Brand
Dell D3100 USB 3.0 Ultra HD Triple Video Docking Station
Quicklinx: B23NWS00 Mfr#: 452BBOO
Device Type: Laptop
More than 50 in stock
£171.95 ex VAT
£206.34 inc VAT
The Dell Docking Station - USB 3.0 connects your laptop to up to three additional monitors, various external devices and the Internet with a single cable. It's a convenient way to expand the capabilities of your portable PC and customize your desktop computing environment. This sleek, compact dock unlocks enhanced productivity and entertainment options with high-speed connectivity and support for Ultra HD 4K displays. Designed for Ultra HD 4K resolution, this USB 3.0 universal docking station enables compatible PC's to display 4K resolution when connected.
  • Easily connect laptops
  • Supports one Ultra HD 4K display and two Full HD displays
    Expand your desktop by connecting up to three displays at once, including one Ultra HD 4K display and two Full HD displays. The Dell Docking Station allows you to spread out your desktop on up to three external displays, increasing productivity and making it easier to manage multiple applications.
  • High-speed data transfer with USB 3.0
    The Dell Docking Station offers ultra-fast data transfer speeds among connected devices. The dock features three USB 3.0 ports, as well as two USB 2.0 connections, ensuring compatibility with a vast array of peripherals, such as external hard drives, printers and scanners. The dock also provides USB charging to external devices.
  • Expand productivity with peripherals
    Your laptop is no longer constrained by its included ports. With a single cable, the Dell Docking Station - USB 3.0 connects your laptop to various devices, such as printers, scanners and external hard drives. There's also a Gigabit Ethernet port, headphone jack and audio output to connect external speakers.
  • Advanced networking and security for enterprise use
    The Dell Docking Station - USB 3.0 is a great choice for corporate environments. There's also an integrated cable lock slot, so the dock can be secured to a desk or workstation.
Dell D3100 - docking station - USB - 2 x HDMI, DP - GigE
Docking station
Docking Interface
USB
Video Interfaces
2 x HDMI, DP
Gigabit Ethernet
Power adapter
Dell P2715; Inspiron 13 73XX, 14 34XX, 14 5447, 15, 15 35XX, 15 55XX, 15 7548, 17 57XX, 17 77XX, 5458, 55XX, 5759; Latitude 13 7350, 3150, 33XX, 34XX, 35XX, E5270, E5450, E5470, E5550, E5570, E7250, E7270, E7450, E7470; UltraSharp U2515, U3415; Vostro 35XX; XPS 12 9250, 13, 13 9350, 15, 15 9550
Docking station
Enclosure Colour
Gigabit Ethernet
2 x USB 2.0 - 4 pin USB Type A , 3 x SuperSpeed USB 3.0 - 9 pin USB Type A , 2 x display / video - HDMI - 19 pin HDMI Type A , 1 x display / video - DisplayPort - 20 pin DisplayPort , 1 x network - RJ-45 , 1 x headphones - output - mini-phone 3.5 mm , 1 x audio - output - mini-phone 3.5 mm , 1 x SuperSpeed USB 3.0 - 9 pin USB Type B
1 x HDMI-DVI adapter - external , 1 x SuperSpeed USB cable - external - 61 cm
Security lock slot (cable lock sold separately), wake on LAN
Security Slot Type
Kensington security slot
Power adapter
Microsoft Windows XP / 7 / 8 / 8.1 (32/64 bits)
Dell E5515H, P2415Q, P2715Q , Dell Inspiron 13 7347, 13 7348, 14 3442, 14 3451, 14 5447, 15 3541, 15 3542, 15 3543, 15 3551, 15 5547, 15 5548, 15 7548, 15 Gaming 7567, 15R 5547, 17 5748, 17 5749, 17 7746, 17 7778 2-in-1, 5458, 5555, 5558, 5759, 7737 , Dell Latitude 13 7350, 3150, 3330, 3340, 3440, 3450, 3540, 3550, 3570, E5250, E5270, E5450, E5470, E5550, E5570, E7250, E7270, E7450, E7470 , Dell Precision M3800 , Dell UltraSharp U2515H, U3415W , Dell Vostro 3558, 3559 , Dell XPS 12 9250, 13, 13 (9343), 13 9350, 15 (9530), 15 9550, 18, 18 (1820)
Device Type: Laptop
Brand: Dell
Stock Status: In stock
