HD quality display with ultra-wide viewing angles, tilt feature, VGA port and VESA-mount compatibility. EcoEnergy saving with power-efficient features.
Screen performance
View your applications, spreadsheets and more on 19.5 inches of 1440x900 HD clarity, with a 16:10 aspect ratio, 16.7 million colors, an 85 percent color gamut and a 178° ultra-wide viewing angle that allows colors to remain consistent from virtually any angle. -
Plug and view
Compatible with both legacy and non-legacy PCs via VGA and DisplayPort connectivity. -
Mounting option
Keep your desk clutter-free by mounting your VESA compatible monitor on the wall or using the optional Dell Single Monitor Arm, detailed below. -
Tilt at will
Work comfortably by tilting the monitor 5° forward or 21° backward. -
Convenient controls
Easily access buttons for power, brightness, contrast and customizable preset modes on the monitor's front panel.
- Dell E2016 - LED monitor - 20" - with 3-Years Advanced Exchange Warranty
- LED-backlit LCD monitor - 20"
- Panel Type
- IPS
- Aspect Ratio
- 16:10
- Native Resolution
- 1440 x 900 at 60 Hz
- Pixel Pitch
- 0.2915 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 6 ms (grey-to-grey with overdrive)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72% (CIE 1931), 85% (CIE 1976)
- Input Connectors
- VGA
- Tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 45.421 cm x 18 cm x 39.095 cm
- 2.81 kg
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, DDC/CI, RoHS, CECP
- 3-year warranty
- Bundled with
- 3-Years Advanced Exchange Warranty
- Display Type
- Diagonal Size
- 20"
- Viewable Size
- 19.45"
- Panel Type
- IPS
- Aspect Ratio
- 16:10
- Native Resolution
- Pixel Pitch
- 0.2915 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Colour Gamut
- Response Time
- Vertical Refresh Rate
- 56 - 76 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Video Bandwidth
- 136.75 MHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Brightness, contrast, H/V position, sharpness, colour temperature, phase, aspect control
- OSD Languages
- Chinese (simplified), Brazilian Portuguese, English, German, French, Russian, Spanish, Japanese
- Adjustable LED power indicator, BFR/PVC-free, Energy Gauge, Mercury free, backlight dimming control, arsenic-free glass
- Black
- 45.421 cm x 18 cm x 39.095 cm - with stand
- 2.81 kg
- Bundled with
- VGA
Mechanical
- Tilt
- Tilt Angle
- -5/+21
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), integrated cable management, VESA interface support, Dell Soundbar mounting slots
- Included Accessories
- Stand, VESA screw cover
- Cables Included
- 1 x VGA cable
- Security Slot Type
- Kensington security slot
- Input Voltage
- Power Consumption (Typical)
- 20 Watt
- Power Consumption Stand by
- 0.3 Watt
- Power Consumption Sleep
- 0.3 Watt
- Included Software
- Drivers & Utilities, Dell Display Manager
- Dimensions & Weight Details
- With stand - width: 45.421 cm - depth: 18 cm - height: 39.095 cm - weight: 2.81 kg , Without stand - width: 45.421 cm - depth: 5.099 cm - height: 29.795 cm - weight: 2.29 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
