Dell E2216H 21.5" 1920x1080 5ms VGA DisplayPort LED Monitor
Quicklinx: BM8GWS00 Mfr#: 210-AFPR
Diagonal Size: 21.5in
Max Resolution: 1920 x 1080
Response Time: 5ms
Speakers: None
Interfaces: DisplayPort, VGA (HD-15)
£81.33 ex VAT
£97.59 inc VAT
This reliable and affordable monitor meets everyday office demands. It has a great display quality at multiple angles with VESA-mount compatibility, as well as a VGA and DisplayPort. Save energy with power-efficient features.
Dell E2216h - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms (black-to-white)
Colour Support
16.7 million colours
Input Connectors
VGA, DisplayPort
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, 3H Hard Coating
51.22 cm x 18 cm x 39.67 cm
3.36 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
TCO Certified Displays 8
Plug and Play, DDC/CI, RoHS, CECP
3-year warranty
Bundled Services
3 years Advanced Exchange Service
Display Type
Diagonal Size
21.5"
Viewable Size
21.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Video Bandwidth
148.5 MHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Screen Coating
Backlight Technology
LED backlight
Controls & Adjustments
Brightness, contrast, H/V position, sharpness, phase, aspect control
OSD Languages
Chinese (simplified), Brazilian Portuguese, English, German, French, Russian, Spanish
72% (CIE 1931) colour gamut, 84% (CIE 1976) colour gamut, Flicker Free technology, adjustable LED power indicator, Energy Gauge, backlight dimming control
51.22 cm x 18 cm x 39.67 cm - with stand
3.36 kg
DisplayPort , VGA
Mechanical
Tilt
Tilt Angle
-6/+22
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), integrated cable management, VESA interface support, Dell Soundbar mounting slots
Stand, VESA screw cover
1 x DisplayPort cable
Security Slot Type
Kensington security slot
24 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.3 Watt
Included Software
Drivers & Utilities, Dell Display Manager
Dimensions & Weight Details
With stand - width: 51.22 cm - depth: 18 cm - height: 39.67 cm - weight: 3.36 kg , Without stand - width: 51.22 cm - depth: 5.05 cm - height: 30.37 cm - weight: 2.84 kg
TCO Certified
Limited warranty - 3 years
Bundled Services
10 - 80% (non-condensing)
Dell E2216H 21.5 Bundle deal on Dell E2216H 21.5" 1920x1080 5ms VGA DisplayPort LED Monitor
£180.50
Accessories (4)
BM8G StarTech.com Monitor Mount w/ Articulating Arm - Grommet or Desk Mount In Stock £65.12
BM8G StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount In Stock £112.28
BM8G StarTech.com Dual Monitor Stand In Stock £70.92
BM8G StarTech.com Monitor Arm - Heavy Duty In Stock £74.67
Other bundles (7)
BM8G C2G 2m DisplayPort Male to HD Male Adapter Cable - Black In Stock £23.02
BM8G C2G 2m DisplayPort Male to Single Link DVI-D Male Adapter Cable In Stock £25.11
BM8G C2G 3m DisplayPort Cable with Latches M/M - Black In Stock £8.17
BM8G C2G 10m DisplayPort Cable with Latches M/M – Black In Stock £23.89
BM8G C2G 20cm DisplayPort Male to Single Link DVI-D Female Adapter Cable - Black In Stock £16.60
BM8G C2G 20cm DisplayPort Male to HDMI Female Adapter Converter Black In Stock £21.09
BM8G C2G 20cm DisplayPort Male to VGA Female Adapter Converter Black In Stock £16.28
Response Time: 5ms
Speakers: None
Interfaces: VGA (HD-15)
Brand: Dell
Price Range Ex VAT: 50 - 100
