    Composting or recycling the packaging is easy since it's made with at least 25% of recycled cardboard.
Dell E2220H - LED monitor - Full HD (1080p) - 22"
LED-backlit LCD monitor - 22"
Energy Class
Class D
Power Consumption (On mode)
10.8 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Colour Gamut
72% (CIE 1931), 83% (CIE 1976)
Input Connectors
VGA, DisplayPort
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
Voltage
51.22 cm x 17.1 cm x 39.73 cm
Environmental Standards
TCO Certified Displays 8, ENERGY STAR Qualified
DisplayPort 1.2, HDCP 1.2
Bundled Services
3 years Advanced Exchange Service
Display Type
Energy Class
Class D
Diagonal Size
22"
Viewable Size
21.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Pixel Per Inch
102
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Colour Gamut
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Flicker Free technology, Dell ComfortView
51.22 cm x 17.1 cm x 39.73 cm - with stand
DisplayPort 1.2 , VGA
Mechanical
Tilt
Tilt Angle
-5/+21
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), VESA interface support
VESA screw cover
1 x DisplayPort cable - DisplayPort to DisplayPort , 1 x VGA cable
Input Voltage
10.8 W
10.8 kWh/1000h
Power Consumption (Typical)
13 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.3 Watt
Power Consumption (Off Mode)
0.3 Watt
Included Software
Dimensions & Weight Details
With stand - width: 51.22 cm - depth: 17.1 cm - height: 39.73 cm , Without stand - width: 51.2 cm - depth: 5.24 cm - height: 30.37 cm - weight: 2.7 kg
Shipping Weight
4.9 kg
TCO Certified
ENERGY STAR Certified
Bundled Services
Diagonal Size: 22in
Response Time: 5ms
Interfaces: DisplayPort
Brand: Dell
Stock Status: In stock
