Dell E1715S 17" 1280x1024 5ms VGA DisplayPort LED Monitor
Quicklinx: BJ4LWS00 Mfr#: 210-AEUR
Diagonal Size: 17in
Max Resolution: 1280 x 1024
Response Time: 5ms
Speakers: None
Interfaces: DisplayPort, VGA (HD-15)
More than 50 in stock
£91.92 ex VAT
£110.30 inc VAT
The Dell 17 monitor E1715S is your smart choice for reliability and essential features that can help drive productivity. Add the E1715S to your workplace for a great viewing experience in just about any setting.
  • Essential features
    The E1715S offers HD quality viewing, easy connectivity and compatibility with legacy custom applications.
  • Responsible design
    The E1715S minimizes power consumption with an efficient LED backlight and PowerNap technology.
  • A great fit
    This compact, 5:4 aspect ratio monitor can fit into smaller spaces while still maintaining compatibility with software requiring a 5:4 display ratio.
  • Simple connections
    Simplify connections to laptop and desktop PCs with VGA and DisplayPort connectors.
  • Tilt adjustment
    Tilt the screen up to 5.5° forward or 22° backward for optimal viewing comfort.
Dell E1715S - LED monitor - 17"
LED-backlit LCD monitor - 17"
Panel Type
TN
Native Resolution
1280 x 1024 at 60 Hz
Pixel Pitch
0.264 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms (black-to-white)
Colour Support
16.7 million colours
Input Connectors
VGA, DisplayPort
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, 3H Hard Coating
37.45 cm x 16.55 cm x 38.95 cm
Environmental Standards
ENERGY STAR Qualified
Plug and Play, VESA EDID, DDC/CI, RoHS, CECP
3-year warranty
Bundled Services
3 years Advanced Exchange Service
Display Type
Diagonal Size
17"
Viewable Size
17"
Panel Type
TN
Native Resolution
Pixel Pitch
0.264 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 81 kHz
Video Bandwidth
135 MHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Screen Coating
Backlight Technology
LED backlight
Controls & Adjustments
Brightness, contrast, H/V position, sharpness, saturation, input select, colour temperature, phase, clock, hue
OSD Languages
Chinese (simplified), English, German, French, Portuguese, Russian, Spanish, Japanese
72% (CIE 1931) colour gamut, 85% (CIE 1976) colour gamut, LED edgelight system, PowerNap, Image Enhance
37.45 cm x 16.55 cm x 38.95 cm - with stand
VGA , DisplayPort
Mechanical
Tilt
Tilt Angle
-5.5/+22
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), LED indicator, VESA interface support
Stand, VESA screw cover
1 x VGA cable
Security Slot Type
Kensington security slot
15 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
Included Software
Drivers & Utilities, Dell Display Manager
Dimensions & Weight Details
With stand - width: 37.45 cm - depth: 16.55 cm - height: 38.95 cm , Without stand - width: 37.45 cm - depth: 4.65 cm - height: 30.69 cm - weight: 2.08 kg
ENERGY STAR Certified
Limited warranty - 3 years
Bundled Services
10 - 80% (non-condensing)
Accessories (4)
BJ4L StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount In Stock £110.82
BJ4L StarTech.com Dual Monitor Stand In Stock £70.24
BJ4L StarTech.com Cubicle Monitor Hanger In Stock £46.01
BJ4L StarTech.com TV/Monitor Arm - Wallmount In Stock £66.06
Other bundles (4)
BJ4L C2G 2m DisplayPort Male to HD Male Adapter Cable - Black In Stock £22.20
BJ4L C2G 10m DisplayPort Cable with Latches M/M – Black In Stock £22.89
BJ4L C2G 20cm DisplayPort Male to Single Link DVI-D Female Adapter Cable - Black In Stock £15.89
BJ4L C2G 20cm DisplayPort Male to VGA Female Adapter Converter Black In Stock £15.58
Diagonal Size: 17in
Response Time: 5ms
Speakers: None
Interfaces: VGA (HD-15)
Brand: Dell
Price Range Ex VAT: 50 - 100
