Dell E1916H 18.5" 1920x1080 5ms VGA DisplayPort LED Monitor
Customer rating: 1.0* (Write a review)
Quicklinx: BM89WS00 Mfr#: 210-AFOX
Diagonal Size: 19in
Max Resolution: 1366 x 768
Response Time: 5ms
Interfaces: DisplayPort, VGA (HD-15)
£74.73 ex VAT
£89.67 inc VAT
A reliable and affordable 18.5-inch monitor with essential features that meets everyday office demands. It features HD quality display with VESA-mount compatibility and tilt options, as well as VGA and DisplayPort connectivity. It also saves energy with power-efficient features.
  • Screen performance
    View your applications, spreadsheets and more on 18.5-inch of 1366x768 HD clarity, with 16.7 million colors.
  • Plug and view
    Compatible with both legacy and current PCs via VGA and DisplayPort connectivity.
  • Mounting possibility
    Keep your desk clutter-free by mounting your VESA compatible monitor on the wall.
  • Tilt at will
    Work comfortably by tilting the monitor forward or backward.
  • Convenient controls
    Easily access buttons for power, brightness, contrast and customizable preset modes on the monitor's front panel.
  • Environmentally friendly materials
    This improved Dell monitor is made with arsenic-free glass and a mercury-free LED panel. Its circuit boards are made from brominated flame retardant (BFR)- and PVC-free laminates.
Dell E1916H - LED monitor - 19"
LED-backlit LCD monitor - 19"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
1366 x 768 at 60 Hz
Pixel Pitch
0.3 mm
Brightness
200 cd/m²
Contrast Ratio
600:1
Response Time
5 ms (black-to-white)
Colour Support
16.7 million colours
Input Connectors
VGA, DisplayPort
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, 3H Hard Coating
44.54 cm x 16.7 cm x 35.9 cm
2.72 kg
Microsoft Certification
Compatible with Windows 7
Plug and Play, DDC/CI, RoHS, CECP
3-year warranty
Bundled Services
3 years Advanced Exchange Service
Display Type
Diagonal Size
19"
Viewable Size
18.51"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
1366 x 768 at 60 Hz
Pixel Pitch
0.3 mm
Brightness
200 cd/m²
Contrast Ratio
600:1
Colour Support
Response Time
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
90
Vertical Viewing Angle
65
Screen Coating
Backlight Technology
LED backlight
Controls & Adjustments
Brightness, contrast, H/V position, sharpness, input select, colour temperature, phase
OSD Languages
Chinese (simplified), Brazilian Portuguese, English, German, French, Russian, Spanish, Japanese
72% (CIE 1931) colour gamut, 82% (CIE 1976) colour gamut, LED edgelight system, adjustable LED power indicator, Energy Gauge, backlight dimming control
44.54 cm x 16.7 cm x 35.9 cm - with stand
2.72 kg
DisplayPort , VGA
Mechanical
Tilt
Tilt Angle
-6/+22
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), integrated cable management, VESA interface support, Dell Soundbar mounting slots
Stand, VESA screw cover
1 x DisplayPort cable
Security Slot Type
Kensington security slot
17 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.3 Watt
Included Software
Drivers & Utilities, Dell Display Manager
Dimensions & Weight Details
With stand - width: 44.54 cm - depth: 16.7 cm - height: 35.9 cm - weight: 2.72 kg , Without stand - width: 44.54 cm - depth: 5.15 cm - height: 26.6 cm - weight: 2.26 kg
Limited warranty - 3 years
Bundled Services
10 - 80% (non-condensing)
BM89 C2G 3m DisplayPort Cable with Latches M/M - Black In Stock £8.17
BM89 C2G 10m DisplayPort Cable with Latches M/M – Black In Stock £21.32
BM89 C2G 20cm DisplayPort Male to Single Link DVI-D Female Adapter Cable - Black In Stock £14.78
BM89 C2G 20cm DisplayPort Male to HDMI Female Adapter Converter Black In Stock £18.94
BM89 C2G 20cm DisplayPort Male to VGA Female Adapter Converter Black In Stock £14.51
Customer reviews
Write a review for the Dell E1916H 18.5" 1920x1080 5ms VGA DisplayPort LED Monitor here!
Item description wrong
Reviewed by Anonymous Review Posted 24/09/2018
This is not 1920 x 1080. It is 1366 x 768
  • Overall 1*
  • Ease of use 1*
  • Value for money 1*
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
Diagonal Size: 19in
Response Time: 5ms
Interfaces: VGA (HD-15)
Brand: Dell
Price Range Ex VAT: 50 - 100
