Dell E1715S 17" 1280x1024 5ms VGA DisplayPort LED Monitor
Quicklinx: 9J32WS00 Mfr#: 855-BBBC
The Dell 17 monitor E1715S is your smart choice for reliability and essential features that can help drive productivity. Add the E1715S to your workplace for a great viewing experience in just about any setting.
  • Essential features
    The E1715S offers HD quality viewing, easy connectivity and compatibility with legacy custom applications.
  • Responsible design
    The E1715S minimizes power consumption with an efficient LED backlight and PowerNap technology.
  • A great fit
    This compact, 5:4 aspect ratio monitor can fit into smaller spaces while still maintaining compatibility with software requiring a 5:4 display ratio.
  • Simple connections
    Simplify connections to laptop and desktop PCs with VGA and DisplayPort connectors.
  • Tilt adjustment
    Tilt the screen up to 5.5° forward or 22° backward for optimal viewing comfort.
Dell E1715S - E Series - LED monitor - 17"
LED-backlit LCD monitor - 17"
Energy Class
Class D
Power Consumption (On mode)
9 W
Panel Type
TN
Aspect Ratio
5:4
Native Resolution
1280 x 1024 at 60 Hz
Pixel Pitch
0.264 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms (black-to-white)
Colour Support
16.7 million colours
Colour Gamut
85% (CIE 1976)
Input Connectors
VGA, DisplayPort
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
37.45 cm x 16.55 cm x 38.95 cm
United Kingdom
Environmental Standards
TCO Certified Displays 8, ENERGY STAR Qualified
CEL
3-year warranty
Display Type
Energy Class
Class D
Diagonal Size
17"
Panel Type
TN
Aspect Ratio
5:4
Native Resolution
Pixel Pitch
0.264 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Colour Gamut
85% (CIE 1976)
Response Time
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 81 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Screen Coating
Backlight Technology
LED backlight
PowerNap
37.45 cm x 16.55 cm x 38.95 cm - with stand
VGA , DisplayPort
Mechanical
Tilt
Tilt Angle
-5.5/+22
VESA Mounting Interface
100 x 100 mm
Stand
CEL
United Kingdom
Security Slot Type
Kensington security slot
Power Supply
Internal
Input Voltage
9 W
9 kWh/1000h
Power Consumption (Typical)
11 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
Dimensions & Weight Details
With stand - width: 37.45 cm - depth: 16.55 cm - height: 38.95 cm , Without stand - width: 37.45 cm - depth: 4.65 cm - height: 30.69 cm - weight: 2.08 kg
Sustainability Information
TCO Certified
ENERGY STAR Certified
Limited warranty - advance parts replacement - 3 years
10 - 80% (non-condensing)
