Dell E1920H 19" 1366 x 768 5ms HDMI VGA LED monitor
Quicklinx: FY9RWS00 Mfr#: DELL-E1920H
Diagonal Size: 19in
Max Resolution: 1366 x 768
Response Time: 5ms
Interfaces: DisplayPort, VGA (HD-15)
26 in stock
£103.13 ex VAT
£123.75 inc VAT
Marketing description is not available.
Dell E1920H - LED monitor - 19"
LED-backlit LCD monitor - 19"
Energy Class
Class C
Power Consumption (On mode)
8 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
1366 x 768 at 60 Hz
Pixel Pitch
0.3 mm
Brightness
200 cd/m²
Contrast Ratio
600:1
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
VGA, DisplayPort
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
Voltage
44.54 cm x 17.1 cm x 35.96 cm
Environmental Standards
TCO Certified Displays 8, ENERGY STAR Qualified
Bundled Services
3 years Advanced Exchange Service
Display Type
Energy Class
Class C
Diagonal Size
19"
Viewable Size
18.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
1366 x 768 at 60 Hz
Pixel Pitch
0.3 mm
Pixel Per Inch
85
Brightness
200 cd/m²
Contrast Ratio
600:1
Colour Support
Response Time
5 ms (grey-to-grey)
Horizontal Viewing Angle
65
Vertical Viewing Angle
90
Screen Coating
Anti-glare
Backlight Technology
LED backlight
72% (CIE 1931) colour gamut, 83% (CIE 1976) colour gamut, ComfyView, Flicker Free technology
44.54 cm x 17.1 cm x 35.96 cm - with stand
DisplayPort (DisplayPort 1.2 mode) , VGA
Mechanical
Tilt
Tilt Angle
-5/+21
VESA Mounting Interface
100 mm, VESA
Security lock slot (cable lock sold separately), VESA interface support
VESA screw cover
1 x DisplayPort cable - DisplayPort to DisplayPort , 1 x VGA cable
Input Voltage
8 W
8 kWh/1000h
Power Consumption (Typical)
10 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.3 Watt
Included Software
Dell Display Manager
Dimensions & Weight Details
Without stand - weight: 2.19 kg , With stand - width: 44.54 cm - depth: 17.1 cm - height: 35.96 cm
Shipping Weight
3.92 kg
TCO Certified
ENERGY STAR Certified
Bundled Services
Diagonal Size: 19in
Response Time: 5ms
Interfaces: VGA (HD-15)
Brand: Dell
Stock Status: In stock
